How Does Light Intensity Change Through Three Stacked Polarizing Films?
  • Thread starter Thread starter chaosprimer
The discussion centers on calculating the intensity of light passing through three stacked polarizing films, each oriented at +45 degrees relative to the previous one. The initial light intensity is 1 watt, and the Law of Malus is applicable for determining the transmission through each polarizer. The formula Itrans = Io cos²θ is used, where θ is the angle between the light's polarization direction and the polarizer's axis. The final intensity can be calculated using this equation for each polarizer in the stack.
  • Understanding of the Law of Malus in optics
  • Knowledge of light intensity and polarization concepts
  • Familiarity with trigonometric functions and their applications
  • Basic principles of collimated light
  • Study the application of the Law of Malus in various optical systems
  • Explore the effects of multiple polarizers on light intensity
  • Investigate the behavior of light through non-ideal polarizers
  • Learn about collimated light sources and their characteristics
Physics students, optical engineers, and anyone interested in the principles of light polarization and its applications in optical devices.
chaosprimer
If you have 3 perfect polarizing films and you place them on top of the other, with each successive film oriented +45 degrees from the one before it (first and last oriented perpendicular to each other and middle polarizer at 45 degrees between them). If one shines a light on this polarizer stack with an intensity of 1 watt, what is the intensity of the light on the other side of the three polarizer stack?
Now when I tried to figure this out I assume that the light is collimated and that the films are perfect polarizer. But I got stuck on the actually equation... Anyone out there knows how to solve this?
Perhaps the Law of Malus applies.
For each polarizer - Itrans = Io cos2[itex]\theta[/itex], where [itex]\theta[/itex] is the angle of between axis of polarizer and some reference.
The question is what is the transmission of light through the first polarizer.
Edit: See http://hyperphysics.phy-astr.gsu.edu/hbase/phyopt/polcross.html
for discussion of crossed polarizers and Law of Malus.
10K
  • · Replies 20 ·
