Thread Closed
Rolle's Theorem
Share Thread Thread Tools
Nov11-05, 05:19 PM   #1
Rolle's Theorem
Ok I think I can use Rolles theorem on F(x)=x^2+3x on the inteval [ 0,2]
because the derivative can be defined
so then I think I use the formula [f(b)-f(a)] / [b-a] to find f'(c), then set f'(c) = F'(x) and solve is this process right?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Nov11-05, 06:03 PM   #2
AKG
Recognitions:
Homework Helper Homework Help
What are you even trying to prove?
Nov11-05, 09:13 PM   #3
It seems you're using the mean value theorem, which is the one you listed. Rolle's theorem says that if f(a)=f(b) on some closed interval, then there must be some point c such that f'(c)=0.
Nov12-05, 11:50 AM   #4
Recognitions:
Rolle's Theorem
rolles theorem is a trivial consequence of the obvious (but deep) fact that a continuous function f which takes the same value twice must have a local extremum in between.
then rolle says if f is also differentiable, the derivative is zero there.
the MVT is then a further trivial consequence of rolle.
i.e. both rolle and MVT are trivial, but useful consequences of one deep result about continuity.
my point is that the emphasis on these two as big time theorems is quite misplaced.
even their statements take away something from the result, since just knowing the derivative is zero somewhere in between two points is decidedly weaker than knowing there is a local extremum.
for instance the statement of rolles theorem does not imply that between two critical points of a continuously differentiable function there must be a flex, but the stronger result does.
Nov14-05, 03:57 PM   #5
I had seen my error after my post I was using the mean value theorem instead of rolles theorem opps thanks for the replys though
Thread Closed
Thread Tools
Similar Threads for: Rolle's Theorem
Thread Forum Replies
Rolle's Theorem...Please Help... Calculus & Beyond Homework 5
rolle's theorem problem Calculus & Beyond Homework 6
Calc Help, Rolle's Thm Maybe? Calculus & Beyond Homework 2
proof using Rolle's thm or the Mean Value Thm Calculus & Beyond Homework 3
Gauss's Divergance Theorem and Stokes's Theorem Classical Physics 1
