VB Error: Array Names are Ambiguous - What Now?
  • Thread starter Thread starter zanazzi78
    Array Error
The discussion revolves around a Visual Basic (VB) error related to ambiguous array names. Participants are exploring the reasons behind this error and seeking solutions to resolve it. The scope includes technical explanations and potential troubleshooting steps related to programming in VB.
  • Technical explanation, Debate/contested
  • One participant reports an issue with VB indicating that array names are "ambiguous" and seeks clarification on how to resolve this.
  • Another participant requests further elaboration on the problem to better understand the context.
  • A participant mentions defining an array as spd(n,n) under 'Option Explicit' and questions why VB does not accept this definition.
  • It is suggested that the variable 'n' must be explicitly defined, as 'Option Explicit' requires all variables to have a defined type.
  • Another participant notes that typically, an array can only be dimensioned to fixed values or constants, and suggests using the 'ReDim' function for dynamic sizing.
  • A participant explains that an "ambiguous name detected" error can occur if there is a naming conflict with a sub, function, or variable that shares the same name as the array being defined.
Participants express varying views on the causes of the ambiguous name error, with some suggesting it relates to variable definitions and others pointing to naming conflicts. The discussion remains unresolved regarding the best approach to address the issue.
Participants have not fully clarified the definitions or values of the variables involved, particularly 'n', which may affect the understanding of the problem. There is also a lack of consensus on the best practices for defining arrays in this context.
zanazzi78
To those who helped yesterday,again, thanks.
I have managed to resolve most of my problems, however, i have a new issue.
VB seemsto think that the names of my arrays are "ambiguous", WHY?
what do i need to do to resolve this new and fustrating problem?
Technology news on Phys.org
Can you elaborate?
In the optionexplict i`ve defined my array as spd(n,n)
Vb doesn`t like this and i don`t know why!
Have you defined n?
'Option Explicit' means you must explictly define every variable with a type. If you merely say a(n,n) that's not explicit.
You first need 'Dim n as integer'.
Typically you can only dimension an array to either values (i.e. 4) or constants. If you have n defined as dim n as integer, it will (in my experience) kick the variable out. If you need to have it change size look at the redim function. Hope this helps
An "ambiguous name detected" error is caused by a sub, function, or some other variable or array having the same name as the one you are currently trying to define.
  • · Replies 17 ·
  • · Replies 23 ·
  • · Replies 28 ·
13K
  • · Replies 31 ·
