Acid/Base Questions: True or False?
  • Thread starter Thread starter parwana
The discussion centers on the true or false evaluation of five statements regarding acid-base chemistry. The consensus is that statements a, b, c, and e are false, while statement d is true. Specifically, combining 0.3 moles of any acid with 0.3 moles of any base does not guarantee a pH of 7.0, and a 1 M solution of HCl and HNO3 do not have identical pOH values. Additionally, combining acetic acid and NaOH does not result in a buffer, and a 1.0 M HCl solution has a pH of 1.0.
  • Understanding of pH and pOH concepts
  • Knowledge of strong vs. weak acids and bases
  • Familiarity with buffer solutions
  • Basic acid dissociation constants (pKa) and their implications
  • Study the principles of acid-base neutralization reactions
  • Learn about buffer solution preparation and its applications
  • Explore the concept of pKa and its role in acid strength
  • Investigate the differences between strong acids like HCl and weak acids like acetic acid
Chemistry students, educators, and professionals in laboratory settings who require a solid understanding of acid-base reactions and their implications in various chemical contexts.
parwana
Answer the following questions t or f
a) Combining 0.3 moles of any acid with 0.3 moles of any base in water will always result in a pH value of 7.0
b) A 1 M solution of HCl and a 1 M solution of HNO3 have identical pOH values
c) Combining equal volumes of a 0.3 M acetic acid solution and a 0.3 M NaOH solution results in a buffer
d) The pH of a 1.0 M HCl (a strong acid) solution is 1.0
e) A 1 M solution of acetic acid (pKa = 4.75) and a 1 M solution of HCN (pKa = 9.20) have identical pH values
I would think abc would be false, d would be true, and e would be false. Please help
If you could tell why you think each answer is right or wrong, it would be easier to help.
In reality all are false, but one answer may depend on your education level.
  • · Replies 23 ·
