Mastering Linear Vector Spaces: Exploring Bases, Dependence, and Operators
  • Thread starter Thread starter fahd
    Linear Vector
The discussion revolves around two problems related to linear vector spaces, specifically focusing on concepts of linear dependence and the properties of differential operators in the context of quantum mechanics. The original poster expresses confusion regarding the material, indicating a lack of thorough instruction on the topic.
  • Participants discuss the definitions of linear dependence and basis, suggesting that the original poster consider how vectors in a larger set relate to a given basis. There is also mention of the properties of the momentum operator, including linearity and hermitian nature, with references to integration by parts.
Some participants provide guidance on how to approach the problems, emphasizing the importance of understanding definitions and properties. The conversation includes attempts to clarify the application of integration by parts and the behavior of functions in the context of the second question. The original poster expresses gratitude for the assistance and indicates a newfound understanding of the concepts discussed.
The original poster notes a lack of adequate instruction on the topic, which may impact their ability to tackle similar problems in the future. There is an emphasis on the need to consider the entire vector space when discussing the properties of functions.
fahd
hi there..i am stuck wid these 2 problems from the subject mathematical methods for physicists and the topic is "linear vector spaces"
Q1) If S={|1>,|2>,...|n>} is a basis for a vector space V, show that every set with more than n vectors is linearly dependent? (where |> is a dirac bracket)
Q2)Show that the differential operator
p=h/i (d/dx)
is linear and hermitian in the space of all deifferentiable wave functions
[phi(x)] that, say, vanish at both ends of an interval (a,b)?
i am totally confused with these two questions..we were not taught this topic that well and they expect us to know these questions because similar ones like these wud be in the test tomrrow..please help me ..i dun want to loose marks.I ALSO KNOW THAT according to the rules..i need to show u what iv dun so far..but please understand..what do i show you..im totally confused! please revert!
to get started
hey Fahd,
if you're going to continue on in physics, particularly quantum mechanics, this is important stuff to know. to get you started think about the definitions of the terms involved. linearly dependent means that at least one of the vectors in the 'greater than n' set can be written in terms of others in the set. also recall that the definition of a basis is that any vector in the space can be written in terms of these basis vectors. start out by thinking about how you can write every vecor in the 'greater than n' set in terms of the n vectors given as the basis.
for the momentum operator recall that linearity just means
O[a f(x) + b g(x)] = a O f(x) + b O g(x)
and hermitian just means
[tex] \int_a^b f(x)^*p g(x) \,dx = \int_a^b (p f(x))^* g(x) \,dx[/tex]
do a little integration by parts and you should be set
gabe
Allday said:
hey Fahd,
gabe
thanks allday
just wonering
what do i take as f(x) and g(x) in the second question as stated by you
thanks
you can't use any particular function because the relation has to hold for the entire vector space ie (every differentiable wave function). the only objects you can use are those functions and their derivatives. The important thing to know (and this comes up all the time in derivations) is that integration by parts allows you to move a derivative under an integral from one function to the other at the cost of a boundary term and a minus sign.
ill show you some of the steps in the last part.
[tex] \int_a^b f^*(x)\frac{h}{i}\frac{dg}{dx} \,dx [/tex]
[tex] = \frac{h}{i}[f^*(x=b)g(x=b)-f^*(x=a)g(x=a)] - \int_a^b \frac{h}{i}\frac{df^*}{dx}g(x)[/tex]
how is this related to the rhs? the tricky part about these problems is dealing only with the abstract label of the function which represents all the functions in a certain family. here you'll have to make some assumptions about how the functions behave at the boundries of the region that they're defined (x=a and x=b)
thanks
hey..allday
thanks a lot for ur help
i finally understood it well...got both the questions..i was initially wondering where did g(x) and f(x) come from when they don't belong to the question..now i know!
thanks again!
glad to hear that it makes sense. i know it feels great to finally understand a particularly abstract concept.
gabe
  • · Replies 18 ·
  • · Replies 23 ·
  • · Replies 25 ·
  • · Replies 32 ·
