How Does Angular Acceleration Affect Rotational Motion?
The discussion focuses on calculating angular acceleration and tangential speed in rotational motion scenarios involving a rotating door and a falling rod. For the rotating door, the mass of each glass pane is 95 kg, and a force of 80 N is applied perpendicularly. The solution involves determining the rotational inertia of the door and applying the torque formula to find angular acceleration. For the falling rod, which is 1.90 m long, the tangential speed just before impact can be calculated using its moment of inertia and the time of fall.
  • Understanding of rotational kinematics
  • Knowledge of torque and angular acceleration
  • Familiarity with moment of inertia calculations
  • Basic principles of angular motion
  • Study the calculation of rotational inertia for composite objects
  • Learn about torque and its application in rotational dynamics
  • Explore the relationship between angular displacement and tangential speed
  • Investigate the equations of motion for rigid bodies in rotational motion
Physics students, mechanical engineers, and anyone interested in understanding the principles of rotational dynamics and motion analysis.
rockmorg
Hey all, thought I should ask about a couple problems...
1 - A rotating door is made from four rectangular glass panes, as shown in the drawing. The mass of each pane is 95 kg. A person pushes on the outer edge of one pane with a force of F = 80 N that is directed perpendicular to the pane. Determine the magnitude of the door's angular acceleration.
This says it is about a fixed axis so I don't know how that changes it, but it doesn't seem like I have enough information for one of the rotational kinematics equations...
2 -
A thin uniform rod is initially positioned in the vertical direction, with its lower end attached to a frictionless axis that is mounted on the floor. The rod has a length of 1.90 m and is allowed to fall, starting from rest. Find the tangential speed of the free end of the rod, just before the rod hits the floor after rotating through 90°.
This one seems like it should be really easy, but I'm not sure. I'll need the time it takes for the rod to fall, and I assume that I could use moment of inertia somehow because they specifically say thin uniform rod? Then convert the angle it fell thru to radians...?
Thanks much, any help is appreciated!
rockmorg
For problem 1, first find the rotational inertia of the door (includes all 4 panes). Then, you can use the torque formula to find the angular acceleration. Remember the force is perpendicular to the pane.
  • · Replies 22 ·
  • · Replies 19 ·
