Organic Chemistry Lab: Calculate NaBH4 Needed to Reduce Acetophenone
  • Thread starter Thread starter quarkboy
    Stoichiometry
This discussion focuses on calculating the mass of a 12% NaBH4 aqueous solution required to reduce 5.00 g of acetophenone in an organic chemistry lab. The calculation involves determining the moles of NaBH4 needed, where the molecular weight of NaBH4 is established as 38 g/mol. Participants clarify that a 12% solution indicates 12 g of NaBH4 per 100 g of solution, leading to the conversion of mass to moles for accurate stoichiometric calculations. The balanced chemical equation for the reaction between acetophenone and NaBH4 is also necessary for completing the calculation.
  • Understanding of molarity and molality concepts
  • Knowledge of stoichiometry in chemical reactions
  • Familiarity with calculating molecular weights
  • Basic principles of preparing solutions based on percentage by weight
  • Learn how to write balanced chemical equations for organic reactions
  • Study the concept of percent by weight solutions in chemistry
  • Explore stoichiometric calculations involving limiting reagents
  • Investigate the properties and applications of NaBH4 in organic synthesis
Students in organic chemistry labs, chemistry educators, and anyone involved in chemical calculations and solution preparation.
quarkboy
Im taking an organic chemistry lab, must calculate the following:
NaBH4 is normally prepared for use in basic aqueous solution. Calculate the mass of a 12% NaBH4 aqueous solution required theoretically to reduce 5.00 g of acetophenone.
I am can probably have a go at this question if I can get a hint on how to start ? Anyone point me in the right direction, I don't want the solution but a helping hand in working out the right way to do this. Thanks in advance.Edit: 12 moles NaBH4 / 100 mL water ? x 1 mole NaBH4 / 38 g NaBH4 x ... ?
Is that 12% NaBH4, 12% by weight (mass)? Then it would be 12 g NaBH4 in 100 gm of solution. Then one must convert that to moles.
Percent by weight: To make up a solution based on percentage by weight, one would simply determine what percentage was desired (for example, a 20% by weight aqueous solution of sodium chloride) and the total quantity to be prepared.
See - http://environmentalchemistry.com/yogi/chemistry/MolarityMolalityNormality.html
Another example -
http://www.madsci.org/posts/archives/aug97/867968894.Ch.r.html
NaBH4 by mass ...partial solution
Calculated Molecular Weight
MW NaBH4 : 23 + 11 + 4 = 38g
Convert to moles - NaBH4
12g NaBH4 / 100g NaBH4 * 1 mole NaBH4 / 38g = 0.0032 moles NaBH4However, at this point I need to write a balanced equation for the Acetophenone and NaBH4 reactants ? I am not sure if this makes sense so far.
Any hints ?
13K
23K
40K
