Simulating the Spiralling Motion of a Coin on a Table
  • Context: Graduate
  • Thread starter Thread starter sreenathb
    Effects
This discussion focuses on simulating the spiraling motion of a coin on a table using three key equations: the gyroscopic moment equation, the conservation of energy equation, and the general kinematic equation. The user is facing challenges with non-linear equations and seeks numerical methods for approximate solutions. Recommended techniques include the Runge-Kutta method for numerical integration, the Euler method for simpler integration, and gradient-based optimization algorithms like Levenberg-Marquardt and Newton's Method.
  • Understanding of gyroscopic motion and its equations
  • Familiarity with conservation of energy principles
  • Knowledge of kinematic equations
  • Basic programming skills for numerical methods implementation
  • Research the Runge-Kutta method for numerical integration
  • Explore the Euler method for solving differential equations
  • Learn about gradient-based optimization algorithms, specifically Levenberg-Marquardt
  • Investigate Newton's Method for finding roots of non-linear equations
Students and researchers in physics, mathematicians, and software developers interested in simulating dynamic systems and solving non-linear equations.
sreenathb
i am trying to simulate the spiralling motion of a coin that is rolled on a table.i am having three equations...
1. the gyroscopic moment equation.
2. the conservation of energy equation.
3. general kinematic equation.
three unknowns...curvature radius,precession velocity and coin inclination.
the equations i am getting are non-linear.can someine suggest me any numerical methods to solve these approximately.
i want those which can be easily programmed.i tried one which uses the jacobian..bit found that the solution was not converging.
anyone please help.
It sounds like you're trying to solve a difficult problem! Have you tried using numerical integration techniques, such as the Runge-Kutta method? This method is relatively easy to program, and can be used for non-linear equations. You could also look into the Euler method, which is a simpler numerical integration technique. Another option is to try a gradient-based optimization algorithm, such as Levenberg-Marquardt or Newton's Method. These may be able to help you find an approximate solution to your equations. Good luck!
  • · Replies 20 ·
20K
  • · Replies 38 ·
