Proof of Rational Root Theorem
The discussion centers around the Rational Root Theorem, specifically seeking a proof of the theorem and addressing challenges encountered in the proof process. Participants explore the implications of polynomial coefficients being integers and the conditions under which rational roots may exist.
  • One participant attempts to prove that if a polynomial has rational roots of the form p/q, where p and q are factors of the constant term and leading coefficient respectively, then p must divide a_0 and q must divide a_n.
  • Another participant challenges the assumption that integer polynomials necessarily have rational roots, suggesting that there are counterexamples.
  • Some participants assert that the sum of integers is an integer, supporting the argument that the expression involving p and q remains an integer.
  • There is a discussion about the nature of p and q, with some asserting they should be coprime rather than both being prime numbers.
  • A participant questions the logic behind concluding that p divides a_0 implies it is a factor, and suggests exploring the role of q in the proof.
  • Another participant proposes an alternative approach by considering the polynomial's roots and their implications on the factors of the constant term and leading coefficient.
Participants express differing views on the existence of rational roots for integer polynomials, with some asserting that rational roots may not exist at all. There is no consensus on the proof approach or the implications of the assumptions made regarding p and q.
Participants highlight the presumption that the polynomial has rational roots, which remains unverified. The discussion also touches on the definitions of factors and the implications of integer properties in the context of the theorem.
Paragon
I want to find a nice and elegant proof of the Rational Root theorem, but I get stuck. I read some stuff on the Internet, but I have not found a complete proof of the theorem. Here's my try:
Say we have a polynomial:
[tex]F(x) = \sum ^{n}_{r = 0} a_{n}x^{n} = a_{n}x^{n} + a_{n - 1}x^{n-1} + ... + a_{1}x + a_{0}[/tex]
where all of the coefficients are integers and [tex]a_{0}[/tex] does not equal zero.
I want to prove that there is a factor of [tex]a_{n}[/tex], call it q, and a factor of [tex]a_{0}[/tex], call it p, so that:
[tex]F(\frac{p}{q}) = 0[/tex]
p and q are prime numbers. So I want to prove that p is a factor of [tex]a_{0}[/tex] and q is a factor of [tex]a_{n}[/tex]. Next, I insert p/q into F(x):
[tex]F(\frac{p}{q}) = a_{n}\left(\frac{p}{q}\right)^{n} + a_{n-1}\left(\frac{p}{q}\right)^{n-1} + ... + a_{1}\left(\frac{p}{q}\right) + a_{0} = 0[/tex]
multiplying by [tex]q^{n}[/tex] we get:
[tex]a_{n}p^{n} + a_{n-1}p^{n-1}q + ... + a_{1}p q^{n-1} + a_{0}q^{n} = 0[/tex]
and factorizing out p:
[tex]p (a_{n}p^{n-1} - a_{n-a}p^{n-2} q - ... - a_{1} q^{n-1}) = a_{0} q^{n}[/tex]
As p, q are prime numbers, the Greatest Common Devisor of p and q is 1, i.e. GCD(p, q) = 1. And hence, p devides [tex]a_{0}[/tex] and is then a factor of [tex]a_{0}[/tex].
As the same kind of argument applies to q being a factor of [tex]a_{n}[/tex], I thought that this proved the theorem (p/q are roots of F(x)), but no... The problem is in:
how do I prove that: [tex]a_{n}p^{n-1} - a_{n-a}p^{n-2} q - ... - a_{1} q^{n-1}[/tex] is an integer?
You won't be able to prove that. Exercise: find a polynomial with integer coefficients which doesn't have any rational roots.
The "rational root" theorem that /I'm/ familiar with states that if p/q is a rational root of F and gcd(p, q) = 1, then q is a factor of a_n and p is a factor of a_0. (Note that this theorem doesn't guarantee that F actually has any rational roots).
A finite sum of integers is clearly an integer itself.
Firstly, as stated your trying to prove something that is false. There is no reason to suppose that an integer polynomial has *any* rational roots.Then there is the issue of what a rational root might look like even if it had one: consider 2x-1, its rational root is 1/2, and not of the form p/q where p and q are primes,
However, I don't see that issue you have is at all an issue: all of the a_r are integers, p and q are integers, and multiplying and adding together integers yields integers.
Indeed, the fact that the polynomial had rational zeros was a presumption. And p, q are factors of a_0 and a_n.
The statement: "A finite sum of integers is clearly an integer itself." hit the nail =)
Thanks guys, this helped a lot!
You asserted they were primes. They are at best coprime, or prime to each other.
My maths isn't that strong. I am having trouble with this proof as well. Basically its the logic of saying that p divides a0 and hence is a factor. Why couldn't q be factored out of the equation (instead of p) and then divide the a0*q^n on the RHS by q and just say that q is a factor of a0 (in addition to a factor of q^n).
Lastly, I don't understand why just because p divides [tex]a_{0}[/tex] means that it is a factor of a0. The logic seems to be that just because q^n can't be factored by p therefor it implies that a0 can be factored by p.
I would approach it from the other end. IF polynomial p(x) has root m/n, then (x- m/n) is a factor: p(x)= (x- m/n)q(x). So np(x)= (nx- m)q(x)= (nx-m)(an-1xn-1+ ...+ a0). It should be obvious from that, that the constant term has m as a factor. It is a little harder, because of that "n" in "np(x)", to see that the leading coefficient has m as a factor.
  • · Replies 31 ·
  • · Replies 27 ·
