Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
image Young double slit experiment Share It Thread Tools Search this Thread image
Old Nov17-05, 08:33 AM                  #1
Ukitake Jyuushirou
Ukitake Jyuushirou is Offline:
hello,
i am doing a work sheet on the title of this thread and i do not have the answer sheet for the questions so can some one please go through my answers and see if i am correct
Young used a monochromatic light source
a) wat does this mean?
my ans: light of a single wavelength
b) how did he achieve this?
my ans: by using sunlight
c)wat is the purpose of the single slit?
my ans: so that only light from the single slit will reach the double slit
d)when does destructive interference occur?
when the wavelength is 1/2 of the wavelength of the bright fringes
Old Nov17-05, 01:18 PM                  #2
Doc Al
PF Mentor
Doc Al's Avatar
Doc Al is Offline:
That's the correct meaning of monochromatic.
Sunlight is not monochromatic.
Well, yes, but why is that important? (The key is that it keeps the path length the same for light hitting the double slits.)
Not sure what that means. Hint: What must be the path length difference between light from each slit arriving at a point on the screen so that there is destructive interference?
Old Nov18-05, 03:08 AM                  #3
Ukitake Jyuushirou
thank u doc
for the qn 2 , wat then qualifies as a monochromatic light?
for the last qn, i mean to say the path difference between the 2 sources must be 1/2 wavelength
Old Nov18-05, 02:14 PM                  #4
Doc Al
PF Mentor
Doc Al's Avatar
Doc Al is Offline:
I don't know what Young did in his orginal experiments to get a monochromatic source, but he could have used a filter or a prism to select a single wavelength. (If you don't use a monochromatic source, then you'll get overlapping fringes from each wavelength.) Nowadays, getting a monochromatic source is easy using lasers.
Good. The path difference of the light from each slit must be 1/2 wavelength for destructive interference.
Old Nov18-05, 05:40 PM                  #5
Just some guy
Just some guy is Offline:
I assume he used a sodium lamp - it's monochromatic enough (not coherent though - that doesn't mean it's impossible to do but it makes it bl--dy hard (speaking from experience here )
Old Nov18-05, 06:54 PM                  #6
brewnog
brewnog's Avatar
brewnog is Offline:
Recognitions:
PF Contributor PF Contributor
I believe Young did use sunlight in his original experiment.
Old Nov18-05, 07:01 PM                  #7
Doc Al
PF Mentor
Doc Al's Avatar
Doc Al is Offline:
Absolutely. I just don't know what pains, if any, he took to select a particular wavelength.
image image
Reply
Thread Tools
Similar Threads for: Young double slit experiment
Thread Thread Starter Forum Replies Last Post
Problem: Plastic Covering One Slit in Double Slit Experiment chipwhisperer Introductory Physics 5 Feb22-07 09:01 PM
Double slit experiment Amith2006 Introductory Physics 6 Dec6-06 12:21 PM
Double-slit experiment of Young ntk Introductory Physics 5 Mar30-06 12:07 PM
Double Slit experiment Honorable_Death Quantum Physics 36 Nov6-05 12:15 AM
Double Slit Experiment LizardKing23 Quantum Physics 4 Apr21-05 07:53 AM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
