Telekinesis |
Dec2-03, 09:34 PM
#1
einsteinian77 is
Offline:
Telekinesis
Telekinesis is it possible? Why or why not
Dec3-03, 04:37 PM
#2
zoobyshoe is
Offline:
I don't believe it is possible. The reason would be that the human brain/body can't generate the right kind of force to move something, or enough of the right kind of force.
The notion of telekenesis probably arose from people hallucinating for one reason or another; psychosis or psychoactive plants. It has been fostered by charlatans who can do some very convincing magic tricks they pass off as real telekenisis. (Hint: there are very thin strings attached)
Dec4-03, 01:08 AM
#3
einsteinian77 is
Offline:
Why not? The body generates plenty of force to move itself.
Dec4-03, 01:29 AM
#4
zoobyshoe is
Offline:
Yes, but not telekinetically.
Dec4-03, 02:15 AM
#5
Jonathan is
Offline:
I have seen some 'evidence' that telekinesis, if a true case has ever occurred, is due to an abnormal ability to generate static electricity (at will, without shuffling your feet). however, I can't say much on this, I just don't know. I doubt it would be very strong static electricity, so I lean toward no.
Dec4-03, 07:52 PM
#6
wasteofo2 is
Offline:
Maybe you could consider those cybernetic monkeys that play videogames with their thoughts telekinetic, but they're aided by technology.
Dec4-03, 09:15 PM
#7
einsteinian77 is
Offline:
delete
Dec6-03, 03:27 PM
#8
Jeebus is
Offline:
Uri Geller claims he can bend spoons and stop watches using only his thoughts to control the external objects. Others claim to be able to make pencils roll across a table by a mere act of will. The variety of parlor tricks used to demonstrate psychokinetic powers is endless.
I once tried to move an ant with my mind once, all he did was sit there. My size 11 Nike got upset and smooshed him.
Dec21-03, 12:33 AM
#9
Yahweh is
Offline:
Re: Telekinesis
Jeebus,
Make sure you source your information. Your information came from Skepdic.com - telekinesis and psychokinesis.
Telekinesis is not possible.
1. There are no mechanisms in the human body that allow for controlling of objects with the human "mind".
2. Quite a few Laws of Physics (i.e. Thermodynamics and Laws of Motion) will be violated (keep in mind that "forces" are not a substance).
3. All instances of supposed telekinesis always have natural mundane causes (i.e. They are not telekinesis). Example of "telekinesis":
A 1" square of paper is balanced on the point of a needle. The psychic puts his hand next to the paper, and then it begins rotating.
Is that an example of telekinesis? No, just an example of heat from the "psychic's" hand producing convections currents that push the paper. It's an old trick and tends to fool those ignorant of the Laws of Physics. If that same trick were performed in a vacuum, the paper would not rotate (of course, the "psychic" might be killed by exposing himself in a vacuum).
Those a few reasons I can think off the top of my head.
Keep in mind, Uri Gellar's spoon bending is just a magic trick. Anyone can perform it. All it takes is a little preparation of the spoon (i.e. bending it to score a weak spot in the spoon, that allows you to merely use your fingers to wiggle the spoon, that creates a crack in the spoon, it begins to bend, eventually the spoon will snap in half... total time to snap the spoon is about 45 seconds...).
Dec21-03, 03:37 AM
#10
einsteinian77 is
Offline:
why do you assume to know the laws of physics when there isn't even a unified field theory yet. I would assume that there is much to be discovered in what life is in relation to the actual universe. The human mind is too incompetent to even think that it knows what the universe actually is. Just my thoughts.
Dec21-03, 07:32 AM
#11
Yahweh is
Offline:
While there is no Unified Field Theory yet, that doesnt make applying the Laws of Physics somehow inadequate.
There is still much to discover, however telepathy is not one of those things. In the 1000s of test performed in controlled environments, there has yet to be a single instance of even a smidgen of proof for the existence of telekinesis.
If there is no evidence that a certain thing exists, we can assume that it exists for the purposes of hypothesis and experimentation (such as Quark Theory), but if repeated experimentation and/or observation fails to show evidence that the thing exists, we can be fairly certain that it just ain't there.
One must be careful not to fall into the trap of thinking that because there is no evidence that something does not exist, that it might exist.
The James Randi Educational Foundation is willing to offer the first person US$1,000,000 if they can demonstrate any feat of the supernatural (i.e. dowsing, telekinesis, telepathy, anything of the sort...). Australian Skeptics offer AU$100,000. In fact, the combined offers skeptical organizations around the world yield a combined US$2,326,500. What a way to get rich quick!
That reasoning almost sounds like an Ad hoc fallacy.
I've heard often "humans are too ignorant to comprehend claim X, so claim X is true because so-and-so and it cannot be disproved! Hahahaha" many times (they dont really laugh at the end). Of course, the "human mind is too incompetent" puts itself in a position where you have a universal negative, or an unfalsifyable hypothesis. That puts the claim on a very shaky (or even non-existent) foundation. There's no substance to saying the human mind is too incompetent to understanding so-and-so.
Its not good reasoning at all to assume "Well we havent found evidence against its existence, so theres a chance that it does exist".
If its any help, the gateway between the puny competence of the human mind and the nature of the universe is called "Science".
Dec21-03, 08:43 AM
#12
Jonathan is
Offline:
Some of the things you said were just stupid.
The first automatically disallows the use of a theoretical proof as an absolute proof. The laws of physics are certainly well tested, but we would be very pompous, stupid, and prideful indeed if we thought that given experiments done on earth for a few thousand years we could know anything of any relevance about the working, past, and future of the universe. Also,
That 'quote' is good reasoning, though it would be slightly more correct if it said 'a small chance'. If I look for my cat in the three most likly rooms, and cannot find her, I can conclude that there is a small chance that she has gotten outside. I would not conclude that this must be what happened until I have checked the 4th, 5th, and 6th rooms, and then double checked them all, and then tried yelling 'kitty, kitty, kitty, eat!' to get her to come out from hiding. If those fail, then the most likly thing is that she has gotten away. But given the evidence I had since I started looking for her, that was a possiblility the whole time.
Dec21-03, 03:15 PM
#13
Bunting is
Offline:
maybe telekenesis is just a subject which has not yet been uncovered due to the evolution of the human body not being able to "refine it" yet. Technically its possible surely. Sound is a force, it travels as waves, and can be heard from all drirections by your ears, because they are rigged to decode the information. However telekenetic waves may not yet have a way of being interpreted. Because we can not observe something, it would be alot harder to work out what that thing is. I.e. if we did not have ears, or a way of decoding sound, who could tell how the course of history would be changed?
Theres also theproblem that EVEN IF we do have this, we may have the way of decoding it down, just not the way of transmitting it. Transmit any old sound wave in any old form and you get noise, and thats all. If telekinetic transmission is not wel developed, then oit would problalbly be undirection, weak signal strength or uncontrolled (you dunno what you are transmitting). I would favour (if any), the weak signal strength, due to some people claiming they do have it. There belief may be well founded.
Just my 2 cents! I dont reckon things are done until totally disproved :P
Dec22-03, 03:59 AM
#14
Yahweh is
Offline:
From my original post:
Thermodynamics and the Laws of Motion are some of the most profound and important Laws in Physics. Most would regard those 2 sets of laws as "impossible to violate", there are certainly no other laws I can think of that have been tested so thoroughly and shown to be true.
(Note: This story relating to how the Law Of Entropy was violated, of course it would help if the authors would note how shaking a system adds energy to, no such violation of Thermodyanamics occurred...)
You mention "if we thought that given experiments done on earth for a few thousand years we could know anything of any relevance about the working, past, and future of the universe". You dont do much to support yourself, do you believe that the "Natural Laws" (for lack of better terminology) have changed? If you can demonstrate this, your point might have a bit more credence. (Note: There is an established difference between laws written in a book which are revisable, and "Natural Law" which is irrevisable.)
Neither "Possibilites", nor "Percent Chances", nor "Statistical Likelyhoods" are absolute formulas which govern the world we live in.
By reading your analogy a few times, I see you dont have much a semantics based (in the significance of the word "possibility") overliteralized analogy, make sure to always exercise common sense (unknown to how that may be defined) when making judgements. Also, your analogy (where's kitty?) isnt analogous to my comments (The Laws of Thermodynamics and Motion - and other Laws - nullify any expectation of Telekinesis).
And please, if you are going to make a criticism, do so constructively (see first line of your response).
Dec22-03, 04:21 AM
#15
Yahweh is
Offline:
By technicality, it is quite impossible to find empirical evidence against the occurence or existence of anything. This is one of the areas where Science and Philosophy begin to intermingle with one another, its known as "universal doubt" in laymens terms (or Pyrrhoism in Philosophical Terms).
It is actually quite a paradox:
How can your disprove the existence of something which does not already exist?
To get beyond this, Science derives itself from a few basic axioms (i.e. the external world exists is an example).
If I told you I could morph into a tiger at the snap of my fingers, what would it take to disprove that I really dont have this ability?
Follow-up: If my tiger-morphing claim cant be disproved, is it still possible?
Note: Dont let common sense fly out the window, keep your Philosophy seperate from Science whenever you can.
Dec22-03, 04:32 AM
#16
Jonathan is
Offline:
1)Certaintly true, but unless the universe is finite I can prove that you can't actually be 100% sure about anything: epistemological pessimism and Godel's incompleteness theorem.
2)About you comments on the second law, I'd guess you don't know about emergent phenomena and chaos theory.
3)No, the natural laws do not change, what we think they are do. If I ask you to name all the natural laws, you and anyone else can only name what they think they are and add that you're sure that's not all of them, we're not done researching yet. We don't have God's book with all the exact laws in it, so my point is again about epistemological pessimism, we will never really know for sure if the laws we have are the right ones. In fact, if the universe is finite then technically there can be more than one theory that holds, but they could be proven, by definition, to be mathematically identical, and of only trivial conceptual difference.
4)This sounds contradictory to QM:
do we not live in a world made of particles? If we have only part of the info necessary to make a sound conclusion, can't we only come to statistical possiblities for conclusions?
5)I don't know what you are saying in this part:
But I was refering to this:
not this:
The Laws of Thermodynamics and Motion - and other Laws - nullify any expectation of Telekinesis.
Which I completely agree with. I don't even entirly understand our arguemnet here, because we both agree that telekinesis probably isn't real, what we disagree on is why.
6)You are right, that was mean, I'm sorry.
I find these quotes to be wise/funny:
"The more important fundamental laws and facts of physical science have all been discovered, and these are now so firmly established that the possibility of their ever being supplanted in consequence of new discoveries is exceedingly remote.... Our future discoveries must be looked for in the sixth place of decimals."
- Albert. A. Michelson, speech given in 1894 at the dedication of Ryerson Physics Lab, Univ. of Chicago
"In real life, every field of science is incomplete, and most of them - whatever the record of accomplisment during the last 200 years - are still in their very earliest stages."
- Lewis Thomas
"Wisest is she who knows she does not know."
- Anonymous
