Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Physics > Quantum Physics
Reply
image On the uniqueness of QED Share It Thread Tools Search this Thread image
Old Dec14-05, 05:29 AM                  #1
dextercioby
dextercioby's Avatar
dextercioby is Offline:
Recognitions:
Homework Helper Homework Helper
Using this convention
LaTeX Code:  A \\overleftrightarrow{\\partial }_{\\mu} B =:A \\overrightarrow{\\partial}_{\\mu} B - A \\overleftarrow{\\partial}_{\\mu} B
one can write the QED Lagrangian density simply as
LaTeX Code:  \\mathcal{L}_{QED} =\\frac{i}{2} \\bar{\\Psi}_{\\alpha} \\left(\\gamma^{\\mu}\\right)^{\\alpha}{}_{\\beta} \\overleftrightarrow{\\partial }_{\\mu} \\Psi^{\\beta} -m \\bar{\\Psi}_{\\alpha}\\Psi^{\\alpha} +g \\bar{\\Psi}_{\\alpha} \\left(\\gamma^{\\mu}\\right)^{\\alpha}{}_{\\beta} \\Psi^{\\beta} A_{\\mu} -\\frac{1}{4} F_{\\mu\\nu} F^{\\mu\\nu} -\\frac{1}{2\\xi} \\left(\\partial^{\\mu}A_{\\mu}\\right)^{2} + \\left(\\partial^{\\mu}\\bar{\\eta}\\right) \\left(\\partial_{\\mu} \\eta}\\right)
,where "g" is the coupling constant (plus/minus the electron's charge depending on the convention), LaTeX Code: \\eta  is the ghost field associated to the gauge parameter LaTeX Code:  \\epsilon  and LaTeX Code:  \\bar{\\eta}  is a ghost field from the nonminimal spectrum.
The question doesn't concern the uniqueness of the gauge-fixing term (one can implement various gauges, chosing a gauge-fixing fermion is, up to a point, arbitrary), but the consistent cross-interaction term, Dirac field - gauge abelian one-form field. The question is
Is LaTeX Code:  g \\bar{\\Psi}_{\\alpha} \\left(\\gamma^{\\mu}\\right)^{\\alpha}{}_{\\beta} \\Psi^{\\beta} A_{\\mu}  the only consistent cross-interaction between a massive Dirac field and a gauge abelian one-form field ? If so, how would one go about & prove it...?
Daniel.
Old Dec14-05, 06:17 AM                  #2
vanesch
PF Mentor
vanesch is Offline:
Originally Posted by dextercioby
The question is
Naive answer: dimensional power counting. Do you see another way to have a polynomial term that will give rise to a renormalizable interaction ?
Old Dec14-05, 08:22 AM       Last edited by Physics Monkey; Dec14-05 at 08:24 AM..            #3
Physics Monkey
Physics Monkey is Online:
Recognitions:
I think one could in principle have other terms like LaTeX Code:  \\bar{\\Psi} \\sigma^{\\mu \\nu} \\Psi F_{\\mu \\nu}  or indeed higher powers and so on. This term respects Lorentz invariance, gauge invariance, and CP invariance, and there is no reason, from the point of view of symmetries, why it shouldn't be in the Lagrangian. The term I mention here would give, among other things, a contribution to the electron's magnetic moment. Of course, as vanesch said, these terms are all non-renormalizable which is why they were historically excluded, but in the spirit of effective field theory, non-renormalizability isn't such a big deal. Such a term could actually be present and we wouldn't even know it unless we made it to sufficiently high energy or otherwise looked sufficiently closely.
I know this is discussed in the Weinberg, and if I remember right I think he even talks about this particular term.
Old Dec15-05, 04:50 AM                  #4
dextercioby
Recognitions:
Renormalizability, in the context of the question, is not an issue. One can couple gravitons to a large spectrum of fields, yet such theories are not renormalizable.
Well, the term LaTeX Code:  c \\bar{\\Psi} \\sigma^{\\mu\\nu} \\Psi F_{\\mu\\nu}  is both LaTeX Code:  \\delta  and LaTeX Code:  \\gamma  closed, so it describes a trivial interaction.
Daniel.
Old Dec15-05, 05:08 AM       Last edited by dextercioby; Dec15-05 at 05:11 AM..            #5
dextercioby
Recognitions:
I have come across very solid reasons that LaTeX Code:  g \\bar{\\Psi} \\gamma^{\\mu} \\Psi A_{\\mu}  is the only possible cohomologically non-trivial cross interaction between a gauge abelian one-form field & a massive Dirac field, regardless of "number of derivatives + renormalizability" issues. For now i'm interested if there are any other justifications.
Daniel.
Old Dec16-05, 03:17 AM                  #6
akhmeteli
akhmeteli is Offline:
Daniel.
I don't know if the following meets your requirements, but in my work http://www.arxiv.org/abs/quant-ph/0509044 I consider the standard Dirac-Maxwell Lagrangian, but vary the action under the constraint that the axial current vanishes, so the resulting equations of motion are different. Alternatively you may impose a weaker constraint, requiring that divergence of the axial current vanishes (in this case initial values may be arbitrary). These two theories seem to differ from the standard one but have the required symmetries.
Old Dec17-05, 10:00 AM                  #7
huhuayu
huhuayu is Offline:
Is QED a superior theory to quantum mechanics? Forgive my ignorance, but I think QED itself(the annihilation operator, the Lagrange and so on) is hard to get the scene of electrons jumping between bound state. Is it true?
Old Dec17-05, 08:17 PM                  #8
reilly
reilly is Offline:
Recognitions:
A question always to ask in problems of interaction structures is, "What else could it be?" There are only two possible terms for a local nucleon parity conserving vector current; first, the standard gamma nu, second is the anomolous magnetic moment contribution (q mu) (sigma mu nu) (See any particle physics book on electromagnetic structure of the nucleon, and the Rosenbluth cross section.)
Regards,
Reilly Atkinson
Old Dec18-05, 12:32 AM                  #9
lonelyphysicist
lonelyphysicist is Offline:
Could you explain what you meant by the above statements?
Old Dec19-05, 04:30 AM                  #10
dextercioby
Recognitions:
Well, "this particular term" cannot be in the classical lagrangian, since it's nothing but a (first order in LaTeX Code:  \\hbar  ) quantum correction to the original classical (nonquantized) lagrangian. U can see that LaTeX Code:  g\\bar{\\Psi} \\gamma^{\\mu} \\Psi A_{\\mu}  and LaTeX Code:  g\\bar{\\Psi} \\sigma^{\\mu\\nu} \\Psi \\partial_{[\\mu} A_{\\nu]}  are dimensionally not the same. Even if, by absurd they were, "this particular term" would still be found when discussing radiative corrections to the QED vertex LaTeX Code:  g\\bar{\\Psi} \\gamma^{\\mu} \\Psi A_{\\mu}  .
Daniel.
Old Dec19-05, 04:33 AM                  #11
dextercioby
Recognitions:
Regards,
Reilly Atkinson
The way the problem was presented, phenomenology is not an issue, as well...
Daniel.
Old Dec19-05, 04:38 AM       Last edited by dextercioby; Dec19-05 at 05:22 AM..            #12
dextercioby
Recognitions:
Daniel.
When discussing the idea behind the construction of QED Lagrangian, people usually get exposed to the "good ole Noether procedure" which requires gauging the global matter field's symmetry (for the case of a single Dirac field the global symmetry group is LaTeX Code:  U(1)  ). The interesting fact is that they take it for granted. One never asks him/herself why we do it and whether the result of this (namely the coupling one gets) is unique...Incidentally, why cannot one have a "seagull" term like in LaTeX Code:  SED  ...?
Daniel.
Old Dec19-05, 11:30 AM       Last edited by Physics Monkey; Dec19-05 at 11:37 AM..            #13
Physics Monkey
Recognitions:
dextercioby,
Thanks for the reply, but I don't understand your objection. The two terms have to have the same dimensionality if they are to be added in the Lagrangian. You seem to indicate that I would put the same coupling in front of each, but this is certainly not true. In particular, you can easily see that the coupling to the term I mentioned would have to have a dimension of -1, where as the usual coupling is dimensionless. This dimensional coupling is, of course, a sign of non-renormalizability. My point is that this term is completely consistent with gauge and Lorentz symmetry, and it leads to a non-trivial correction to the electron's magnetic moment.
Also, you need not go the route of gauging the global symmetry. Instead, you can start by trying to deal with the peculiarities of defining the propagator of a massless spin 1 particle, and then observe that you need a conserved current to couple the vector field to. With the minimal coupling assumption you end up at the same place, but this route makes it clear that there is no reason, from the point of view of gauge symmetry, why terms like the one I mentioned shouldn't be included.
I feel like I must be missing part of your argument, so what am I missing?
Old Dec19-05, 11:48 AM                  #14
Haelfix
Haelfix is Offline:
Recognitions:
Simple answer here. Even if you don't care about renormalizability too many weird cross terms can break partial wave unitarity bounds from experiment. Its a bit of a long detailed calculation from many Feynman diagrams to get all the relevant constraints, but it has been done (theres a book that does this)
Old Dec19-05, 08:13 PM       Last edited by Physics Monkey; Dec19-05 at 08:23 PM..            #15
Physics Monkey
Recognitions:
Haelfix,
Thanks for your reply, but I'm not sure I follow. The unitarity bounds are automatically respected as a consequence of the unitarity of the S-matrix. In non-renormalizable theories, it makes sense to expand the theory in a perturbation series in LaTeX Code:  E/M  where LaTeX Code:  E  is the energy scale of interest and LaTeX Code:  M  is the mass scale of the relevant non-renormalizable interactions. Now, simple extrapolation of the expansion to LaTeX Code:  E > M  does, in fact, lead to a naive violation of unitarity bounds. The Fermi theory of the weak decay had this problem, but everything is really ok. We know that the naive Fermi vertex develops structure at higher energies i.e. the W bosons appear, and this new physics prevents the violation of unitarity bounds. There is nothing wrong with the Fermi theory when viewed as effective field theory, and it is a useful description for energies LaTeX Code:  E << M_W . A similar thing is done all the time when developing various effective field theories based on QCD, those effective field theories contain all kinds of horrible interactions. Except in theories where the non-renormalizable effects somehow saturate, we expect that new physics will appear at the mass scale LaTeX Code:  M  . If this is the case, then our non-renormalizable quantum field theory is simply an effective field theory, but it isn't useless or invalid just because it can't be used in every regime.
Am I missing your point?
P.S. I would love to take a look at the book you mentioned, can you remember the title? Thanks.
Old Dec20-05, 05:24 AM                  #16
dextercioby
Recognitions:
I like your arguments. The problem i was trying to address is simply if one knows any way of generating interactions among free (of any self-interactions) fields and by means of this method if one can prove the uniqueness of couplings both in QED (simple part), SED (a bit more difficult) and QCD (not too difficult)...As i said b4, renomalizability, phenomenology and unitarity are not issues to be taken into consideration.
Daniel.
Daniel.
image image
Reply
Thread Tools
Similar Threads for: On the uniqueness of QED
Thread Thread Starter Forum Replies Last Post
Uniqueness theorem matheater Calculus & Analysis 2 Jun5-08 03:24 PM
Existence and Uniqueness LeBrad Differential Equations 4 Feb19-08 12:41 PM
uniqueness FizX Calculus & Analysis 3 Dec1-06 08:27 AM
Negating uniqueness Jeff Ford Precalculus Mathematics 2 Oct21-05 03:55 PM
A necessary condition for uniqueness saltydog Differential Equations 2 Jun17-05 11:06 PM
Powered by vBulletin Copyright ©2000 - 2010, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
