Evaluate Infinite Product to Find $\pi \cos ech\left( \pi \right)$
  • Thread starter Thread starter Benny
    Infinite Product
The discussion revolves around evaluating the infinite product \(\prod\limits_{n = 2}^\infty {\frac{{n^2 - 1}}{{n^2 + 1}}}\), which is claimed to equal \(\pi \cosh(\pi)\). Participants explore methods to approach this evaluation, referencing known infinite products and their properties.
  • Participants discuss writing expressions for the first \(n\) products and taking limits. There is mention of using the product form for sine and the Euler Gamma function as potential avenues for evaluation. Some participants express curiosity about the foundational infinite products and their applications in evaluating others.
The discussion is active, with participants sharing insights and hints without reaching a consensus. Some guidance has been provided regarding the use of known infinite products, but no definitive method or solution has been established yet.
Participants are navigating the complexities of infinite products, with references to specific mathematical functions and identities. There is an acknowledgment of the need for further exploration of foundational concepts in complex analysis and number theory.
Benny
Hi, can someone tell me how I would go about evaluating the following infinite product? I've included the answer and it's taken from mathworld.
[tex] \prod\limits_{n = 2}^\infty {\frac{{n^2 - 1}}{{n^2 + 1}}} = \pi \cos ech\left( \pi \right)[/tex]
I think I'm supposed to be write an expression for the first n products and take the limit. I've tried doing that but I don't know what to do with the expression.
[tex]\left( {\frac{{2^2 - 1}}{{2^2 + 1}}} \right)\left( {\frac{{3^2 - 1}}{{3^2 + 1}}} \right)...\left( {\frac{{n^2 - 1}}{{n^2 + 1}}} \right)[/tex]
Any help would be good thanks.
Do you know the product form for sine? It's usually the first target for writing as an infinite product, and the product you have follows fairly easily from it.
Ok, thanks for the hint. I'll go look up the product form of sine and see what I can come up with.
I love infinite products!
[tex]\prod\limits_{n = 2}^\infty {\frac{{n^2 - 1}}{{n^2 + 1}}} = \pi \mbox{cosh} \left( \pi \right)[/tex]
The above product is from the infinite product page at mathworld, their products were presumably derived using the infinite product for the Euler Gamma Function. I will use the sine product instead.
The infinite product for the sine function is (for complex z):
[tex]\sin \left( z \right) = z\prod\limits_{n = 1}^{\infty} {\left( 1-\frac{z^2}{\pi ^2 n^2} \right)}[/tex]
Recall that [tex]\sin (iz) = i \mbox{sinh}(z)[/tex] so that [tex]\mbox{csch}(z) = \frac{1}{\mbox{sinh}(z)}= \frac{i}{\sin (iz)}[/tex], and hence
[tex]\mbox{csch} \left( z \right) = \frac{i}{(iz)\prod\limits_{n = 1}^{\infty} {\left( 1-\frac{(iz)^2}{\pi ^2 n^2}\right) } }=\frac{1}{z}\prod\limits_{n = 1}^{\infty} {\left( 1+\frac{z^2}{\pi ^2 n^2}\right) ^{-1}}=\frac{1}{z}\prod\limits_{n = 1}^{\infty} {\frac{\pi ^2 n^2}{\pi ^2 n^2+z^2}}[/tex]
it follows that
[tex]\pi \mbox{csch} \left( \pi z \right) = \frac{1}{z}\prod\limits_{n = 1}^{\infty} {\frac{n^2}{n^2+z^2}}[/tex]
plugging z=1 into the above gives
[tex]\pi \mbox{csch} \left( \pi \right) = \prod\limits_{n = 1}^{\infty} {\frac{n^2}{n^2+1}}[/tex]
I can't quite get to what they had, but it is close.
-Ben
That looks quite interesting. Is there a 'model' infinite product which is used to evaluate other infinite products (like what shmoe appears to have alluded to) . If so, is there a way to evaluate such a product, using fairly elementary formulas and algebra?
You are almost done.Note that n^2-1 is (n-1)(n+1)
So product(n^2-1) for n=2 to n is 1.2.3^2.4^2...=product(n^2)/2
Product(n^2+1) for n=1 to n =2.Product(1+n^2) for n=2 to n
So from the above expression
pi*cosech(pi)=2*product(n^2-1)/2*product(n^2+1)=product(n^2-1/n^2+1)
for n=2 to infty
Yes! The Gamma Function
Yes, use the Euler Gamma function, it has several infinite product forms:
[tex]\Gamma (z) = \lim_{n\rightarrow\infty} \frac{n!n^{z-1}}{z(z+1)\cdot\cdot\cdot (z+n-1)} = \frac{1}{z}\prod_{k=1}^{\infty}\left[ \left( 1 + \frac{1}{k}\right) ^{z} \left( 1 + \frac{z}{k}\right) ^{-1}\right] = \left[ze^{\gamma z} \prod_{j=1}^{\infty} \left( 1+ \frac{z}{j}\right)e^{-\frac{z}{j}} \right] ^{-1}[/tex]
where [itex]\gamma = -0.577...[/itex] is Euler's constant. See my paper for a more complete discussion of the above infinite products and the Euler Gamma function.
A notable identitiy is the Euler reflection formula:
[tex]\Gamma (z) \Gamma (1-z) = \frac{\pi}{\sin (\pi z)}[/tex]
try deriving it via the above products...
It's odd that mathworld page only mentions Hadamard/Weiestrass product as a footnote. If you want to learn where the product form of these functions comes from, look for "hadamard factorization theorem", "hadamard products", "functions of finite order" or some variations. They'll be in more complex analysis books, and also in analytic number theory books (comes up with the zeta function).
If you look at the product form of sine, it's essentially factoring sine as though it were an "infinite polynomial", it's a product over its zeros (paired up to simplify convergence). This is possible for some analytic functions by hadamards work. In some ways, sine is the prototype simple case, up to normalization it's zeros are nicely placed on the integers.
Gamma has no zeros, but it has poles at 0, -1, -2, ... so 1/Gamma is then the other "prototype case, of this type of factorization, having zeros at the natural numbers (up to a simple change of variables).
Thanks for the information benorin and shmoe. If I have time before the end of my summer break then I'll have look at some of those topics.
HI Guys...
I am trying to figure out the infinite product :
product_(k=1)^(infty)(1+(2k)^2)/(1+(2k-1)^2))
Can anyone help? Benorin, you say you love infinite products... have a go!
I would be very grateful!
  • · Replies 22 ·
  • · Replies 16 ·
  • · Replies 105 ·
13K
