Hello. I need some help with the following problems.
4. A solid spherical container has a radius of 15 cm. The
electric field 30 cm from the center of this sphere has a magnitude of 800 N/C. What is the surface charge density (sigma) on the sphere?
I did:
EA= q/ e0
E(4)(pi)(r^2) = [sigma(4)(pi)(r^2)] / e0
E= sigma / e0
800(8.85 X 10^-12) = sigma
sigma = 7.08 X 10^-9
But the answer is 2.8 X 10^ -8 C/m^2
6. A uniform line charge of linear charge density lambda= 5 nC/m extends from x=0 to x=10 m. The magnitude of the electric field at the point y=12 m on the perpendicular bisector of the finite line of charge is?
I did:
I made a right triangle where 10 m was the length of the horizontal side and 12 m was the length of the vertical side. Then I found the hypotenuse to be 15.62 m
E= lambda / [(2pi)(e0)(r)]
E= (5X 10 ^ -9) / [(2pi)(8.85 X10^-112)(15.62)
E=7.49
But the answer is 2.88 N/C
16. An infinitely long cylindrical shell of radius 6.0 cm carries a uniform surface charge density sigma = 12 nC/m^2. The electric field at r = 6.1 cm is approximately?
I did:
EA = q/e0
E(2)(pi)(r)(l) = [sigma(2)(pi)(r)(l) ] / e0
E= sigma / e0
E= 1355.93
But the answer is 1.3 kN/c
I don’t know if my answer is wrong or correct because of rounding.
Any help would be greatly appreciated.
Thanks
