Einstein makes extra dimensions TOE the line
The discussion revolves around the implications of Einstein's principle of the constancy of the speed of light on theories predicting extra dimensions and the nature of black hole particle beams directed at Earth. It touches on theoretical physics, astrophysics, and the interpretation of observational data.
  • Some participants assert that Einstein's principle of the constancy of the speed of light undermines certain theories of extra dimensions and a complex structure of space.
  • One participant questions the alignment of black hole particle beams with Earth, suggesting it may not be a coincidence.
  • Another participant references models that are ruled out by high-energy astrophysical observations, indicating that certain extra dimension theories cannot account for observed phenomena like intergalactic absorption.
  • A later reply discusses blazars and their observational characteristics, suggesting that their alignment is due to chance rather than a directed phenomenon.
Participants express differing views on the implications of Einstein's principles for extra dimensions and the nature of black hole particle beams. The discussion remains unresolved with multiple competing perspectives presented.
Some arguments depend on specific astrophysical observations and models, which may not be universally accepted or fully resolved. The discussion includes references to complex theoretical frameworks that are not definitively established.
Ivan Seeking
Staff Emeritus
Scientists say that Albert Einstein's principle of the constancy of the speed of light holds up under extremely tight scrutiny, a finding that rules out certain theories predicting extra dimensions and a "frothy" fabric of space.
http://www.gsfc.nasa.gov/topstory/2003/1212einstein.html
What I want to know is why are those two black hole particle beams "aimed directly at the Earth"? Coincidence? I think not...
That's funny, but maybe you should take a look at this,
http://xxx.lanl.gov/abs/astro-ph/0308214
"Some models with large extra dimensions are ruled out by the existence of absorption in the very high energy spectra of nearby BL Lac objects. The fact that more distant brighter sources are not seen can also be taken as indirect evidence of intergalactic absorption by pair production interactions. The constraints based on analysis of the Crab Nebula γ-ray spectrum, discussed in the previous section, imply that the quantum gravity scale is orders of magnitude above the Planck mass scale. This indicates that the class of models considered here with linear Planck scale suppressed terms in the dispersion relations cannot be reflective of physics at the Planck scale. Models such as loop quantum gravity with a preferred inertial frame are ruled out by this line of reasoning. Alternative models to consider might be models with quartic momentum terms with [itex]M_{QG}^2[/itex] supression in the dispersion relations, Lorentz invariant quantum gravity models, or really new Planck scale physics such as string theory, which preserves Lorentz invariance."[/color]
Ah blazars! They're really no different from other active galactic nuclei (AGNs), just that by chance we're looking straight down the jets. You can use data on the observed blazar sky density to do several consistency checks of AGN models; e.g. if the jets have an opening angle of x radians, then the sky density of AGNs should be [tex]\frac{4\pi}{x}[/tex].
A good collection of links:
http://wwwospg.pg.infn.it/blazarsintheweb.htm
BTW, there are several threads with related discussions (including reference to the very same Stecker paper) in our very own PF Special & General Relativity board.
  • · Replies 0 ·
  • · Replies 34 ·
  • · Replies 62 ·
10K
  • · Replies 21 ·
  • · Replies 25 ·
