How Do I Solve This Tricky Calculus Problem About Rolling Ball Bearings?
The discussion revolves around a calculus problem involving a ball bearing rolling down an inclined plane, where the distance rolled is expressed as a function of time and the angle of elevation. Participants are exploring the concepts of speed and velocity, as well as how to maximize speed with respect to the angle.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the differentiation of the distance function to find velocity and question the treatment of the angle as a constant. There are attempts to clarify the distinction between speed and velocity, and some participants suggest re-evaluating the approach to maximizing speed based on the angle.
There is an ongoing examination of the differentiation process and the implications of treating the angle as constant. Some participants have provided guidance on correcting the differentiation and understanding the relationship between speed and velocity. Multiple interpretations of the problem are being explored, particularly regarding the correct approach to finding the maximum speed.
Participants are working within the constraints of a homework assignment, which may limit the information available and the methods they can use. There is an emphasis on understanding rather than simply arriving at a solution.
Tony Zalles
Hi,
Ok I'm havin troubles trying to solve this calculus problem.
-Rolling a Ball Bearing-
A ball bearing is placed on an incline plane and begins to roll. The angle of elevation of the plane is θ.
The distance (in meters) the ball bearing rolls in t seconds is
s(t) = 4.9(sin θ)t^2
a. Determine the speed of the ball bearing.
b. What value of θ will produce the maximum speed at a particular time.
Ok so here is how I "tackled" the problem.
ok part a, asks for speed so I take the derivative of the function to get velocity.
v(t) = (0)(sin θ)(t^2) + (4.9)(cos θ)(t^2) + (4.9)(sin θ)(2t)
v(t) = 4.9(t^2)(cos θ) + (9.8t)(sin θ)
ok now from here I'm not sure if my next steps are right...
Ok since they asked for the speed, I'm assuming they want an actual value...versus what I have thus far...
ok now setting what I have for v(t) to zero, I solve for t,
thus I get: t = -2tan θ
Now I take that value and put it back into my original equation.
Now I have s(t) = 4.9(sin θ)(-2tan θ)^2
Now I solve for θ, by setting s(t) equal to zero.
but I end up with this...
4 = (cos θ)^2, and I don't think this is the right answer...
So any help on this would be nice,
Thanks.
In particular, you're taking the derivative with respect to t.
θ is a constant with respect to t... try to differentiate again.
Nope. Aside from your mistake, they want what you had.
Why set v(t) to 0? You're trying to maximize v(t) with respect to θ, right? You want to set zero equal to the derivative of v(t) with respect to θ.
θ is a constant with respect to t... try to differentiate again..
hmn...yea actually right after I posted, I wondered if I was differentiating wrong.
Ok so the correct differentiation should be as follows.
v(t) = 9.8(cos θ)(sin θ)t
therefore that's part A right there.
Part B than should be the derivative of part A, set equal to zero.
Code:
a(t) = (sin θ)(cos θ)
   0 = (sin θ)(cos θ)
   θ = 45 Degrees
Ok, I hope i got it right this time.
Thanks,
Your derivative is still wrong... try writing out all of the steps (like you did when you first learned derivatives) and maybe you'll see your mistake... or at least I'll be able to see what you did wrong when you post it.
For the first part of this problem θ is CONSTANT. What is the derivative of at2? Now replace a with 4.9cos(θ).
After you have that velocity (at any time t), you want to start thinking "what would happen if we changed θ?". Specifically, what value of θ gives the maximum velocity. Now t is fixed and θ is the variable!
Well, your first mistake is using the velocity function as your speed function. Velocity IS NOT the same as speed. Speed is the magnitude of velocity. You should probably fix that first. Everything else will fall into place as you go along.
Welcome to Physics Forums :smile:
Hopefully Tony Zalles is not still working on this problem after more than 6 years. However, note that the ball simply moves down the slope (starting from rest) without reversing direction. So the speed-velocity distinction is not important here.
  • · Replies 24 ·
  • · Replies 38 ·
  • · Replies 18 ·
