Unable to display LaTeX
  • Thread starter Thread starter Brian_D
The discussion centers on a technical issue with displaying LaTeX code on PhysicsForums. A user is unable to see a proper preview of their LaTeX expression and only sees the code instead. It is clarified that enclosing the LaTeX in double-$ delimiters is necessary for proper display. Additionally, a reminder is given that the imaginary unit should be represented as a lowercase 'i' rather than an uppercase 'I'. The conversation highlights the importance of formatting in LaTeX for successful rendering.
Brian_D
Homework Statement: Not applicable. I'm asking about a technical problem with the PhysicsForums software
Relevant Equations: \left(-2+2 \,\mathrm{I}\right)^{\frac{1}{3}}
I posted the LaTeX code for an expression in the "relevant equations" and "attempt at a solution" boxes. When I'm in the "attempt at a solution" box and I click "Preview," I do not see a preview of the expression properly displayed, only the code. After I post this message, the expression may be properly displayed, but I need to use the preview feature to clean up my code if necessary before posting. I am using an HP Envy x360 Laptop and Windows 11 Home version 24H2. Any thoughts how to fix this problem?
P.S. I mentioned this problem previously and someone said I need to refresh the page. But when I hit "refresh," it erases everything.
Testing:
$$\left(-2+2 \,\mathrm{I}\right)^{\frac{1}{3}}$$
Works for me as long as I enclose the LaTeX in double-$ delimiters front and back.
Yes! I was missing the double $ delimiters. Thank you, berkeman. :-)
Likes Greg Bernhardt and berkeman
Glad to help. Remember that double-$ delimiters are for stand-alone lines of LaTeX, and double-# delimiters are used with in-line LaTeX.
Thank you.
Minor nit -- the character that represents the imaginary unit is always written as i (lower case), not I (upper case).
Thank you.
@Greg Bernhardt , @berkeman
What happened here? LaTeX did not render in an unsorted list!
Greg Bernhardt said:
Where is "here"?
But I removed the list tags after they didn't work and replaced them with empty lines.
My guess is that list tags (BBCode?) don't play well with LaTeX code.
  • · Replies 29 ·
  • · Replies 105 ·
  • · Replies 22 ·
