Automotive Why Do BMW Engines Suffer from Rod Bearing Issues?
BMW engines, particularly the S54, S65, and S85 models, are known for rod bearing issues, with several potential causes discussed. Key factors include infrequent oil changes, the use of inadequate oil, and tight engine tolerances that may not suit the recommended 10W60 oil. Crankshaft alignment problems and metal fatigue are also mentioned as contributing factors. Regular maintenance, including timely oil changes and bearing replacements, is emphasized as crucial to prevent failures. The discussion seeks insights from mechanical engineering enthusiasts to better understand and address these issues.
petrolhead47
TL;DR
BMW Engine and their problems
Hi i Have a question about bmw's engine. Everyone knows thats engine this company have a rod bearings problem. But nobody excatly know why is that? In Web we can search lot of reason.
1. Bad oil and too rarely change. BMW recommend 10W60 and perhaps it is a thick oil and when it's cold start the bearing runs without lubrication.
2. There are tight engine tolerance between the shaft journal and the bearing, But in my opinion there isn't a true because 10W60 for tight tolerance ?
3. Lot of things that crankshaft are crooked.
So i don't know what is the problem ? You are a mechanical engiinering and maybe knows answer ? how avoid problem or
how to service such an engine?
I’m not an expert but it looks like you pretty much answered your own question:
Frequent and regular oil changes. Avoid subpar oil.
Avoid too high pressure, load and beware metal fatigue.
Perhaps better quality bearings?
Lots of suggestions out there…
Maybe you are referring to the S65 engine (E90/E92/E93 M3), S85 engine (E60 M5, E63 M6), and S54 engine (E46 M3), which are prone to rod bearing problems. Which engine do you have?
Always warm the engine before working it hard.
Use oil of the recommended grade.
Change the engine oil regularly, more often than recommended.
Do not wait for a mechanical failure, replace the bearings on a regular basis.
Baluncore said:
Być może masz na myśli silnik S65 (E90/E92/E93 M3), silnik S85 (E60 M5, E63 M6) i silnik S54 (E46 M3), które są podatne na problemy z panewkami korbowymi. Który silnik posiadasz?
Zawsze rozgrzewaj silnik przed ciężką pracą.
Stosuj olej o zalecanej klasie.
Wymieniaj olej silnikowy regularnie, częściej niż jest to zalecane.
Nie czekaj na awarię mechaniczną, wymieniaj łożyska regularnie.
BMW's engine specially MPower have a rod bearing problems. For example S54, S65,S85.S55 etc. In the internet can read about suggestion which i include in my first post but neither suggestion is confirmed for sure. So that's why i insert my post here because there are lots of people who like mechanical engineering or maybe deisgn a combustion engine and help me solved my question. Maybe there are a people who analys the bmw's engine ?
Number one way to ruin a rod bearing is to spin up the engine to high RPM before the oil is warm. Let the engine temperature rise to normal operating temperature before getting into the throttle.
The S65 Con rod Bearing clearance tolerance (set by BMW) is 0.027 - 0.076mm ( 0.001" to 0.003"). There is a general consensus that the S65 (and S85) BMW Bearings have 'tight' clearances as well as the possibility of the engine(s) having a bad luck 'tolerance stack' assembly process. This is the typical USA Small Block Chevy, Ford Mopar clearance.
In my research for BMW con rod problems I found this. The stock bearing clearances were too tight at .001”. The industry recommended standard is .0025”. The clearance of .001” is too small to allow for proper lubrication of the bearings. In addition, the side clearance allowed for the crankshaft rod bearing journals is too narrow and impedes allowable expansion of the components due to heat. This is witnessed on the engine bearings having bluish/purplish heat plumes extending inwards from the sides of the rod bearings and heat discoloration on the bearing rod ends. The general consensus is to replace the rod bearings at 60,000 miles with special coated bearing to help alleviate friction issues and improved handling of the heat caused by expansion and the resulting increased friction. Recommendation is for removing the engine and regrinding the crankshaft to allow for thicker bearings and improved clearance. This is the only way to guarantee S65 and S85 engine longevity. Unfortunately, this can be cost prohibitive $$$
You have got to change oil per factory recommendations. The oil passages are a lot smaller than in the old cast iron blocks and any sludge build up is an engine killer.
Factors That Accelerate Bearing Wear​
1. Using Sub-Par Oil​
Zinc dialkyldithiophosphates (ZDDP) are vital oil additives. They create a sacrificial protective layer under high temperature and pressure, reducing metal-to-metal contact.
These engines were designed when API SL oils, rich in ZDDP, were common. But after 2005, oils changed to protect catalytic converters and O2 sensors. Phosphorus levels dropped, weakening the ZDDP barrier. If oil runs past its protection point, bearings quickly suffer.
Even BMW’s recommended Castrol 10W-60 oil has been reformulated over the years. While once ideal, today’s blends shear down into thinner viscosities long before the 15,000-mile service interval.
2. Outdated Manufacturer Service Intervals​
BMW originally recommended 15,000-mile oil changes using LL-01-approved oils. Modern SM, SN, and SN+ oils limit phosphorus content to under 800ppm, reducing protection. Combined with long intervals, this approach accelerates wear.
In reality, Castrol 10W-60 and newer Shell TwinPower 10W-60 oils shear down quickly. Many experts now recommend a high-quality 5W-50 oil, like Torco SR-1R or SR-5R, which maintains proper viscosity throughout the service life.
Recommended BMW Rod Bearing Maintenance​
To protect your BMW rod bearings, we suggest:
  • Oil Change Intervals: Every 5,000 miles for track-driven cars; every 7,500–10,000 miles for daily-driven cars.
Assume that a 100m long (probably irrelevant) train travelling at 30m/s, with a mass of 100.000 Kg passes next to a man/woman of 100 Kg standing still at 1 m away from the track. Since air is massively displaced by the train, creating like a small vacuum/low pressure area next to its surface, I reckon a certain pull may be applied to anything the train passes by, so in this case a person. My question is very simple: this pull can be quantified by a force. Is this force enough to pull the...
10K
  • · Replies 80 ·
68K
