wolram
Dearly Missed
- 4,446
- 558
What is the golden rule for torquing nuts and bolts?
wolram said:What is the golden rule for torquing nuts and bolts?
Danger said:Wow! Awesome post, Bystander. I never saw that stuff before.
I just noticed that I used stupid phraseology there. I did not mean that it's safe as in "it won't come apart"; I meant that there's little chance of damaging the bolt or nut or stripping the threads of the component. Sorry if there was any misunderstanding.Danger said:There is no substitute for followng the manual, but wrist-tight is always safe.
Torque is the measure of rotational force applied to an object, and it is important when tightening nuts and bolts because it ensures that the fastener is securely tightened to the appropriate level, preventing it from coming loose or breaking.
The golden rule for torquing nuts and bolts is to tighten them to the specified torque value recommended by the manufacturer. This ensures that the fastener is tightened to the appropriate level without being over-tightened, which can cause damage.
The correct torque value can usually be found in the manufacturer's manual or by contacting the manufacturer directly. It is important to use the specified torque value for the specific nut and bolt, as different sizes and materials may require different torque levels.
Yes, it is highly recommended to use a torque wrench when tightening nuts and bolts. This ensures that the specified torque value is accurately applied, as using other methods such as a regular wrench or impact gun may result in over-tightening.
It is not recommended to reuse a nut and bolt that has already been torqued. Repeatedly tightening and loosening a fastener can affect its integrity and may lead to failure. It is best to use a new nut and bolt when possible.
