GRE Question (QM, Perturbation theory?)
In summary, the ground state energy is increased when a small bulge is introduced in the potential energy.
HungryChemist
143
Initially, you have a one dimensional square well potential with infinitely high potential fixed at x = 0 and x = a. In the lowest energy state, the wave function is proportional to sin (kx). If the potential is altered slightly by introducing a small bulge(symmetric about x = a/2) in the middle, which of the following is true of the ground state?
a. The energy of the ground state remains unchanged.
b. The energy of the ground state is increased.
c. The energy of the ground state is decreased.
d. The original ground state splits into two states of lower energy
e. the original ground state splits into two states of higher energy
This has to do with perturbation theory but I am not sure. Since this is GRE question, I am guessing there must be a cleaver way of solving this problem rather than solving the Schrödinger's equation.
I eliminated a, d, and e so far and left with b and c as candidates. I thought that to introduce a new potential to a system( however small) requires certain amount of work which then will increase the energy of system. So, I would go for the choice b as a final answer. But then, I wouldn't be surprise if I am entirely wrong. Can someone help?
Do you know the formula (from what is called "Rayleigh-Schrodinger" or "stationary state" perturbation theory) for the first-order change in an energy eigenvalue due to a small change in the hamiltonian?
I looked them up just now, but it seems quiet handful of mathematics involved and I wish to postpone studying them formally when my course get there. However now, I am looking for some quick guidance to solve this problem (since this is GRE problem, you've got a minute and a half to solve). Am I being too optimistic?
No. You don't need to do a computation. The relevant formula is
[tex]\Delta E_n = \langle \psi_n | \Delta H | \psi_n \rangle[/tex]
where [tex]|\psi_n\rangle[/tex] is the unperturbed eigenstate. So, what does this formula reduce to (in terms of an integral over x) in the case that the change in the hamiltonian is a positive change in the potential energy V(x)? What does this tell you about the sign of [tex]\Delta E_n[/tex]? (Note: I am assuming that the "small bulge" represents a local increase in the potential energy.)
1. What is the GRE Question on QM and Perturbation theory?
The GRE Question on QM and Perturbation theory is a question that tests your understanding of quantum mechanics and perturbation theory, which are both fundamental concepts in physics. It may involve solving equations, interpreting diagrams, or applying theoretical principles.
2. How important is it to study QM and Perturbation theory for the GRE?
Studying QM and Perturbation theory is crucial for the GRE, as these concepts are often tested in the Physics subject test. Having a strong understanding of these topics can significantly improve your score on the exam.
3. What is the best way to prepare for the GRE Question on QM and Perturbation theory?
The best way to prepare for this question is to review your notes and textbooks on quantum mechanics and perturbation theory. Practice solving problems and familiarize yourself with common equations and principles. You can also find GRE practice questions online to help you prepare.
4. Are there any common mistakes to avoid when answering this question?
Some common mistakes to avoid when answering this question include not fully understanding the concepts, rushing through the problem, and not showing your work. It is essential to carefully read the question and understand what is being asked before attempting to solve it.
5. Can I use a calculator to solve the GRE Question on QM and Perturbation theory?
No, the GRE Physics subject test does not allow the use of a calculator. Therefore, you must be familiar with solving equations by hand and using mental math to answer questions on this subject.
