Horizontal and vertical lines - star
In summary, the horizontal and vertical stripes of lights seen when looking at a light source are caused by diffraction spikes, which are a lens flare effect. These spikes are created by the spider supporting the secondary mirror in a telescope or by the aperture blades in a camera. They can also be caused by a thin layer of water on the lens. The number and orientation of the spikes depend on the design of the instrument.
Une-V
Hi all,
I'm wondering why we see those horizontal and vertical stripes of lights when looking at a light source (see e.g. http://apod.nasa.gov/apod/image/0601/pleiades_gendler_big.jpg" ). Why are these lines of light present in the first place and why are they only horizontal and vertical in the second place?
Thanks,
Jeroen
They are caused by the spider supporting the secondary mirror.
They tend to be a aligned horizontally/vertically because:
The engineer designed the secondary support that way
The bolt holes for the camera are also horizontal
The astronomers are used to it and will call the tech out in the middle of the night if they aren't aligned like that
The only sensible reason I can think of is that CCDs can create horizontal and vertical streaks from very bright objects, by orientating the detector this way you only lose one set of pixels.
With a camera mounted on an alt-az telescope you have to be able to rotate the camera as the field rotates when the telescope tracks and so you can set the camera up so the spikes are in any orientation - ideally so they don't hit a faint object near a bright one.
Sometimes they are even put in for aesthetics. My telescope doesn't have spider vanes to support the secondary, so my pictures don't normally have diffraction spikes in them. So when I take pictures of certain objects where I want to see them (open clusters and nebulae with bright stars, mostly), I cause the spikes myself by stringing a couple of pieces of thread across the objective of my scope. For example:
http://www.russsscope.net/images/Beehive-3-30-07.jpg
I also notice that I sometimes get a similar effect when looking at lights after wiping off my glasses, only there tends to be more like 6 spikes instead of 4. Since my glasses don't have a secondary mirror to support, what causes this? Is it because I've smeared a film of whatever oil and gunk was on my glasses over them? And any guesses on how this diffraction works?
Yes, it works exactly the same way.
Probably the easiest way to visualize it is to look at what gentle waves on a lake do to a light source like the sun or moon. They http://farm1.static.flickr.com/176/411409117_6ba4fffd63.jpg" that is basically perpendicular to the wave crests. If the "waves" are small enough (such as streaks on glass) and are oriented in several different directions (say, by vigorous wiping) then the lines will look like corresponding spikes.
One also gets diffraction spikes in photography (especially night photography), by diffraction off of the aperture blades. Typically there are six blades, and you get 6-pointed stars as in this example:
http://www.pbase.com/frida_87/image/88315282
Some nicer lenses have 7, 8, or 9 blades (where odd numbers are especially favorable). For an aperture of N blades, you will get N diffraction spikes if N is even, but 2N spikes if N is odd. Therefore, a 7- or 9-bladed aperture makes very brilliant star shapes.
Heh. Just yesterday while watching an ad, I made my wife roll her eyes at my geekiness. The background of the ad was a Christmas light display but out-of-focus. All the little lights had been blurred from pinpoints out into perfect 7-sided polygons, showing that the lens iris was 7-bladed.
My bare eyes also have those spikes, only 4, when I look to some street lights from my window. They are not vertical and horizontal, and not perpendicular either. When I turn my head, they also turn. It may have something to do with thin layer of water on the lens.
1. What is a horizontal line?
A horizontal line is a straight line that is parallel to the horizon or the ground. It does not have any slope and is always at the same level. In geometry, a horizontal line is represented by the equation y = c, where c is a constant.
2. How can you identify a horizontal line on a graph?
A horizontal line on a graph has a slope of 0 and is parallel to the x-axis. This means that all the points on the line have the same y-coordinate, while the x-coordinate can vary. Visually, it appears as a straight line that runs from left to right.
3. What is a vertical line?
A vertical line is a straight line that is perpendicular to the horizon or the ground. It has an undefined slope and is always at the same x-coordinate. In geometry, a vertical line is represented by the equation x = c, where c is a constant.
4. How can you identify a vertical line on a graph?
A vertical line on a graph has an undefined slope and is parallel to the y-axis. This means that all the points on the line have the same x-coordinate, while the y-coordinate can vary. Visually, it appears as a straight line that runs from top to bottom.
5. What is the significance of horizontal and vertical lines in geometry?
Horizontal and vertical lines are important concepts in geometry as they form the basis of understanding coordinate systems and graphing. They also play a crucial role in understanding the slope of a line and its relationship with other lines. In real-life applications, horizontal and vertical lines can represent various physical elements such as the horizon, buildings, or walls.
  • STEM Educators and Teaching
  • Astronomy and Astrophysics
  • Other Physics Topics
