Little problem with group velocity
In summary, the conversation discusses the group velocity of an electromagnetic (EM) wave transform in special relativity, and its relation to the velocity of a particle with mass. The wave 4-vector is a tensor and the dispersion relation for waves of this type can be derived. The group velocity four-vector is parallel to the wave 4-vector and the relationship between group and phase velocity can be written. This argument also supports the concept of identifying massive particles with waves obeying special relativity.
ziojoe
I have a little trouble in demonstrating that the group velocity of an e.m. wave transform (in special relativity, by passing from an inertial frame to another) like the velocity of a particle with mass.
So, [tex] \left( \frac{w}{c}, k_x, k_y, k_z\right) = \left( \frac{w}{c}, \vec k \ \right)[/tex] is a 4-vector, where [tex]w[/tex] is [tex]2\pi\nu[/tex] and [tex]\vec k[/tex] is the wave vector. So, if another inertial frame moves with velocity [tex]v[/tex] in the direction of the [tex]x[/tex] axis, we have
[tex]\gamma = \left(1 - \frac{v^2}{c^2}\right)^{-\frac{1}{2}}[/tex]
[tex]dw' = \gamma\left(dw-v\cdot dk_x\right)[/tex]
[tex]dk_x' = \gamma\left(dk_x-\frac{v}{c^2}dw\right)[/tex]
[tex]dk_y' = dk_y[/tex]
Let be [tex]u_x = \frac{dw}{dk_x}[/tex], [tex]u_y = \frac{dw}{dk_y}[/tex].
So, I find [tex]u_x' = \frac{dw'}{dk_x'} = \frac{u_x-v}{1-\frac{v\cdot u_x}{c^2}}[/tex] (correct, because it's the same transformation for the velocity in [tex]x[/tex] of a particle with mass), and
[tex]u_y' = \frac{dw'}{dk_y'} = \gamma\frac{dw-v\cdot dk_x}{dk_y} = \gamma\left(u_y-\frac{dk_x}{dk_y}\cdot v\right) = \gamma\left( u_y-v\cdot\frac{dw}{dk_y}\cdot\frac{1}{\frac{dw}{dk_x}}\right) = \gamma\left(u_y-v\cdot u_y\cdot\frac{1}{u_x}\right) = \gamma\cdot u_y\left(1-\frac{v}{u_x}\right)[/tex]
But this is different from the relationship for particle with mass velocity, that is
[tex]u_y' = \frac{u_y}{\gamma\cdot \left(1-v\cdot\frac{u_x}{c^2}\right)}[/tex]
Where's the problem with this derivation? How can I find the right relationship?
Maybe the problem is with the fact that I should do the partial derivation
[tex]u = \frac{\partial w}{\partial \vec k}[/tex]
(I know the transform must be the same for group velocity of an e.m. wave AND for velocity of particles with mass). Please, if you can, show the passages of the derivation.
Firstly, to clarify, the vacuum group velocity of EM waves is c, which is *not* like the velocity of a particle with mass.
You can see that the wave 4-vector is a tensor (in SR) just by recognising that gWx (the phase difference between two events on a wave) is a scalar (while the displacement x and inner product g are both also tensors); W must be contravariant (same as velocity dx/dl) since that equation is valid in all frames.
Hence, gWW (=b) is a constant in all reference frames (although frequency and wave-vector components are not constant, in fact this equation gives you the dispersion relation for waves of this "type", that is, waves that are related by the symmetry of SR). From this you can write the relation between group and phase velocity (they will be inverse fractions of c). Then by simple geometry you can recognise that the group velocity four-vector is parallel to W. QED (and moreover, if you wish to identify massive particles with waves obeying SR then you have proven E=-ih(d/dt) and p=-ih(d/dx) for some constant h, which is of course the basis of QM).
This argument is sketched at the beginning of some QFT texts.
The problem with this derivation is that it assumes that the group velocity of an electromagnetic wave is equivalent to the velocity of a particle with mass. This is not necessarily true. The group velocity of an electromagnetic wave is a property of the wave itself and is not related to the velocity of a particle. The group velocity represents the speed at which the overall shape or envelope of the wave moves, while the phase velocity represents the speed at which the individual wave peaks move. Therefore, the group velocity cannot be directly compared to the velocity of a particle with mass.
To find the correct relationship, you can start by considering the transformation equations for the phase velocity of an electromagnetic wave. These are given by:
u_x' = \frac{u_x-v}{1-\frac{v\cdot u_x}{c^2}}
where u_x and u_y are the phase velocities in the x and y directions, respectively, and u_x' and u_y' are the transformed phase velocities in the new frame.
To relate this to the group velocity, you can use the relationship between the group velocity and the phase velocity:
v_g = \frac{d\omega}{dk}
where v_g is the group velocity, \omega is the angular frequency, and k is the wave vector. In this case, you can use the transformed values of \omega and k to find the transformed group velocity. This will give you the correct relationship between the group velocity in the two frames.
In summary, the group velocity of an electromagnetic wave cannot be directly compared to the velocity of a particle with mass. To find the correct relationship, you need to consider the transformation equations for the phase velocity and use the relationship between the group velocity and the phase velocity.
1. What is group velocity?
Group velocity is a measure of the speed at which a group of waves or particles travels. It is different from the phase velocity, which is the speed of an individual wave or particle within the group.
2. How is group velocity different from phase velocity?
Group velocity and phase velocity are two different measures of speed for a group of waves or particles. Group velocity takes into account the motion of the entire group, while phase velocity only looks at the speed of an individual wave or particle within the group.
3. What causes a little problem with group velocity?
The little problem with group velocity refers to a phenomenon where the group velocity of a wave or particle exceeds the speed of light. This is only possible in certain situations, such as when the group is made up of different frequencies or when it interacts with a medium.
4. How is group velocity calculated?
Group velocity is typically calculated by taking the derivative of the dispersion relation, which is a mathematical equation that relates frequency and wavenumber. This calculation can vary depending on the specific system or medium being studied.
5. Why is group velocity important in physics?
Group velocity is an important concept in physics because it helps us understand the behavior of waves and particles in various systems. It can also provide insight into phenomena such as dispersion, which is the spreading of a wave as it travels through a medium.
