mitchell porter
- 653
I want to make a self-indulgent post about three papers that came out on the arxiv today. It's self-indulgent because there's no obvious logical connection between the three papers, but I want to muse aloud about their meaning and see what I can find.
The three papers are http://arxiv.org/abs/1105.5632" [Broken], author of the fuzzball model of black hole microstates. As I will explain, although the papers are on three different topics, the first two do have a potential connection, by way of twistor string theory. Mathur's doesn't fit that template, so for now I'll just consider it a reminder that string theory still doesn't have a completely transparent model of black hole microstates, and we'll see if, by the end, it naturally reenters the discussion.
Let's start with Maldacena's paper. In my mind, Maldacena has taken Witten's place as the leader in theoretical physics. The idea that theoretical physics has a leader is itself dubious, but here's the pragmatic meaning I associate with the title: There was a time when the simplest way to keep track of theoretical advances was just to read Witten's papers. Even if Witten didn't originate something, any important development would still show up in his papers, described lucidly and insightfully. But now, if I had to specify one person to read, it would be Maldacena. Maldacena's corpus and Witten's corpus are quite different; for example, Maldacena's papers are mostly about AdS/CFT. But I think this reflects the evolving state of theoretical physics. I'd say that when Witten entered the field, the theoretical kingpin was Gerard 't Hooft, for the role he played in making the standard model viable. Then Witten was the dominant figure during the long period of speculative theoretical development which took us from the standard model to M-theory. And now Maldacena's big discovery dominates the agenda in the era of M-theory.
So I am naturally disposed to treat a Maldacena paper as a big event, or at least as worthy of intensive study, for clues regarding where we are and where we're headed in theoretical physics. What does this new paper contain? By my reckoning, there's a clarifying technical advance, an intimation of expected future progress, and something big that I don't understand.
The clarifying technical advance is the observation that "conformal gravity", with the boundary condition "no ghosts in the future", reduces to "Einstein gravity". It's somewhat alarming to see how many different theories of gravity exist in the literature, so it's useful to be told that two of them are this tightly connected, it reduces the chaos a little.
The intimation of expected future progress is: everything in the paper that concerns gravity in de Sitter space. One consequence of AdS/CFT is that it has made quantum gravity in anti de Sitter space, if not a solved problem, a problem in which progress is largely a matter of making an effort. But de Sitter space is both an unsolved problem and far more relevant to the real world, at least cosmologically. This paper, however, contains a number of new results, building on http://arxiv.org/abs/astro-ph/0210603" [Broken] from 2002. This encourages me to think that quantum gravity in de Sitter space will one day be as "solved" as AdS now is: there will be a consensus on how to think about it, and a consistent body of results and techniques to apply.
Something big that I don't understand: this is part 6 of the paper. That one type of gravity (conformal) should reduce to another (Einstein) in the same dimension, it's interesting but it's easy to understand, no more challenging conceptually than a change of variables. But to be told that 4-dimensional conformal gravity describes something about gravity in 5-dimensional de Sitter space - it's confusing, it sounds important, it even sounds important because it's confusing. I definitely know that I don't understand what's at work here, and so the payoff for actually getting to the bottom of it is unknown.
One reason it's confusing is that, if you're used to AdS/CFT, you're used to gravity in one dimension being related to a non-gravitational theory in a lower dimension. That this is a gravity-gravity relationship is mystifyingly novel.
Now here I want to mention a few other curious assertions I've seen in the literature, which I think are clues as to what's going on here. That is, in trying to understand the bigger picture, I would be revisiting these other papers for guidance. The first comes from that 2002 paper by Maldacena, which is also about the relationship between dS and AdS. In section 5, he mentions a difference in how dS/CFT works for dS4 and dS5: "the nonlocal piece in the wavefunction which determines the stress tensor seems unrelated to the local piece which determines the expectation value of the fluctuations. In other words, dS5/CFT4 would tell us how to compute the non-local piece in the wavefunction but will give us no information on the local piece." There's a special property here, of gravity in 5-dimensional de Sitter space, which I just bet is related to this new oddity whereby there's also a connection to 4-dimensional conformal gravity.
My next two clues bring us to Simon Caron-Huot's paper, which is part of the big attempt to completely solve N=4 super-Yang-Mills. This is the field theory which figured in the original AdS/CFT duality, but AdS space isn't playing much of a role in his discussion. Nonetheless, let me mention my "clues". First, a handful of recent papers using the Goncharov symbol technique to compute correlation functions in 6-dimensional Yang-Mills theory - see citations 52 to 55 in Caron-Huot. These six-dimensional quantities apparently have very immediate relationships to the four-dimensional theory.
My other clue was something I found in http://arxiv.org/abs/alg-geom/9601021" [Broken]. Start with section 1.1. Here I summarize something I don't really understand, but I'll state the gist as I see it: Hyperbolic spaces are highly rigid, their volumes are transcendental numbers obtained from polylogarithms, and the odd-dimensional case is far more complex and interesting than the even-dimensional case. In odd dimensions, the rigidity implies strong and nontrivial constraints on how a hyperbolic space can be chopped up and reassembled, and these constraints in fact define an algebra which is a "motivic cohomology".
Referring to my earlier post about https://www.physicsforums.com/showthread.php?t=490749", I'll point out two things: formulae in N=4 Yang-Mills which evaluate to combinations of polylogarithms, and formulae which evaluate to a surface area in anti de Sitter space. I believe that these pure-math observations by Goncharov must lie at the root of this conjunction. AdS space emerges as the space of energy scales for a field theory (the domain of RG flow, for a non-conformal theory), certain amplitudes are given by volumes in AdS space, and volumes in AdS space are polylogarithms featuring in a combinatorial motivic algebra. It's obvious that it must all cohere somehow, but the details escape me, and it sounds like even the experts haven't got it straight yet.
But if we can return to this phenomenon of crossovers between 4, 5 and 6 dimensions, occurring in Maldacena's paper, Caron-Huot's paper, and the recent papers employing the Goncharov symbol technique, it seems likely that the "crossover phenomenon" is also related to the "motivic synthesis". Also, I should mention that N=4 Yang-Mills is the worldvolume theory of a stack of D3-branes, and D3-branes are actually M5-branes with two dimensions compactified, and there is a big body of work (by Gaiotto and others) on the 4-dimensional theories resulting from the compactification of the 6-dimensional worldvolume theory of M5-branes. (Another reminder: this theory is dual to M-theory on AdS7 x S4.) There are papers by Witten in which this 6d to 4d reduction is associated to the Langlands program. There is a paper by Weinberg, cited by Caron-Huot, in which a 6d formalism is developed for employment in 4 dimensions. The more of these facts that I list, the more obvious it becomes that there is an enormous coherent synthesis to be unearthed here, much of which would already be evident to these authors. The challenge for outsiders is to crack enough of the code to understand what is already being said and, more importantly, being presupposed, in these papers written by one expert for their colleagues.
I think all of that is what I really needed to say. I've been seeing these connections build and build and build without knowing how to organize them. I still don't, but, at least the problem is now in the open! The challenge is to find the important clarifying insights which will organize this mess of data and discoveries, and allow one to see the essence of what is at work here.
I'll return to the actual content of Caron-Huot's paper later on, I think. And I haven't forgotten Mathur. I want his work to stand as a reminder that a lot of the stringy discussion of black holes (in AdS spaces and elsewhere) is still very heuristic in nature. But the microscopic description of black holes in AdS space is one of the things which, in time, AdS/CFT ought to provide us with. And in turn that should tell us how black holes work in dS/CFT, and thus in the real world. In the application of AdS/CFT to quark-gluon plasmas, one uses a duality between thermal states in a field theory and black holes in AdS space, and so I wonder if all black holes in every dimension can ultimately be understood as a sort of deconfined Yang-Mills plasma. Another aspect of the N=4 revolution is the understanding of gravitational amplitudes as squares of Yang-Mills amplitudes; it goes back to the fact that in string theory, you can understand a closed string (graviton) as two open strings (gauge bosons) joined together. http://arxiv.org/abs/1105.2565" [Broken] was a recent big advance in the sub-sub-field of "relationships between Yang-Mills theory and perturbative gravity". But that really does exhaust my ability to tie this stuff together, for now.
... OK, I see I forgot to mention how twistor string theory fits in. Twistor string theory was where the N=4 revolution got underway: it was the first recent use of twistors to simplify super-Yang-Mills theory. But this original formulation was considered slightly pathological, because it consisted of Yang-Mills coupled to conformal gravity, and conformal gravity is nonunitary. So if Maldacena has discovered how to fix conformal gravity, by imposing these future boundary conditions, then he may also have fixed twistor string theory.
