PatrickPowers
- 240
- 1
When I search for "X Y Z" I get all results that have either X or Y or Z.
Is there any way to find only posts that have X and Y and Z?
The most effective way to search for specific topics in the forums is to use the search bar located at the top of the forum page. Simply enter your keywords or phrases and click on the search button. You can also use advanced search options to narrow down your results.
To search for multiple keywords or phrases in the forums, you can use the Boolean operators "AND" and "OR" in your search query. For example, if you want to search for posts that contain both "X" and "Y", you can type "X AND Y" in the search bar. If you want to search for posts that contain either "X" or "Y", you can type "X OR Y" in the search bar.
Yes, you can filter your search results by date or user by using the advanced search options. You can specify a date range to search within and choose to only see posts from a specific user. This can help you find more relevant and recent information on your desired topic.
Yes, there is a way to search for posts within a specific forum category. You can use the "Forum" drop-down menu in the advanced search options to select the specific category you want to search within. This will help you find posts that are more relevant to your search query.
You can search for posts that have been marked as "solved" in the forums by using the "Solved" drop-down menu in the advanced search options. This will filter your search results to only show posts that have been marked as solved by the original poster or a forum moderator.
