EPR Debate: Nature Agrees with Einstein
  • Thread starter JohnBarchak
  • Tags
    Epr
In summary: It appears that Nature agrees with Einstein.In summary, Nature agrees with Einstein that the measurement of one photon affects the polarization of the other.
  • #36
DrChinese said:
... if you can get classical optics to yield a different prediction for Aspect-like correlation percentages, go for it.
See Appendix C of my paper at http://arxiv.org/abs/quant-ph/9903066. The basic LR (classical optics) prediction is in fact very close to Aspect's raw data, not adjusted by subtraction of accidentals, at least in his first experiment. It differs markedly from the quantum theoretical prediction and from the published (adjusted) data, but, as you may have realized, I and other local realists challenge the legitimacy of the subtraction. As far as I know, even quantum theorists (in particular, Wolfgang Tittel and his team at Geneva) now agree with me.
None of the above affects the fact that all extant tests support the predictions of QM, or that the QM formula [tex]cos^2[/tex] is the same applied in classical optics in cases in which polarized light is passed through a second polarizer.
Right, but this is for two polarisers "in series". In the Bell test experiments we have two polarisers "in parallel". It is only in the very special case when all the light is polarised in the same direction that classical optics and QM agree.
As to who originally pointed out that LR and classical optics were at odds, I see that as being Bell. Before Bell, the LR prediction was [tex]cos^2[/tex] matching classical optics. After Bell, the LR predicted value changed (to something that no LRist is willing to stand behind).
No DrChinese, I'm afraid you've got this all wrong! I don't know what makes you think classical optics is not a LR theory. Bell originally talked only of spin-1/2 particles, not light, so naturally the local realist model he considered was slightly different from the one applicable to light. He assumed, for instance, that when a particle is detected, it must be + or - (though later he added the possibility of zero). It could never be "both + and -". In classical optics, both + and - simultaneously is perfectly possible.
It might help if you checked out my wikipedia page on hidden variable theories: http://en.wikipedia.org/wiki/Local_hidden_variable_theory
The basic LR theory for Bell's spin-1/2 particles yields a zig-zag prediction, whilst the basic one for an experiment using polarised light yields a sine curve but shifted upwards, so that it no longer has full visibility.
Caroline
http://freespace.virgin.net/ch.thompson1/
  • #37
Caroline Thompson said:
1. Right, but this is for two polarisers "in series". In the Bell test experiments we have two polarisers "in parallel". It is only in the very special case when all the light is polarised in the same direction that classical optics and QM agree.
2. No DrChinese, I'm afraid you've got this all wrong! I don't know what makes you think classical optics is not a LR theory. Bell originally talked only of spin-1/2 particles, not light, so naturally the local realist model he considered was slightly different from the one applicable to light. He assumed, for instance, that when a particle is detected, it must be + or - (though later he added the possibility of zero). It could never be "both + and -". In classical optics, both + and - simultaneously is perfectly possible.
1. In EPR, we use one entangled particle (say the Right) to gain knowledge of the other (say the Left [tex]\theta[/tex]). A measurement of the Right tells us it is polarized at 0 or 90 degrees relative to an arbitrary angle we shall call 0 degrees. Using classical optics, I then use the knowledge I have to predict the likelihood of detection at the other polarizer when the polarization is known:
[tex]P(+,0)=cos^2(\theta)[/tex]
[tex]P(-,0)=sin^(\theta)[/tex]
[tex]P(+,90)=cos^2(90-\theta)[/tex]
[tex]P(-,90)=sin^(90-\theta)[/tex]
Assuming the light is randomly polarized initially so the Right side odds are 50-50, we get:
[tex]P(correlation)=P(+,0)+P(-,90)=.5cos^2(\theta)+.5sin^(90-\theta)=cos^2(\theta)[/tex]
which is also the QM prediction. For [tex]\theta=22.5 degrees, P(correlated)=.8536[/tex].
If you care to make a case that this is not how the rest of the world looks at this problem, by all means, go ahead. To me, it looks like dismissive hand-waving on your part.
2. We know the classical correlation probability of .8536 is what the LR position USED to predict before Bell. After Bell, the new LR value for [tex]\theta=22.5 degrees, P(correlated)=.7500[/tex]. I don't think you will find this value in a lot of old books on Optics. And for that matter, you won't see it in many places today either. In fact, I doubt there are very many people who know where that value even comes from! But the fact is that this is about the highest value you can have for an LR prediction of correlation at 22.5 degrees that is consistent with Bell.
Again, if you can use classical optics to yield ANY other predicted value than the one I have given of .8536, then by all means, go ahead. Just make sure the result is .7500 or less so it can match your LR prediction, and then your point will be made. I have seen your charts on possible values per LR. Simply tell us which one is your prediction and then derive it from classical optics.
(As to your idea that the LR model predicts both + and - cases simultaneously... hey, you are the one that is talking to us about what is REASONABLE and INTUITIVE. And that doesn't sound so reasonable to me. In fact, it sounds like QM weirdness if you think about it :smile: )
  • #38
Sorry, but I'm afraid you've already gone wrong! A single measurement of polarisation does not, in classical theory, tell you what the input polarisation was.
The classical formula, given that the input polarisation was in a random direction, is:
[tex] P_{AB}(a, b) =
\int^{\pi}_0 \frac{d\lambda}{\pi} \cos^2(\lambda - a)\cos^2(\lambda - b)[/tex]
which evaluates to
[tex]\frac{1}{8} + \frac{1}{4} \cos^2 \theta[/tex]
where [tex]\theta = b - a[/tex].
The logic behind this is well known, even to quantum theorists, and reproduced in many papers, including the one I keep referencing, http://arXiv.org/abs/quant-ph/9903066.
... Assuming the light is randomly polarized initially so the Right side odds are 50-50, we get:
No, this is not how to deal with random polarisation directions in classical optics. It's some kind of compromise, influenced by QM thinking and the photon idea. In classical optics the initial beam has a definite polarisation direction, [tex]\lambda[/tex], i.e. it has the very "hidden variable" assumed in all (reasonable) local realist models for optical Bell tests. This is commonly known, reproduced in many texts other than mine.
I'm afraid that, to me, you algebra looks like a quantum-theoretical fudge! :frown:
I have seen your charts on possible values per LR ...
But I have never given any! If you are using anything out of my Chaotic Ball papers then you are using it incorrectly. As I've said before, it illustrates the principle only. As I've also said before (and as you might now better understand, with the aid of the equation above), all that is needed to convert the basic, idealised, local realist (optical) Bell test prediction into one that can have higher "visibility" is to alter the assumed shapes of the functions involved, allowing for the true operating characteristics of the apparatus concerned. There is no need for the model to predict values anywhere near as high as 0.75. The high figure you quote is after "normalisation".
Hmmm ... Well now, possibly (after seeing the equation) you will by now see for yourself why both + and - is perfectly natural, but just in case you don't, consider what happens if you input light polarised at 45 deg to the axes of a 2-channel polariser.
Suppose the initial intensity is I. The intensity in both outputs will then (under the usual assumption of a 50-50 split) be I/2. Assuming "perfect" detectors, giving a count every time for a signal of intensity I and for signals of lesser intensity a count with probability proportional to that intensity, the detector for the + channel has a probability 0.5 of a count and likewise, independently, the - channel. The probability of both at once is 0.25.
Is that so very weird?
You will have noticed, incidentally, that the above depends on a number of assumptions, none of which are absolutely necessary. You can get different answers under different conditions. As has been shown experimentally, when you have very weak light (in QM considered to be "single photon" level), the individual pulses making up the beam may not split 50-50. That, though, is a separate issue, not critical here.
Caroline
  • #39
DrChinese, Caroline
OK I think I’ve spotted where I needed the help.
My analogy does not fit the testing. At least not the testing you all are debating.
Just to be sure I understand the actually tests being do on EPR here.
The simple part A&B we expect the Non-Correlation to be near 0%
When we have testing set up for A, B, & C and of course can only test two at a time.
We still expect A&B Non-Correlation to be near 0% - correct?
But using the LR “C” we expect:
A&C tests and also B&C tests would both have a significant % of Non-Correlation! Plus QM and Non-QM both agree on this.
My analogy would not allow for this expectation of Non-coralation!
Test where A sees polarization of 0 or 90 degrees it would expect B tests correlating 100% when testing 90 degrees off of A’s view. And when testing polarization in B’s area at an angle at 22.5 degrees (I assume half of 45 is used for a reason) we should expect some non-correlation from anybodies view of it of what the LR will see.
Therefore the LR from QM and Non-QM views is NOT expected to be in 100 percent correlation with A. My analogy is not able to represent such an idea.
Maybe I can modify it so that it can – to do so; this is what I don’t know:
What are the predicted results for the amount of “Non-Correlation” both from QM and Non-QM views?
Why are the predictions different?
My guess is that using 45 degrees would predict the same amount of correlation (Also Non-correlation) from QM and Non QM views.
So using 22.5 is somehow important – True?
Thanks RB
  • #40
Thanks RB
Yes, the 22.5 degrees is significant.
As you can see from your example, you are basically using 0 degrees which gives perfect correlations. Guess what? Both the QM and LR interpretations can handle this case equally well. Ditto for 90 degrees. Ditto for 45 degrees (as you guessed above).
For nearly 30 years, no one noticed there was a glaring hole in the logic. Then Bell came along. He noticed that if you use ANY other angles, you start getting significant problems with the LR predictions IF you expected them to yield similar results as QM - as happens for the 0, 45 and 90 degrees cases. It turns out that the deviation hits a maximum at 22.5 degrees and 67.5 degrees. The reason I don't bother with analyzing other cases is that the 22.5 degrees case leads to enough evidence that you can basically ignore all the others.
As a matter of practice, Bell test do actually check a range of angles, more than just the 22.5 degrees case.
  • #41
OK I feel like I’m getting closer.
Testing at 45 will give us sin & cos .707 squared we get .5
22.5 and 67.5 degrees sin & cos gives .38 or .92 squared gives .146 or .854
So I’m jumping to some conclusions in using the squared.
Pythagoras feels right and more important the numbers look right that way.
At 45 degrees Pythagoras would predict 50-50 correlations vs. non-correlations. And at 22.5 degrees it will be .146 vs. .854 odds of correlations vs. non-correlations.
Just guessing again the above odds are Classic expectations (If that’s the correct way to refer to “Non-QM”). And the other expectation (QM?) agrees with it at 50-50.
BUT something about the way QM is defined forces a prediction that does not agree with the 14.6% vs. 85.4% distribution for 22.5 degrees.
This is the key I’d like to understand!
What is that prediction?
And how and why does it’s math come up with different numbers than above?
With luck I have some errors in thinking here, cuss correcting those is how I’ll learn something.
  • #42
RandallB said:
... something about the way QM is defined forces a prediction that does not agree with the 14.6% vs. 85.4% distribution for 22.5 degrees.
As far as I can tell, the QM formula is effectively a lucky guess, the LR one (see my latest message in the thread re negative probabilities) the only logical possibility. I recently copied out Shimony's derivation of the QM formula, for the benefit of wikipedia (see http://en.wikipedia.org/wiki/Quantum_mechanical_Bell_test_prediction). It seemed to me that Malus' Law was just "plucked out of thin air" and assumed to apply to the coincidences. It has only ever been derived experimentally using two polarisers in series, which is logically quite different. [Moreover, it applies to (classical) beam intensities, which will only be proportional to QM's counts if the detectors are ideal ones in that their response probabilities are exactly proportional to the input intensities.]
Caroline
  • #43
As far as I can tell, the QM formula is effectively a lucky guess, ...
ROTFL :rofl:
Funny, I can describe its applicability quite easily:
If the source is randomly polarized, and you know the polarity of any photon on the Right by means of observing its polarization, the probability of any particular polarity being seen on the Left is given by Malus' Law where the angle is the angle in-between.
I have long assumed that the applicability was so obvious that it did not need formal proof in most analyses, it was simply used as a starting point. Even most classical treatments of Bell use the same logic. Correlations are defined by Malus' Law.
  • #44
Caroline & Dr C
I appreciate any extra input – But before I can even evaluate the credibility of a website or see how Malus' Law defines correlations and evaluate that for myself. I’d be lost if I’m not on the right track. So for the following items:
1) Classical View or LC for Local Causes – Is it fair and recognized to use these terms to describe the Non-QM view? That is in principal local causes control or outcomes are predetermined before elements reach test areas. (LR used for Lorentz Relativity by some) Is there even a preference?
2) On 45 Degrees – Am I on track there?? Does both LC and QM predict 50% - 50% or not? It’s just that when I do look around at some of the formulas I see “(1/2)” being included with sin2 – which would give me 25%?
Or is that 25% for each of two permutations out of four which will get me back to 50-50?
3) For 22.5 degrees or 67.5; Am I right is it (1/2) cos2 times 2 permutations is giving a .146 vs. .854 odds of correlations vs. non-correlations.
AND WHO is making this prediction LC or QM (I guessed LC, but …..?)
4) Now what is the other prediction, not results the other prediction?
And How is it arrived at? And if it is QM that does not agree with .146 vs. .854; Is this where I will have no choice but to get familiar with Malus?
Can these be answered without needing me to become an optical, polarization expert to understand the answers?
  • #45
RandallB said:
Caroline & Dr C
2 & 3 - Yes. As to who is making the prediction - it is definitely QM putting forth the .146 and .854 predictions for correlations at 67.5 and 22.5 respectively. Sometimes the LR side tags along, and sometimes it doesn't. :smile:
I don't think you have to be an expert to follow, think you are probably following pretty well. Some of it comes down to opinion or wording anyway.
  • #46
Sometimes the Classical LR Local realist approach predicts the same thing and sometimes they DON'T! ? If we're talking about 22.5 degrees shouldn't that be a big problem!?
Especially when I made my own predications of what I'd think the results should be I thought I was using classical thinking! Based on using polarized light coming through filter at 22.5 degrees diagonal..
But if my classical prediction is simply the same as the QM prediction what good is the testing if it only confirms BOTH predictions. Unless my prediction is faulty and it can be shown that the LR MUST predicate something else – how is the testing useful at all??
Can it be shown the classical thinking MUST predict something else and not just “Tag along" ??
Reviewing my own ‘prediction’ - I can see in a classical sense I was using ‘Wave’ theory not making a prediction for an individual event(s). Is that enough to disqualify the approach I used to make the 'classical' prediction?? AND does (should) the LR predict??
ALSO, since the QM prediction gives the same 'negative' result in statistical math we talked of earlier - why is that acceptable from QM view?
RB
  • #47
DrChinese,
Thanks for your post #355
But I need to ask a question:
Aren't you taking the absense of a measurement and relating that to no photon present?
That's the problem I have with Bell Inequalities. It seems to me they are trying to prove/disprove QM, but then they don't hold to the underlying postivism philosophy when attempting to do that. That philosophy says you gain no information from the absense of a measurement, not that you can assign it a definate outcome .. the inequalities assign it a definate outcome .. in this case a negative/no particle found.
  • #48
Nacho said:
DrChinese,
You have it backwards. Bell sets a requirement for a local realistic theory. There is no requirement for QM, which does not assert that there is the possibility of a more complete specification of the system.
  • #49
RB
Yes, sure, you can make any prediction you want to. It can make it match QM or not. It can match experiment or not. The norm is to have the local realistic (LR) predicition match QM so that it will not be ruled out by an experiment that yields experimental results compatible with QM. To date, all published tests of Bell's Inequalities have matched the QM predictions without exception (although there are those such as Caroline who dispute the validity of the results).
I will repeat: QM itself does NOT lead to negative probabilities. LR does if it matches the predictions of QM. These are two completely different scenarios even though they sound like they are the same. Local reality makes assumptions that QM does not.
  • #50
Maybe I have it backwards .. probably I just didn't go far enough in my question/explanation. I'm really referring to conclusions based on them.
I do believe Bell Inequalties could prove or disprove realism. I believe both it and mathematics are based on the same underlying philosophy. Maybe the Aspect type experiments prove the quantum world doesn't follow realism, sans loopholes.
But, what I was trying to get to across was that some people (not necessarily you) take that conclusion and go too far, to say then that the Universe follows postivism rules and that the Universe is non-local. I don't see how that can be done as the formulization of the inequalities neglects tenants of QM (especially the Copenhagen Interpretation).
  • #51
OK I must be missing something on the assumtions: - before we run a test how can we accept a LR prediction of "anything it wants". We don't need to run a test to reject invalid predictions as we should be able to show a prediction to be invalid, based on the standards of the predicting theroy.
SO predictions are invalid or acceptable based on: -- First let's review:
[1] A+ B+ C+
[2] A+ B+ C-
[3] A+ B- C+
[4] A+ B- C-
[5] A- B+ C+
[6] A- B+ C-
[7] A- B- C+
[8] A- B- C-
Total probability 1.0 100% of 8 permutations
Three tests holding one Variable unknown (??)
Each test 4 permutations for 100%
Predictions: (C using 22.5 Degrees)
Test ?? - Corr - - NonCorr - Predict - BY:
A&B (C) [1,2,7,8] [3,4,5,6] 1.0 0.0 : QM & LR both
A&C (B) [1,3,6,8] [2,4,5,7] .14 .86 : QM ;; LR?
B&C (A) [1,4,5,8] [2,3,6,7] .14 .86 : QM ;; LR?
Statistical Math gives us:
A&B(NonCorr) + A&C(Corr) – B&C(NonCorr) = [1,3,6,8] + [3,4,5,6] - [1,4,5,8]
Result 0.0 + .14 - .86 = [1][3][6][8] + [3][4][5][6] - [1][4][5][8]
[3] [3] [6] [6] = -.72
[3][6]= -.36 or - 36% (Negative probability !)
(I can see where 45 degrees or 0.5 & 0.5 would not reveal this problem)
Before we even consider running a test, we know the LR (Local Realist) cannot predict .14 & .86 due to the negative probability that would predict for permutations [3][6] together! The LR position must agree with the validity of the Statistical Math as being a requirement part of the LR and a prediction of .14 & .86 on its face would be contrary to the LR view and assumtions BECAUSE: ...?
However from the QM view the Statistical Math is not even considered or referred to since the assumption and principal view of QM does not agree that the above Statistical Math would apply to this case at all BECAUSE: ...?
Therefore before running the test we know that the only realistic prediction that the LR based on LR assumtions & view (and such test results validate the LR view) WOULD BE: ...?
  • #52
RandallB said:
1. Before we even consider running a test, we know the LR (Local Realist) cannot predict .14 & .86 due to the negative probability that would predict for permutations [3][6] together!
2. The LR position must agree with the validity of the Statistical Math as being a requirement part of the LR and a prediction of .14 & .86 on its face would be contrary to the LR view and assumtions BECAUSE: ...?
3. However from the QM view the Statistical Math is not even considered or referred to since the assumption and principal view of QM does not agree that the above Statistical Math would apply to this case at all BECAUSE: ...?
4. Therefore before running the test we know that the only realistic prediction that the LR based on LR assumtions & view (and such test results validate the LR view) WOULD BE: ...?
1. Yes, exactly, this is what Bell pointed out.
2. Because, as you showed, negative probabilities result and that is an un-physical result.
3. Because QM already had the Heisenberg Uncertainty Relations (with its h), and had accepted that there were limits to the description of physical reality. (The realist position is that there is no absolute limit.)
4. LR must predict differing values from QM, since the .14 and .86 are the predictions of QM. So the LR advocate has a problem as now QM and LR must go their separate ways.
Keep in mind that we are in the world of "designer" theories in which theories can be constructed ad hoc to fit various scenarios. Of course, 99.99% of these are totally useless and most of those are a complete waste of time. QM is the .01% that is useful.
So if you (or someone else) want to construct a theory which can be disproven before testing, then there is no law against it other than it wastes time. There are also those who hold out hope that all existing published EPR tests will somehow be thrown out in the future.
  • #53
Yes, for example me, and not without good reason.
I've studied many reports of actual experiments and discovered alternative local realist explanations for all the results. In some experiments it's just a matter of the data having been adjusted in a manner that makes sense under QM but not under local realism. The adjustment increases the Bell test statistics, turning (in the specific instances for which I have the data) results that comply with the inequality into ones that do not. In other experiments, the "detection" or "fair sampling" loophole is open. This loophole crept into the experiments as a result of sleight of hand! It is related to the use of an inequality for which an unbiased estimate demands that each term be divided by the number of emitted pairs. The test used in practice involves division by the number of detected pairs and is simply not valid.
There are other loopholes, different ones (or combinations of them) being relevant in different experiments. See my website or a page I contributed to wikipedia:
http://en.wikipedia.org/wiki/Bell_test_loopholes
Caroline
  • #54
Caroline:
DrChinese's comment:
"LR must predict differing values from QM, since the .14 and .86 are the predictions of QM."
Makes no sense to me.
Just because one method/theory (QM) makes a prediction (A legit one based on that theory) cannot be justification for denying any other approach from making exactly the same prediction as long as it's legit within that other theory.
A credible argument as to why LR is wrong should at least define the prediction LR must make (Say for 22.5 degrees), within the definition of LR.
I guess Dr Chinise dosn't know or care as he's in a position to already "know" that even if it agrees with QM it's wrong.
You have at least implied that there are results that if reached during testing would support LR over QM. (Hence your concern over the apparent "adjusted" data favoring QM).
My main question then: in an example like 22.5 degrees, does LR make a prediction different than QM?
What is it ??
Are we talking about a tiny difference like .001% or less that is making this so hard to test?
Personally I wonder about the usefulness of Polarization testing, because it seems to me that a classical view, as I'd see it, would agree with 14% and 85% that QM predicts. But I suspect my "classical view" may not be consistent with the rules for LR. I can deal with that later.
For now I'd be impressed if someone could just explain what the LR prediction actually is for 22.5 degrees.
RB
  • #55
RandallB said:
Caroline:
I will repeat: Bell's Theorem (and not DrChinese) precludes LR and QM from making the same predictions.
Also: As I have said before, some LR theories make predictions outside of the Bell Inequality. I have repeatedly asked for other values to discuss. In one of these provided by Caroline, the difference between LR and QM is large: 1.000 for QM vs. .7500 for LR at 0 degrees; .8536 for QM vs. .6768 for LR at 22.5 degrees (correlated cases). However, they agree at 45 degrees.
  • #56
You're just not reading me, DrChinese! The figures are meaningless. The idea that LR predicts just one figure is wrong: LR represents the genuine scientific approach to modelling the real world, and it is absolutely right and proper that it should give a different result for each experiment. The exact experimental conditions vary.
That's one point. The other is that if the experimenters in practice pursue the aim of obtaining as high a visibility to their coincidence curves as they can (by using suitably low beam intensities, for instance, with the nominal aim of obtaining the "single photon level"), then they will land up, if they are lucky, with curves of almost 100% visibility. They will be very nearly exactly sinusoidal. Both LR and QM agree on this, so naturally there is no problem for LR theory in agreeing with your figures and with experiment, so long as we look only at the normalised data, where the normalisation is done with respect to the detected pairs! Had we normalised with respect to the emitted pairs, the figures would have looked very different. All coincidence rates would have been well below the QM prediction.
As far as I know, there has been only one exception to this -- the Rowe et al experiment using trapped ions. Here almost every emission was detected, so the two methods of normalisation coincide. As the whole world recognises, though, the experiment did not satisfy the basic requirements of a Bell test: the ions were very close together, the settings of the detectors may not have been independent, and the measurements made did not even pretend to be independent. [See M Rowe et al, “Experimental violation of a Bell’s inequality with efficient detection”, Nature 409, 791 (2001)]
Caroline
  • #57
I recognize that you postulate added parameters in experimental situations - one being beam intensity. So you should be able to put this in terms of a specific prediction, shouldn't you? I simply ask for a value to compare against the experimental results so we can rule a specific theory as "in" or "out". As best I see, all current LR theories are ruled out by experiment. But perhaps your added parameters would fix everything (although I personally don't see how that is possible).
Assume the added parameter "beam intensity" comes into the equation. You state that QM and your LR theories give identical predictions when this parameter is low. But this would then violate the Bell Inequality, no?
  • #58
I'm afraid not. In the general formula for the local realist prediction we have a function that gives, effectively, the probability of detection as a function of intensity. The exact form of this function depends on the particular make of detector used. The only way I can think of to find this function is to do some supplementary tests using different input intensities and seeing what happens. You have to be careful, though, what physical mechanism you use to vary the intensity! You'd expect one answer if you vary the number of pulses per second, a different one if you vary the strength of each individual pulse. It is mainly the latter that is of interest for Bell tests. The polariser, in the "classical" model, is assumed to reduce the intensity of the indivual pulses.
You're absolutely right! Take account of all the messy details and your LR solution will reveal itself.
I can't guarantee exact equality of the predicitions, only agreement with experiment. Yes, the results may very well violate an invalid Bell inequality, but they will never violate a valid one.
Caroline
  • #59
I've read through this thread, perhaps not quite carefully enough, and here's where my head is at at the moment:
- QM can predict the outcome of an experiment (accurately)
- LR can match the outcome of an experiment (accurately)
- QM's predictions apply across a range of experiments, of several different kinds
- LR cannot make 'before the experiment' predictions (the exact details are unknowable?)
- QM's predictions are general, with no ad hoc components
- LR's post-experiment analyses are ad hoc
- both QM and LR analyses of experimental results are consistent with the Bell inequality
- there have been no experiments conducted - to date - which proponents of LR regard as definitive tests of the Bell Inequality
- there have been many experiments conducted - to date - which proponents of QM regard as definitive test of the Bell Inequality
- proponents of LR have not (yet) proposed an experiment (or class of experiment) which, if conducted properly, would yield a good result which would unambiguously distinguish LR from QM
- proponents of QM have proposed many experiments which, if conducted properly, would yield good results which would unambiguously distinguish LR from QM.
  • #60
Hi Nereid
Hmmm ... Most of your points seem correct. However, I think the position re proposals for experiments that would in fact discriminate between QM and LR is that local realists (and there are, unfortunately, not many of these who have the courage to stand up and be counted) have from time to time suggested such experiments and been ignored. [The journals have not been helpful re publicising them.]
I think one could prove the matter one way or the other if only a sufficiently comprehensive set of tests were to be done, covering a wide range of parameters.
Caroline
  • #61
Nereid
The seemingly circular logic needed to get to where your head is at oddly enough makes the most sense to me. I’m still not sure I have a clear understanding of the LR.
So allow me my translate and you or someone can let me know if I have the LR right.
In the case of “entangled particles” for polarization testing this would be a pair of photons generated simultaneously and heading in opposite directions. With a “LR” observing one of these in Area A while the other is headed off though area B.
LR and QM both agree that the testing in area A (just sending the photon through a polarizing filter) permanent changes that photon, and is no longer the same as it was prior to arriving at the filter.
However, QM claims by going through the filter in area A the photon actually traveling in area B is affected and can test differently then it would have, were no testing to be done on the photon in area A.
LR presumes the testing in area A has had no affect at all on the other photon in area B.
-- Just want to be sure I have this basics of how each view understands “entanglement”.
And if I’m understanding the above correctly would it be proper to say the LR view disagrees with the idea of “entanglement”?
  • #62
RandallB said:
---And if I’m understanding the above correctly would it be proper to say the LR view disagrees with the idea of “entanglement”?
Hello--I have been watching here for some time--very interesting postings. Please excuse my posts until I get the hang of the system-
One additional question relating to the above quote: Is it also proper to say that the LR view disagrees with the concept of "Superposition" and that of the Photon being a particle? I read a lot of history in here-but never saw this addressed.. Thanks,Photongod
  • #63
RandallB,
QM doesn't claim that. It claims you will know of the state of particle B only if you measure it, and further notes that when it is measured, you find correspondence to particle A.
  • #64
Quantum Mechanics Meets Reality
It is clear that the quantum world is non-local. But that world has almost nothing to do with reality.
In "Towards Quantum Information Theory in Space and Time", http://arxiv.org/PS_cache/quant-ph/pdf/0203/0203030.pdf
Igor V. Volovich shows us that modern quantum information theory deals with an idealized situation where the spacetime dependence of quantum phenomena is neglected.
In "Local Realism, Contextualism and Loopholes in Bell`s Experiments"
http://arxiv.org/PS_cache/quant-ph/pdf/0212/0212127.pdf
Volovich and Andrei Khrennikov demonstrate that if we include into the quantum mechanical formalism the space-time structure in the standard way then quantum mechanics might be consistent with Einstein's local realism.
Volovich is of the opinion that QM can be fixed. To me, that seems
roughly equivalent to trying to fix the Titanic, but let's look at his
proposal.
Igor Volovich, in "Seven Principles of Quantum Mechanics", looks at
bringing QM closer to reality:
"INTRODUCTION
Most discussions of foundations and interpretations of quantum
mechanics take place around the meaning of probability, measurements,
reduction of the state and entanglement. The list of basic axioms of
quantum mechanics as it was formulated by von Neumann [1] includes
only general mathematical formalism of the Hilbert space and its statistical interpretation, see also [2]-[6]. From this point of view any mathematical proposition on properties of operators in the Hilbert space can be considered as a quantum mechanical result. From our point of view such an approach is too general to be called foundations of Quantum mechanics.
We have to introduce more structures to treat a mathematical scheme
as quantum mechanics. These remarks are important for practical
purposes. If we would agree about the basic axioms of quantum mechanics and if one proves a proposition in this framework then it could be considered as a quantum mechanical result. Otherwise it can be a mathematical result without immediate relevance to quantum theory. An important example of such a case is related with Bell's inequalities. It is known that the correlation function of two spins computed in the four-dimensional Hilbert space does not satisfy the Bell inequalities. This result is often interpreted as the proof that quantum mechanics is inconsistent with Bell's inequalities. However from the previous discussion it should be clear that such a claim is justified only if we agree to treat the four-dimensional Hilbert space as describing a physical quantum mechanical system. In quantum information theory qubit, i.e. the two-dimensional Hilbert space, is considered as a fundamental notion.
Let us note however that in fact the finite-dimensional Hilbert space should be considered only as a convenient approximation for a quantum mechanical system and if we want to investigate fundamental properties of quantum mechanics then we have to work in an infinitedimensional Hilbert space because only there the condition of locality in space and time can be formulated. There are such problems where we can not reduce the infinite-dimensional Hilbert space to a finite-dimensional subspace.
We shall present a list from seven axioms of quantum mechanics. The
axioms are well known from various textbooks but normally they are not combined together. Then, these axioms define an axiomatic quantum
mechanical framework. If some proposition is proved in this framework then it could be considered as an assertion in axiomatic quantum mechanics. Of course, the list of the axioms can be discussed but I feel that if we fix the list it can help to clarify some problems in the foundations of quantum mechanics.
For example, as we shall see, the seven axioms do not admit a nontrivial realization in the four-dimensional Hilbert space. This axiomatic framework requires an infinite-dimensional Hilbert space. One can prove that Bell's inequalities might be consistent with the correlation function of the localized measurements of spin computed in the infinite-dimensional Hilbert space [16, 20]. Therefore in this sense we can say that axiomatic quantum mechanics is consistent with Bell's inequalities and with local realism. It is well known that there are no Bell's type experiments without loopholes, so there is no
contradiction between Bell's inequalities, axiomatic quantum mechanics and experiments, see [21].
There is a gap between an abstract approach to the foundations and the very successful pragmatic approach to quantum mechanics which is essentially reduced to the solution of the Schroedinger equation. If we will be able to fill this gap then perhaps it will be possible to get a progress in the investigations of foundations because in fact the study of solutions of the Schroedinger equation led to the deepest and greatest achievements of quantum mechanics.
In this note it is proposed that the key notion which can help to build a bridge between the abstract formalism of the Hilbert space and the practically useful formalism of quantum mechanics is the notion of the ordinary three-dimensional space. It is suggested that the spatial properties of quantum system should be included into the list of basic axioms of quantum mechanics together with the standard notions of the Hilbert space, observables and states. Similar approach is well known in quantum field theory but it is not very much used when we consider foundations of quantum mechanics.
Quantum mechanics is essentially reduced to the solution of the Schroedinger equation. However in many discussions of the foundations of quantum mechanics not only the Schroedinger equation is not considered but even the space-time coordinates are not mentioned (see for example papers in [6]). Such views to the foundations of quantum mechanics are similar to the consideration of foundations of electromagnetism but without mentioning the Maxwell equations.
Here I present a list from seven basic postulates of quantum mechanics which perhaps can serve as a basis for further discussions.
The axioms are: Hilbert space, measurements, time, space, composite
systems, Bose-Fermi alternative, internal symmetries. In particular the list includes the axiom describing spatial properties of quantum system which play a crucial role in the standard formalism of quantum mechanics. Formulations of the axioms are based on the material from [1]-[20]. The main point of the note is this: quantum mechanics is a physical theory and therefore its foundations are placed not in the Hilbert space but in space and time."
The complete paper may be found at:
http://arxiv.org/PS_cache/quant-ph/pdf/0212/0212126.pdf
References
[1] John von Neumann. Mathematical Foundations of Quantum Mechanics,
Princeton University Press, 1955.
[2] I. Segal. Mathematical Foundations of Quantum Field Theory,
Benjamin, New York, 1964.
[3] G.W. Mackey. The Mathematical Foundations of Quantum Mechanics,
W.A. Benjamin, Inc., 1963.
[4] A. Peres. Quantum Theory: Concepts and Methods, Kluwer,
Dordrecht, 1995.
[5] P. Bush, P. Lahti, P. Mittelstaedt. The Quantum Theory of
Measurement. Springer, 1996.
[6] Quantum Theory: Reconsideration of Foundations, Ed. A.Khrennikov,
Vaxjo University Press, 2002.
[7] P.A.M. Dirac. The Principles of Quantum Mechanics, Oxford Univ.
Press, 1930.
[8] N.N. Bogoluibov, A.A. Logunov, A.I. Oksak, I. Todorov. General
Principles of Quantum Field Theory, Nauka, Moscow, 1987.
[9] R.F. Streater, A.S. Wightman. PCT, Spin, Statistics and All That,
[10] R. Haag. Local Quantum Physics. Fields, Particles, Algebras.
Springer, 1996.
[11] L. Landau, M. Lifschic. Quantum Mchenics, Nauka, Moscow, 1974
[12] J. Sakurai. Modern Quantum Mechanics, 1985
[13] Andrei Khrennikov. Non-Archimedean Analysis: Quantum Paradoxes,
Dynamical Systems and Biological Models. Kluwer Academic Publishers,
1997.
[14] H. Araki. Mathematical Theory of Quantum Fields, Oxford Univ.
Press, 1999.
[15] R. Gill. On Quantum Statistical Inference,
http://www.math.uu.nl/people/gill/
[16] I. Volovich. Quantum Cryptography in Space and Bells Theorem,
in: Foundations of Probability and Physics, Ed. A. Khrennikov, World
Sci.,2001, pp.364-372.
[17] L. Accardi, Yu.G. Lu, I. Volovich. Quantum Theory and Its
Stochastic Limit, Springer, 2002.
[18] M. Ohya, I.V. Volovich. Quantum Computer, Information,
Teleportation, Cryptography, to be published.
[19] A. Khrennikov, I. Volovich. Einstein, Podolsky and Rosen versus
Bohm and Bell, http://arxiv.org/abs/quant-ph/0211078.
[20] I.V. Volovich. Towards Quantum Information Theory in Space and
Time, http://arxiv.org/abs/quant-ph/0203030.
[21] A. Khrennikov, I.V. Volovich. Local Realism, Contextualism and
Loopholes in Bells Experiments,
http://arxiv.org/abs/quant-ph/0212127.
  • #65
RandallB said:
Nereid
1. However, QM claims by going through the filter in area A the photon actually traveling in area B is affected and can test differently then it would have, were no testing to be done on the photon in area A.
2. LR presumes the testing in area A has had no affect at all on the other photon in area B.
1. QM view... is silent about the mechanics. The setup of the QM prediction is "as if" a measurement at A changes the photon at B to match. Or it could have been "as if" a measurement at B changes the photon at A to match. No one really is saying, and that is the objection many have with QM. Anyway, if you follow the picture through to the conclusion, you end up believing you are witnessing non-local causation. But this is really a result of the picture. (There are other possible interpretations as well that lead to the same results. That is why I say "as if" which is a big consideration.)
You know the setup is done as I describe above because the correlation formula is [tex]cos^2\theta[/tex] which comes once the polarization is known on one side. I.e. once you know the results on side A, you can predict the statistics observed on side B. And vice versa.
2. LR view... there is no "one" LR view. There are many depending on the hidden variables you wish to postulate. The most simplistic view is that there is a real polarization which is definite as of when the photons are created. But there are literally an infinite number of other possibilities. Since Bell, it has been acknowledged that the fundamental problems with any LR theory appear insurmountable.
  • #66
JohnBarchak said:
Volovich is of the opinion that QM can be fixed. To me, that seems roughly equivalent to trying to fix the Titanic, but let's look at his
proposal.
..."Therefore in this sense we can say that axiomatic quantum mechanics is consistent with Bell's inequalities and with local realism. It is well known that there are no Bell's type experiments without loopholes, so there is no contradiction between Bell's inequalities, axiomatic quantum mechanics and experiments, see [21].
This is absolutely nothing, John. Any EPR paper that assumes that published experimental results are in error as its premise is stating a well-known position argued by Caroline Thompson and others. And that conclusion is further clouded by the authors arguing that in an infinite-dimensional space, LR wouldn't violate Bell's Inequality anyway.
If folks are going to feel better about LR and Bell by assuming that a) the universe has infinite dimensions; or b) that published repeatable results are in error... well, I say have a nice day.
As to the idea that QM can be "fixed", I would point out the old saying "if it ain't broke, don't fix it." Other than violating some folks' sense of what is right, what is wrong with QM?
More importantly, where is the better theory? You know, the one with more decimal places... We all know there are a thousand "promising" ideas out there, we are simply waiting for ONE actual such theory to materialize. Any theory which makes the same predictive results as QM in all particulars is merely an ad hoc theory, and nothing more. Show me a testable prediction which differs from QM, and then you will have something.
  • #67
Principle of Local Action
I accept your challenge. Einstein's Principle of Local Action has never been violated and it is clearly at odds with QM:
In 1948, very early atomic age, Albert Einstein was in the twilight of his career. He published an article in the journal Dialectica. He hoped that his clear definition of locality and explanation of why locality is an essential part of the scientific method would be a major part of his legacy.
Here is Einstein's Principle of Local Action
"The following idea characterises the relative independence of objects far apart in space (A and B): external influence on A has no direct influence on B; this is known as the Principle of Local Action, which is used consistently only in field theory. If this axiom were to be completely abolished, the idea of the existence of quasienclosed systems, and thereby the postulation of laws which can be checked empirically in the accepted sense, would become impossible."
The import of this principle is that without the Principle of Local Action, science, engineering and law as practiced today would not be viable. In fact, if the Principle of Local Action were to be completely abolished, the Bell Test experiments would have no validity since the test apparatus could be influenced (in unknown ways) by events at the other side of the universe. It should be clear that Bell Test experiments cannot disprove the Principle of Local Action. To make it perfectly clear, the Principle of Local Action would be needed to disprove the Principle of Local Action.
All the best
John B.
  • #68
Unless Volovich has changed his tune since I last corresponded with him, this is not what he claims. I must say I'm inclined to think you are right in dismissing his ideas, though. I could not find much of value in the paper we were discussing (http://arxiv.org/abs/quant-ph/0009058).
I don't know where that idea came from, but it must be remembered that the hidden variables can have any number of components. If they have an infinite number that does not necessarily condemn the theory. The "dimensions" here are merely mathematical, with no assumption that they have any geometrical meaning.
["Some folk" being, in this instance, almost every living human being! Those who are blessed by ignorance of QM would surely never dream of accepting the possibility of non-local effects!
Under that criterion we might find ourselves accepting Ptolemy!
Again and again I've told you: simply repeat a Bell test experiments more comprehensively, doing a designed set of related experiments to investigate how the coincidence rates vary as you vary all the relevant parameters! Simply find out by trial and error what parameters matter (the experimenters will already know these!). They will be found to include those built into the local realist model: parameters controlling the response of a detector to variations in individual input pulse intensity etc..
QM predicts that the CHSH test statistic does not vary as you vary the beam intensity. LR predicts that it is most unlikely to stay constant. It is likely to increase as the beam intensity decreases. [NB: the beam intensity needs to be varied by a method such as the introduction of attenuating plates, so that (under wave theory) each individual pulse of light (treated under QM as a single "photon") is reduced in intensity]
Caroline
  • #69
All the best
John B.
Good try, but there is no conflict between this and QM. If there is, where is the experiment?
  • #70
Except that is going the wrong direction. I said MORE decimals places, not less.
It's all about the usefulness of the theory. Theory is never reality - not ever. All theory is a model of a subset of reality to which the theory applies, under limited conditions and with specific limits on its applicability. QM is useful and has no superior (read: more useful) competitors at this time other than ad hoc theories yielding identical predictions.
  • Quantum Physics
11K
  • Quantum Physics
  • Quantum Interpretations and Foundations
  • Quantum Physics
  • Quantum Physics
9K
