Particle on a sliding inclined plane
In summary, the conversation involves a discussion on the equations of motion for a particle and an inclined plane, viewed from an inertial reference frame. The equations are solved by transforming to a non-inertial frame, where the plane is at rest. The solutions involve the acceleration of the particle and the inclined plane, as well as the normal force between the two objects. The conversation also addresses the possibility of an unphysical solution and provides a condition for when the solution is valid.
Zatman
86
A particle of mass m slides on the surface of a plane inclined at an angle θ to the horizontal. The plane itself has a mass M and is allowed to slide on a horizontal surface (such that θ remains constant). There are no frictional forces.
(i) Write equations of motion for the particle and the inclined plane as viewed from an inertial reference frame.
(ii) By resolving the equations in (i) into a suitable coordinate system, find the acceleration of the particle and that for the inclined plane.
2. The attempt at a solution
Let N1 be the reaction force of the plane on the particle and vice-versa (by NIII), and N2 be the reaction of the horizontal plane on the inclined plane. If a is the acceleration of the particle and A is the acceleration of the plane:
[itex]m\mathbf{a}=\begin{pmatrix}ma_x\\ma_y\end{pmatrix}=\begin{pmatrix}-N_1\sin\theta\\N_1\cos\theta-mg\end{pmatrix}[/itex]
[itex]M\mathbf{A}=\begin{pmatrix}MA_x\\MA_y\end{pmatrix}=\begin{pmatrix}N_1 \sin\theta\\N_2-N_1\cos\theta-Mg\end{pmatrix}=\begin{pmatrix}N_1\sin\theta\\0\end{pmatrix}[/itex]
(see diagram - obviously forces are not drawn at correct positions on the plane, but this is irrelevant for the question anyway.).
It's part (ii) I'm having trouble with. Ignoring the y-acc of the plane, there are three equations and four unknowns (ax, ay, Ax and N1). How is transforming to a different coordinate system going to help? Surely a fourth equation is needed. Any hints would be appreciated :)
First off, you were asked to view this in a non-inertial reference frame. This was NOT made in order to complicate things for you, but actually to help you. What you are basically lacking is such information that the relative normal velocity between the particle and the block remains a CONSTANT zero.
Now, you have put a really good effort into your attempt here, so as a bonus, I will give you a guide on how this can be done.
1. Choice of non-inertial frame:
We choose the frame in which the inclined plane/block is at rest, so that inclined plane is in equilibrium with the fictitious force -MA_x, the particle -mA_x
2. Equations of motion, plane:
N_1sin(theta)-MA_x=0 (x-direction)
N_2-N_1cos(theta)-Mg=0 (y-direction)
3. Equations for motion, particle:
Here, it is most clever to decompose in the tangential and normal direction, since in the tangential direction, the acceleration component relative to the plane is simply equal to the components from the fictitious force and known gravity, while in the NORMAL direction, the acceleration is KNOWN, namely equal to zero (giving an equation relating N_1, A_x and mg to each other).
This yields 4 equations for the unknowns N_2, N_1, A_x, and a_t, the latter being the relative tangential acceleration of the particle.
Now, try to set up these equations, and see if you get it right!
:smile:
Likes 1 person
Really sorry, I typed "non-inertial" when I meant "inertial" in part (i). I think your hints might apply to (ii) anyway, so let me try...
You can perfectly well solve it in an inertial frame, but then you must relate your accelerations properly, so that the relative normal acceleration between particle and plane is zero.
It is simplest to solve it non-inertially.
Good luck! :smile:
To set up an appropriate set of unit vectors to use, I suggest:
[tex]\vec{t}=-\cos\theta\vec{i}-\sin\theta\vec{j},\vec{n}=-\sin\theta\vec{i}+\cos\theta\vec{j}[/tex]
Thus, for example,
[tex]-mg\vec{j}=mg\sin\theta\vec{t}-mg\cos\theta\vec{n}[/tex]
[tex]-mA_{x}\vec{i}=mA_{x}\cos\theta\vec{t}+mA_{x}\sin\theta\vec{n}[/tex]
Thanks for you help, arildno. I have set up the following equations as viewed from the non-inertial reference frame of the inclined plane, and, for the particle, in a coordinate system parallel and perpendicular to the inclined plane:
Plane:
[itex]M\mathbf{A'}=\begin{pmatrix}N_1\sin\theta-MA_x\\N_2-N_1\cos\theta-Mg\end{pmatrix}=\begin{pmatrix}0\\0\end{pmatrix}[/itex]
Particle:
[itex]m\mathbf{a'}\begin{pmatrix}-mg\sin\theta-mA_x\cos\theta\\N_1+mA_x\sin\theta-mg\cos\theta\end{pmatrix}=\begin{pmatrix}ma_t\\0\end{pmatrix}[/itex]
Which I then solve to give...
[itex]A_x=g\frac{\sin\theta\cos\theta}{\sin^2\theta+\frac{M}{m}}[/itex]
[itex]a_t=-g\sin\theta-A_x\cos\theta[/itex]
Using [itex]a_x=a_t\cos\theta+A_x[/itex]* I end up with
[itex]a_x=-g\frac{\frac{M}{m}\sin\theta\cos\theta}{\sin^2\theta+\frac{M}{m}}[/itex]
The line * I'm not so sure is correct. Please could anyone confirm that I set up the equations correctly and that the line * is also correct?
I agree with that.
Remember that if the block has much less mass than the particle (M<<m), it might quite possibly speed off so quickly that the particle lose contact with it.
Thus, I suggest that you look at the acceleration of the particle in the y-particle, and see if it is ever greater than -g. That essentially will give you a condition for when the assumption of contact between particle and plane is no longer valid.
Likes 1 person
Alternatively, see that N_1, the normal force, is represented as a difference.
However, it must NEVER be negative! Agreed?
Likes 1 person
arildno, thank you very much for all of your help. :)
Yes, I agree that the normal force cannot be negative!
Thus, although I haven't gone through the problem on my own, it looks like:
1. Your basic solution seems sound.
2. But, you should check for whether an unphysicality might occur with negative normal force, and thus add to your given solution a requirement for when the solution in 1 is valid (I assume you can represent that requirement in terms of an inequality for the mass ratio, with an appropriate factor of the angle involved).
I'll check it over for myself some time later.
Likes 1 person
Thus, for example,
Okay, as much to satisfy my own curiosity, I'll solve it in my way here:
Equations are:
[tex]N_{1}\sin\theta-MA_{x}=0 (1)[/tex]
[tex]N_{2}-N_{1}\cos\theta-Mg=0 (2)[/tex]
[tex]mA_{x}\cos\theta+mg\sin\theta=ma_{t}(3)[/tex]
[tex]N_{1}+mA_{x}\sin\theta-mg\cos\theta=0(4) [/tex]
From (1) and (4), we get:
[tex](M+m\sin^{2}\theta)A_{x}=mg\sin\theta\cos\theta[/tex]
That is:
[tex]A_{x}=\frac{mg\sin\theta\cos\theta}{M+m\sin^{2}\theta}(5)[/tex]
Thus, the requirement [itex]N_{1}\geq{0}[/itex] can be written as:
[tex]g\cos\theta\geq{A}_{x}sin\theta[/tex]
Or, using (5)
[tex](\frac{M}{m}+\sin^{2}\theta)\geq\sin\theta[/tex]
That is:
[tex]\frac{M}{m}\geq\sin\theta{(1-\sin\theta)}(6)[/tex]
This is the requirement that comes in addition to to the solution of (1)-(4)
Likes 1 person
Wow, thanks for the additional details! Really appreciate this!
Equations are:
That is:
Or, using (5)
That is:
Now, to be absolutely sure there are no other unphysicalities lurking in this problem, we ought to check also the following inequalities (the global inequality must then be the always most stringent requirement, so that ALL inequalities are fulfilled!):
[tex]a_{x}\leq{0} (*)[/tex]
[tex]A_{x}\geq{0}(**)[/tex]
[tex]-g\leq{a}_{y}\leq{0}(***)[/tex]
Now, from (5), we see that (**) is fulfilled.
(3) may be written as:
[tex]a_{t}=\frac{mg\sin\theta\cos\theta}{M+m\sin^{2}\theta}\cos\theta+g\sin\theta=\frac{M+m}{M+m\sin^{2}\theta}g\sin\theta[/tex]
Thus, with in my system of coordinates,
[tex]a_{x}=A_{x}-a_{t}\cos\theta[/tex]
we have, for (*):
[tex]\frac{mg\sin\theta\cos\theta}{M+m\sin^{2}\theta}\leq\frac{M+m}{M+m\sin^{2}\theta}g\sin\theta\costheta[/tex]
yielding the not very interesting inequality:
[tex]m\leq{M}+m[/tex]
We have that [itex]a_{y}=-a_{t}\sin\theta[/itex]
Thus, we must have, (***):
[tex]-g\leq{-}\frac{M+m}{M+m\sin^{2}\theta}g\sin^{2}\theta\leq{0}[/tex]
The left-hand side inequality can then be written as (the right hand automatically fulfilled):
[tex]\frac{(M+m)\sin^{2}\theta}{M+m\sin^{2}\theta}\leq{1}[/tex]
which is automatically fulfilled since [itex]M\sin^{2}\theta\leq{M}[/itex]
Thus, we have checked that the system does not exhibit any further potential unphysicalities.
:smile:
Likes 1 person
The correct interpretation of the derived inequality is that at that value, the system of equations is INCONSISTENT, in that (1) and (4) will clash.
Your dedication to the detail in this question is inspiring, arildno.
The dedication has more to do with me having messed up privately a couple of times, and getting angry at the damn problem, I had to kill it thoroughly in public! :biggrin:
1. What is a "particle on a sliding inclined plane"?
A "particle on a sliding inclined plane" refers to an object, typically a small and light particle, that is placed on an inclined plane and is allowed to slide down due to the force of gravity.
2. What are the factors that affect the motion of a particle on a sliding inclined plane?
The motion of a particle on a sliding inclined plane is affected by several factors, including the angle of the inclined plane, the mass of the particle, and the force of friction between the particle and the inclined plane.
3. How is the acceleration of a particle on a sliding inclined plane calculated?
The acceleration of a particle on a sliding inclined plane can be calculated using the formula a = g sinθ, where a is the acceleration, g is the acceleration due to gravity (9.8 m/s^2), and θ is the angle of the inclined plane.
4. What is the relationship between the angle of the inclined plane and the acceleration of a particle?
The acceleration of a particle on a sliding inclined plane is directly proportional to the sine of the angle of the inclined plane. This means that as the angle of the inclined plane increases, the acceleration of the particle also increases.
5. Can the motion of a particle on a sliding inclined plane be described using Newton's laws of motion?
Yes, the motion of a particle on a sliding inclined plane can be described using Newton's laws of motion. The first law states that the particle will remain at rest or move with a constant velocity unless acted upon by an external force. The second law states that the acceleration of the particle is directly proportional to the net force applied to it. And the third law states that for every action, there is an equal and opposite reaction.
