Is Zero Raised to the Power of Zero Equal to One?
  • Thread starter The Rev
In summary, any number raised to the zeroeth power is equal to 1, including zero raised to the zeroeth power. There is some debate about the value of 0^0, but it is usually defined as 1 for notational convenience. However, in some cases, it may be defined as 0 or left undefined. Overall, 0^0 is considered an indeterminate form and may have different values depending on how the numbers are approaching zero. In polynomials and power series, 0^0 is defined as 1, but in other contexts, it may have a different value.
  • #71
No, no you've misunderstood me (due to an omission I made).
I've said that the LIMIT of f is equal to [tex]e^{-\alpha}[/tex]; I've not stated that f has been defined at x=0; that is; I should have written:
[tex]f(x)=e^{-\alpha},x\neq{0}[/tex]
sorry about that one..
  • #72
BoTemp said:
Interesting, but I'm not sure if f(x) = exp(-a) in the limit as x->0, because there's a 0/0 in the exponent.
x/x=1 for all non-zero x. It's a limit, so we don't actually care what happens at x=0, just near it.
[tex]f(x)=(e^{-\frac{1}{x}})^{\alpha{x}}=e^{-\alpha}[/tex]
for all x>0, so the limit in question is [tex]e^{-\alpha}[/tex]
  • #73
BoTemp was right in critizing me, shmoe; I hadn't made the proper restriction on x.
  • #74
How you stated it is fine to me, you were talking about a right hand limit. There's no reason for anyone to assume (or even care) if your function was defined at 0.
  • #75
i agree that 0^0= 1
a^x= 1/(a^(-x))
if a=x=0 then there is no way that 0^0= 0 because we'll have 0=infinite(1/0)
  • #76
No, there's no way that 0^0 = 0 because 0^0 is undefined.
If you like heuristic reasoning from identities, what about 0^x = 0?
  • #77
I don't think of 0 as being in the same number system as anything else really. It's more of a concept like infinity.
So you really can't do all of the same math with 0 as you can with other numbers. [tex]0^0[/tex] makes no sense. Nor would [tex]log(0)[/tex].
LOL... that's so funny... where I listed ['tex'] 0^0 [/'tex'] it put "infinity".
EDIT: And now it's back to 0^0. Hmmm...
  • #78
You meant arithmetic. :tongue2: And that comes directly from the definitions -- division is defined for any nonzero denominator.
Incidentally, though, for each operation which is undefined at zero (such as 1/x), there's a corresponding operation which is undefined at one. (such as 1/(x-1)) So, in a very real sense, you can do exactly as much with zero as you can do with any other real number.
  • #79
0^x = 0
defined: for all x > 0
undefined: for all x < 0, x = 0
  • #80
Wait! Did someone already do this?
[tex]0 \approx (1/\infty)[/tex] Not quite; but approximately.
[tex]1/(1/\infty) \longrightarrow (1/1)/(1/\infty) \longrightarrow (\infty/1) * (1/1) \longrightarrow \infty*1 = \infty[/tex]
Though [tex]0[/tex] is a little less than [tex]1/\infty[/tex]. So what value is it really?
  • #81
As far as math teachers are concerned, you may safely assume [tex]0^0 = 1[/tex] (/End deliberate hand-waving mode). As a precaution, most documents or proofs that require its use (most that I've seen, anyway) will still explicitly state it as a useful interpretation before applying it.
  • #82
You are wrong [tex]\frac{1}{\infty}[/tex] does not make sense for real numbers as [tex]\infty[/tex] is not an element of the real number set. As for sets in which it does exist, you need to learn their axioms and not assume that they are the same as the real numbers (otherwise they would be the real numbers).
  • #83
hurkyl 0^x=0 if x is different from 0
0^m*0^-m=0^0=1
or as i said before a^x=1\(a^(-x)) so if a=x=0 this means
0^0= 1\(0^(-0))
in this case 0^0 should b equal to one
x^0= 1 even for x=0
  • #84
Sabine said:
0^m*0^-m=0^0=1
If you look very carefully you've just divided by zero: one of m or -m is negative (i'm assuming integral exponent)
  • Linear and Abstract Algebra
