1=0 only in trivial {0} ring.
  • Thread starter tc_11
tc_11
Hi, I found a couple of proofs proving that 1=0 only in the trivial ring {0}. They say
Suppose 1 = 0. Let a be any element in R; then a = a ⋅ 1 = a ⋅ 0 = 0.
But what I don't understand is that they say a = a ⋅ 1. But that is only true if a ring has unity (x*1=1*x=x), and it is possible to have a ring without unity, so why is it okay to say a = a ⋅ 1?
Answers and Replies
Landau
What could 1 possibly mean in a ring without unity? :wink:
tc_11
Yeahh okay that's what I was thinking. We know 1 is in R.... and there is no other way for the number one to behave... 1*x = x always. And so since 1 is in R, we must have unity. Thanks!
Landau
This is not really formulated correctly. The element "1", pronounced "the identity element" or "unit element" is by definition an element with the property that 1x=x=x1 for all x. So once you state a property about "1" you are assuming such an element exists in the first place.
So the correct statement should be:
Let R be a ring with 1. If 1=0, then R={0}.
The first sentence is essential, because otherwise the second sentence does not make any sense.
tc_11
Okay.. but if we are talking about a ring where 1=0, don't we already know 1 is in the ring?
Landau
I don't know how I can be more clear than in my last post:
tc_11
I'm sorry, I'm just trying to understand... my initial question is: we want to prove that the only time 1=0 is in the trivial ring {0}. And in the proof, it is said a=a*1. And so I am trying to clarify... we can use the property a=a*1, because we are talking about a ring where 1=0, we know the ring contains the identity element 1 since 1=0 in our ring? http://en.wikipedia.org/wiki/Proofs_of_elementary_ring_properties
Landau
I am trying to explain that the statement "1=0 holds in our ring" does not have any meaning, except if it had already been assumed that our ring contains the identity element 1. You can't prove a meaningless statement. If our ring does not contain 1, what do you think it would mean to say 1=0?
tc_11
So if our ring does not contain 1... then our ring does not have unity (there is no element such that a*1=a). Then 1=0 would mean... I'm not sure.. that the only element must be 0 because 1's not in there?
espen180
834
I think this sounds like a contradiction. First you say 1 is not in R. Then you say 1=0 leads to R={0}?
What do you think is confusing about Landau's statement?
disregardthat
34
Note that 0 is, in fact, unity in {0}!
brydustin
205
Proof:
If all "a" in R(Ring) such that ab = b = ba then on one hand "b" is a zero.
Then consider if ab = a = ba, then all "b" is identity.
But then all elements are identity and zero, so this set is trivial, only one element is acting on itself.
Equivalently, the first equation says all "a" is identity" and the second equation says all "a" is "identity", but then there must only be one element because everything is zero and identity.... There 1=0 and set is trivial.
QED
Suggested for: 1=0 only in trivial {0} ring.
  • Last Post
20K
  • Last Post
11K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
10K
