Euler's 1-2+3-4+5 = 1/4 Formula - What's Your Experience?
  • Thread starter pliu123123
In summary, the equation 1 - 2 + 3 - 4 + 5... does not converge, but can be defined as 1/4 using certain summation methods. This concept was first introduced by Euler in the 18th century. From a non-mathematical perspective, one may find this equation to be interesting or thought-provoking.
pliu123123
43
1-2+3-4+5... = 1/4
i know this was told by Euler longlong time ago in 18th century
but may i know what do u really feel in daily experience and also math sense
thank you=]
Mathematics news on Phys.org
http://en.wikipedia.org/wiki/1_%E2%88%92_2_%2B_3_%E2%88%92_4_%2B_%C2%B7_%C2%B7_%C2%B7" explains it in detail.
In short, the sum does not converge, so that is not the usual definition of equality. But you can http://en.wikipedia.org/wiki/Divergent_series#Abel_summation" it. We consider
1 - 2 x + 3 x2 - ...
and observe that for 0 < x < 1, this converges to (1 + x)-2, and further that the limit x -> 1 gives the answer 1/4. We then "define" the sum to be this.
Summation methods such as http://en.wikipedia.org/wiki/Ces%C3%A0ro_summation" are not "bad" in any sense, just a different way at looking at sums.
but what is ur feeling about this equation (without using math angle of view)is it stunning or else=]?
1. What is Euler's 1-2+3-4+5 = 1/4 formula?
Euler's 1-2+3-4+5 = 1/4 formula is a mathematical formula that was discovered by the famous mathematician Leonhard Euler in the 18th century. It is also known as the alternating harmonic series and it states that the sum of the series 1-2+3-4+5... to infinity is equal to 1/4.
2. How does Euler's 1-2+3-4+5 = 1/4 formula work?
The formula works by using the concept of telescoping series, where each term in the series cancels out with the next term, leaving only a finite number of terms. In this case, the terms alternate between positive and negative integers, and the sum of these terms approaches 1/4 as the series goes to infinity.
3. What is the significance of Euler's 1-2+3-4+5 = 1/4 formula?
Euler's 1-2+3-4+5 = 1/4 formula has many applications in mathematics and physics. It is linked to the Zeta function, which has important implications in number theory. It is also used in the study of divergent series and has connections to the Riemann hypothesis. In physics, it has been used to calculate the energy of the quantum vacuum.
4. Is Euler's 1-2+3-4+5 = 1/4 formula controversial?
Yes, there is some controversy surrounding Euler's 1-2+3-4+5 = 1/4 formula. Some mathematicians argue that it is not a valid mathematical result because the series does not converge in the traditional sense. However, others argue that it is a useful tool in certain contexts and can be justified through rigorous mathematical reasoning.
5. How can Euler's 1-2+3-4+5 = 1/4 formula be proven?
There are several ways to prove Euler's 1-2+3-4+5 = 1/4 formula, depending on the mathematical approach used. One way is to use the Riemann zeta function and complex analysis. Another way is to use analytic continuation, a technique used to extend the domain of a function beyond its initial definition. Some other methods include using regularization techniques and Abel summation.
  • General Math
  • General Math
  • General Math
