Kinetic Energy & E=mc^2: A Physics Query
  • Thread starter brian.green
  • Tags
    E=mc^2
In summary, the kinetic energy equation 1/2mv^2 comes from the classical mechanics definition of work as the product of force and displacement. The well-known equation E=mc^2 is for rest energy, not kinetic energy, and is a result of the theory of relativity. Both equations are correct and compatible with each other.
brian.green
27
The kinetic energy equ. is 1/2m*v^2 but why just 1/2m and why v^2? I understand why m*v but the rest of it not make sense for me.
There is the well known E=mc^2 where c is v.light but the mass is not half here. Why?
One way of seeing it is that the energy that goes into accelerating an object is given by the work done on that object. Work = force times distance:
E = Fd
If you accelerate an object up to a velocity of v with a constant force then it will have a constant acceleration. Its average velocity during the acceleration will be half of its maximum velocity [right there is your factor of two]. The distance it will cover during the process of accelerating to a velocity of v over a time t will be equal to elapsed time times average velocity:
d = vt/2.​
The acceleration required to reach velocity v in time t is:
a = v/t​
The force required to achieve that (F=ma) is:
F = mv/t​
Put it together and you have
E = Fd = vt/2 * mv/t = mv2/2​
Likes brian.green
If you understand m*v then let's start with it. In classical mechanics (and that's what we are talking about here) momentum is defined as
[itex]p: = m \cdot v[/itex]
force is defined as the change of momentum with time:
[itex]F: = \frac{{dp}}{{dt}} = m \cdot \frac{{dv}}{{dt}}[/itex]
and mechanical work is defined as the product of force and displacement:
[itex]dW: = F \cdot ds = m \cdot v \cdot dv[/itex]
Integration of the work gives the change of kinetic energy:
[itex]E_{kin} = \int {m \cdot v \cdot dv} = {\textstyle{1 \over 2}}m \cdot v^2[/itex]
That's where 1/2 and v^2 come from.
That's something completely different because
1. It's not classical mechanics but relativity.
2. It's not kinetic energy but rest energy.
Likes brian.green and jbriggs444
Thanks Dave, I understand now! The well known equ. is not correct, not the mass is half actually.
brian.green said:
Thanks, I understand now! The well known equ. is not correct, not the mass is half actually.
##E_0=mc^2## is correct. But it is the formula for rest energy, not for kinetic energy. It is the energy equivalent of an object's mass when the object is just sitting there.
##E^2 = m^2c^4 + p^2c^2## is a generalization that gives total energy E in terms of mass m and momentum p.
##E = \frac{mc^2}{\sqrt{1-\frac{v^2}{c^2}}}## is a generalization that gives total energy E in terms of mass m and velocity v.
If you extract kinetic energy KE = Total energy - Rest energy = ##\frac{mc^2}{\sqrt{1-\frac{v^2}{c^2}}} - mc^2## then you get something for which ##KE=\frac{1}{2}mv^2## is a very good approximation.
So the two formulas are not in conflict. They are, in fact, compatible.
Likes davenn and brian.green
1. What is kinetic energy?
Kinetic energy is the energy an object possesses due to its motion. It is dependent on the object's mass and velocity, and is calculated using the equation KE = 1/2 * m * v^2, where m is the mass and v is the velocity.
2. What is the significance of the equation E=mc^2?
The equation E=mc^2, also known as the mass-energy equivalence equation, is one of the most famous equations in physics. It relates an object's energy (E) to its mass (m) and the speed of light (c). This equation shows that mass and energy are interchangeable, and a small amount of mass can contain a large amount of energy.
3. How is kinetic energy related to E=mc^2?
Kinetic energy and E=mc^2 are related through the concept of relativistic mass. As an object's speed approaches the speed of light, its mass increases. This increase in mass is accounted for in the equation E=mc^2, where the energy (E) is equal to the mass (m) times the speed of light (c) squared.
4. Can kinetic energy be converted into mass?
Yes, kinetic energy can be converted into mass. This is demonstrated in particle accelerators, where high-speed particles collide and can create new particles with mass. This process follows the equation E=mc^2, where the energy of the colliding particles is converted into mass.
5. How is kinetic energy conserved in a closed system?
In a closed system, the total amount of kinetic energy remains constant. This is known as the law of conservation of energy. This means that while energy can be converted from one form to another, the total amount of energy in the system will remain the same. In other words, the kinetic energy of one object can be transferred to another, but the total amount of kinetic energy will remain unchanged.
  • Other Physics Topics
