1.5v batt. charger limiter
  • Thread starter n0_3sc
Main Question or Discussion Point
I have a cheap set of wireless headphones where the base unit supplies a voltage to the headphones to charge the 2 AAA NiMh batteries. However it has not cut-off point, ie. it'll charge indefinitely destroying my rechargeable batteries.
I'm looking for the least complicated circuit that will break the charge when the batteries are near or at max capacity.
Any ideas would help greatly.
Answers and Replies
mgb_phys
7,774
It's difficult to correctly charge NiMH batteries without either monitoring their temperature or periodically stopping, discharging at a constant rate and calculating the change in discharge rate.
The best and simple way to charge rechargables is to do so very slowly, it is difficult to damage batteries if you charge them at say 1/20 of their capacity (ie at 100mA for a 2100mAh AA)
ok so if i have a high mAh batt, I don't need to worry about continuous charge damage?
At the moment its using 500mAh and the batteries end up leaking acid after time.
mgb_phys
7,774
Related Threads for: 1.5v batt. charger limiter
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
17K
  • Last Post
12K
