- #1
BMcN
- 11
- 0
What the conversion for bar so that I can use it to work out volume and temprature? Whats the units?
Should be kg/m-s2Originally posted by Ambitwistor
1 bar = 100,000 pascals = 100,000 kg/m/s2
Uh... no.Originally posted by Chi Meson
Interesting note:
In the "common" world, a bar has the unit "kg/cm^2". THis is referring to the weight of one kilogram per square centimeter. THis of course translates to only 98,010 N per square meter, but somewhere along the line, "g" got upgraded to 10 N/kg instead of 9.801 N/kg.
So what is it in hpdpcf's (horsepower-decades per cubic furlong)?
I see your Schwartz is as big as mine.Originally posted by Ambitwistor
1 bar = 3.4595574 hpdpcf's
$ units
2084 units, 71 prefixes, 32 nonlinear units
You have: bar
You want: horsepower-decade/furlong^3
* 3.4595574
/ 0.28905432
Originally posted by chroot
Uh... no.
1 bar is defined to be 100 kilopascals. A pascal is one Newton per square meter. One kilogram-force is g Newtons. Therefore, one pascal is (1/g) kilogram-force per square meter. Therefore, one bar is 100,000/g kilograms-force per square meter.
g is accepted to be 9.80665 m/s^2, so one bar is 10,197.1621298 kilograms-force per square meter.
I have no idea where you got the idea that someone rounded g to 10 m/s^2, but it never happened.
- Warren
Bar conversion is the process of converting units of volume and temperature from one measurement system to another. It is commonly used in scientific and engineering fields to ensure consistency and accuracy in measurements.
Bar is a unit of pressure that is commonly used in scientific and engineering applications because it is a metric unit and therefore is more easily converted into other metric units. It is also a practical unit for measuring pressure in everyday situations.
To convert from Fahrenheit to Celsius using bar conversion, you can use the following formula: °C = (°F - 32) * 5/9. Once you have the temperature in Celsius, you can then use the appropriate bar conversion factors to convert to the desired units.
The conversion factor for converting liters to gallons is 1 gallon = 3.785 liters. This means that to convert from liters to gallons, you would divide the volume in liters by 3.785.
Bar conversion can be used for a variety of units, including volume and temperature. However, it may not be applicable for all types of units. It is important to check the specific conversion factors and formulas for the units you are trying to convert.
