∫1/ (x^3-1)
  • Thread starter arishorts
∫1/(x^3-1)
A/(x-1) + (Bx+C)/(x^2+x+1)
1=A(x^2+x+1) + (Bx+C)(x-1)
I've solved for all the variables in this...
A= 1/3
B= -1/3
C= -2/3
which gets me:
1/3*Ln|x-1| + ∫(-(x/3)-(2/3))/(x^2+x+1)
I can't figure out how to integrate the second half. Maybe i'm not using the right u (u-sub)? There's probably something really simple i'm not seeing.
Answers and Replies
What if you had 1/(ax^2+b)? Then you would use trig sub right? If you complete the square, then you'll be closer to this form.
40
Hi arishorts! Welcome to PF!! :biggrin:
Try substituting [tex]u = x^2 + x + 1[/tex]
You already know this... but i get du=2x+1 dx, but the numerator is x+2. is there a transition i'm missing?
sorry, i didn't notice the x factor in the numerator, you should integrate that part spearately, you can use the easier u substitution.
I'm trying this right now, don't see why it shouldn't work. Is there not a simpler way?
Edit:
This is what i'm doing right now:
-(1/3)∫ (x+2) / ((3/4)-(x+(1/2))^2)
Then i'd trig sub...
40
Write it as
[tex]\frac{1}{2} (\frac{2x+1}{x^2+x+1} + \frac{3}{x^2+x+1})[/tex]
And then complete the square.
du/2=(x+1/2)dx, then for the leftover (a constant in the numerator), complete the square then use trig sub.
Edit:
no simpler way, that's why they teach trig sub
EDIT: Infinitum's last post looks good, use simpler u-sub on term on left, trig sub on right.
Write it as
how can you do that to the numerator, but not the denominator?
40
Is this correct?
[tex]\frac{a+b}{c+d} = \frac{a+b}{c} + \frac{a+b}{d}[/tex]
Put in some values to be sure :wink:
EDIT: it's up to you if you want to consider the x term in the numerator while doing trig sub, I was thinking a constant would be all you'd want to consider. the part with an x in the numerator, i usually go for the much "simpler" u-sub.
You seem to have a very strong algebraic manipulation background, where as i don't. Been trying to work on it lately. I'm trying all methods mentioned here (trying to make sense of it all).
Infinitum actually multiplied by 2(1/2), rather than (1/2)/(1/2). You see, they distributed the 2 to the numerator, and left the 1/2 out front.
do what to the numerator?
Is this correct?
not trying to be an ***...
a=1, b=2, c=3, d=4
3/7 ≠ 3/3 + 3/4
it was edited. the 1/2 wasn't there before or i didn't see it. i see it now. Let me try this.
SammyS
Staff Emeritus
1,045
Write it as
[itex]\displaystyle -\frac{1}{3}\frac{x+2}{x^2+x+1}=-\frac{1}{3}\frac{1}{2}\frac{2x+4}{x^2+x+1}[/itex]
[itex]\displaystyle =-\frac{1}{6}\frac{2x+1+3}{x^2+x+1}[/itex]
[itex]\displaystyle =-\frac{1}{6}\left(\frac{2x+1}{x^2+x+1}+\frac{3}{x^2+x+1}\right)[/itex]​
Got it! Thanks guys... Give you guys +rep if i could, but there doesn't seem to be that system here.
Just got it. Thanks.
Related Threads on ∫1/ (x^3-1)
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
