Johnny Martin
- 2
I am making my own 12v electric bicycle but have read that a starter motor is not acceptable because it is not designed for extended use. What motor could I use?
Johnny Martin said:I am making my own 12v electric bicycle but have read that a starter motor is not acceptable because it is not designed for extended use. What motor could I use?
To create a DIY 12v electric bicycle motor, you will need a 12v DC motor, battery pack, controller, throttle, and some basic tools such as pliers, screwdrivers, and wire cutters. You may also need additional materials depending on the specific design and components you choose.
The difficulty level of building a DIY 12v electric bicycle motor will depend on your technical skills and experience. It may require some basic knowledge of electronics and mechanical systems. However, with the right instructions and materials, most people can successfully build one.
The cost of building a DIY 12v electric bicycle motor will vary depending on the quality and type of components you choose. On average, it can cost anywhere from $100 to $300. However, you can also save money by using recycled or salvaged parts.
The time it takes to assemble a DIY 12v electric bicycle motor will depend on your skill level, the complexity of the design, and the availability of materials. It can take anywhere from a few hours to a few days to complete the assembly.
Yes, it is important to take safety precautions when building a DIY 12v electric bicycle motor. Make sure you have the necessary protective gear such as gloves and safety glasses. Also, be careful when handling and connecting electrical components to avoid electrocution. It is also recommended to test the motor in an open and safe area before using it on your bicycle.
