Homework Help: 1D kinematics - 100m dash
  1. Sep 25, 2010 #1
    On June 14th, 2005, Asafa Powell of Jamaica set a world's record for the 100-m dash with a time t=9.77s. Assuming he reached his maximum speed in 3.00s, and then maintained that speed until the finish, estimate his acceleration during the first 3.00s.
    2. Relevant equations
    vx=v0x+axt
    x-x0=v0xt+1/2axt2
    vx2=v0x2+2ax(x-x0)
    3. The attempt at a solution
    I broke the run into two segments, one of 3s with constant acceleration, and the other of 6.77s with 0 acceleration. The distance traveled in the first segment is 100m - the second, and the same is true of the second segment in relation to the first. Beyond that, I've been fumbling around with this problem for two hours and I'm still no closer to solving it than when I started.
  3. Sep 25, 2010 #2
    The problem is that there are 2 unknowns. You don't know what his acceleration is (obviously) and you don't know what his final velocity is.
    It was a good idea to break the problem into two parts. Try using the third equation to write the final velocity in terms of acceleration.
  4. Sep 26, 2010 #3
    Got it! I can't believe I spent so long on it when the solution was so simple!
    There was another equation that I omitted because I didn't think I'd be using it:
    [tex]\Delta x=\frac{1}{2}(v_{0x}+v_{x})t[/tex]
    So here is how I solved it:
    I found [tex]\Delta x_{1}[/tex] in terms of the final velocity with the formula above:
    [tex]\Delta x_{1}=\frac{1}{2}(v_{0x}+v_{fx})t[/tex]
    [tex]\Delta x_{1}=\frac{1}{2}(0+v_{fx})*3 sec[/tex]
    [tex]\Delta x_{1}=1.5 sec*v_{fx1}[/tex]
    And since there is no acceleration in the second segment:
    [tex]\Delta x_{2}=v_{x2}t[/tex]
    [tex]\Delta x_{2}=6.77 sec*v_{fx1}[/tex]
    [tex]\Delta x_{total}=\Delta x_{1}+\Delta x_{2}[/tex]
    [tex]100 meters=1.5 sec*v_{fx1}+6.77 sec*v_{fx1}[/tex]
    [tex]100 meters=8.27 sec*v_{fx1}[/tex]
    [tex]v_{fx1}=12.092 m/s[/tex]
    [tex]a=\frac{\Delta v}{\Delta t}[/tex]
    [tex]a_{x1}=12.092 m/s \div 3 sec[/tex]
    [tex]a_{x1}=4.03 m/s^2[/tex]
    The equations aren't coming out right on the preview. The first equation if for delta x, 1 = delta x 1, 2 = delta x 2, and a = delta v /delta t
