1st law of thermo
  • Thread starter phymatter
What is the difference between [tex]\Delta[/tex]H and [tex]\Delta[/tex]E in a constant volume process ?????
Answers and Replies
By definition it is always true that
[tex]
H=E+pV
[/tex]
At constant volume you have
[tex]
\Delta_V H=\Delta E+V\Delta p
[/tex]
Here you see the difference in the term.
What exactly did you want to know?
but acc to first law Heat supplied = internal energy + work done
i.e.
i.e. [tex]\Delta[/tex]h = [tex]\Delta[/tex]U + [tex]\Delta[/tex]W
and [tex]\Delta[/tex]W = [tex]\Delta[/tex](pv) and
[tex]\Delta[/tex](pv) = P[tex]\Delta[/tex]V + V[tex]\Delta[/tex]P and
for work done V[tex]\Delta[/tex]p is taken as zero so how come can we say here V[tex]\Delta[/tex]P is not taken as zero here?
Mapes
Hi jeedoubts, welcome to PF. Can you give a reference for these two equations? I doubt very much that they're correct. For example, work is defined as [itex]P\Delta V[/itex], not [itex]\Delta(PV)[/itex].
I agree with Gerenuk's answer.
what does the quantity v[tex]\Delta[/tex]p refers to then????
Mapes
The difference between enthalpy change and energy change in a constant-volume process.
physically what does it represent??
Mapes
I don't know of a simpler description (other than the literal "volume multiplied by pressure change"). What are you looking for?
Neither equation is correct in general. The correct equations are
[tex]
\mathrm{d}W=p\mathrm{d}V
[/tex]
(or with the other sign if you consider the work done on the system) and if you wish
[tex]
\mathrm{d}(pV)=p\mathrm{d}V+V\mathrm{d}p
[/tex]
It follows that only for constant volume or constant pressure processes the work can be described by
[tex]
W=p\Delta V\qquad\text{(const. p or const. V)}
[/tex]
Is it very important to know what is the general equation and what the special case. These special cases only apply if the conditions are met.
Mapes is correct.
Related Threads on 1st law of thermo
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
