Understanding Triangle Medians and Their Proportions
  • Thread starter momentum
  • Tags
    Triangle
In summary, the conversation revolved around understanding the concept of a centroid in a triangle and its 2:1 properties. The participants discussed the conditions under which the centroid is formed and its significance in a triangle. They also requested for tutorials and explanations on the topic, as well as clarifications on certain aspects. The conversation ended with a thank you and appreciation for the concept.
momentum
111
i have heard
when you draw a median in a triangle ...the median gets 2:1 bisected
i want to know when this happens ?
which one is the bigger portion ?
which one is the lower portion ?
can you please tell me the details of it.
can u please provide me a specific web page which explains this stuff ?
thank you
Mathematics news on Phys.org
I simply can't figure out what you mean. Can you post a drawing of that triangle...?
Daniel.
nobody replied.
if medians sects each other who is "2" and who is "1" ...so i want to know about 2:1 formula.
which situation this rule works ?
can you please provide me a tutorial for this ?
momentum said:
here i have uploaded the image
http://img69.imageshack.us/my.php?image=math7of.jpg
in which situation that works ?
does AO:OD=2:1
OR
AO:OD=1:2
which one is correct ?
What do you mean? I don't really get that?
What does the problem actually say?
Which one is the median, and which one is the bisector?
Or do you mean the centroid of a triangle (i.e, the single point where the 3 medians in a triangle intersect each other)? :)
OD = 1/3 AD ; AO = 2/3 AD
AO = 2OD ; AO:OD = 2 : 1
or OD : AO = 1 : 2
yes...probabily you are right.
in fact i don't know the details.
all i know is , a median is divided into 2:1 ratio sometimes ...but when ? i don't know. ...thats what i want to know.
can you please tell when does it occur ?
does it occur when 3 medians intersects each other ?
well, suppose 3 medians intersect each other, so that means each of the median is divided into 2:1 ratio ...but which portion is 2 and which portion is 1 ?
does the
top-->center=2
and
center-->bottom(middle of a side)=1
is this correct ?
Please provide me a tutorial.
i want to know about this thing.
i could not search "google" becuase i don't know what search keywords i should use to search .
thank you
does the
top-->center=2
and
is this correct ?
thank you
In the post #5, I did provide you the link to a wikipedia article about triangle. In the article, you will fnd a part that tells you something about the centroid. It's in the Points, lines and circles associated with a triangle section (number 3).
I'll give you a brief explanation if you want. But I may say, my terminology is not the best.
Let ABC be a triangle, and AM be one of its median. [tex]M \in BC[/tex]
We define the point G on the line segment AM such that:
[tex]\frac{AG}{GM} = \frac{2}{1} \quad \mbox{or} \quad \frac{AG}{AM} = \frac{2}{3} \quad \mbox{or} \quad \frac{MG}{AM} = \frac{1}{3}[/tex].
Then G is the centroid of the triangle ABC.
That is, the median BN, and CK pass through G.
And if we have 3 medians AM, BN, CK, they will intersect each other at only one point, namely G (the centroid).
Can you get it? :)
the centroid of a triangle has many 2:1 properties.
consider triangle ABC, with medians AD, BE, and CF.
1. Centroid G divides medians in the ratio 2:1, so that [tex]\frac{AG}{GD} = \frac{BG}{GE} = \frac{CG}{GF} = \frac {2}{1} [/tex]
2. the centroid G divides the line joining the circumcentre O and the orthocentre H in the ratio 2:1 so that [tex] \frac{HG}{CG} = \frac{2}{1} [/tex]
3. the foot of the perpendiculars P, Q, and R from the centroid to altitudes, divides the altitudes AX, BY, and CZ in the ratio 2:1. that is [tex] \frac{AP}{PX} = \frac{BQ}{QY} = \frac{CR}{RZ} = \frac{2}{1} [/tex]
i am sure there are more such properties of the centroid, (though its a guess)... the moment i find out more, i'll post it...
Hi, centroid is a complex thing.
can i ask 2 questions on this centroid ?
does all triangle have centroid ? does all triangles medians intesect each other in a common point which is called the centroid ?
OR ,
there are few triangles (who are they ?) which has centroid ?
please answer.
thanks
OR ,
please answer.
thanks
Every triangle has a centroid, the centroid is defined to bo the intersection of its 3 medians.
There should be a proof of 3 medians in a triangle intersect each other at only 1 point in your textbook, and that point is called the centroid of that triangle.
Can you get this? :)
beautiful....thanks
1. What is the definition of a median in a triangle?
A median in a triangle is a line segment that connects a vertex to the midpoint of the opposite side. In other words, it divides the opposite side into two equal parts.
2. How many medians does a triangle have?
A triangle has three medians, each connecting a vertex to the midpoint of the opposite side.
3. What is the relationship between a median and the sides of a triangle?
A median is always half the length of the side it connects to. This means that the ratio of the median to the side it connects to is always 1:2.
4. How do you find the length of a median in a triangle?
To find the length of a median in a triangle, you can use the formula M = 1/2 * √(2a² + 2b² - c²), where M is the length of the median, a and b are the lengths of the two sides adjacent to the median, and c is the length of the side opposite the median.
5. Can a median be outside of a triangle?
No, a median must always be inside the triangle. It connects a vertex to the midpoint of the opposite side, so it cannot extend beyond the boundaries of the triangle.
  • General Math
  • General Math
  • General Math
  • General Math
