2 boxes with energy attempt
  • Thread starter Johnny_99
  • Tags
    Energy
In summary, a system consisting of two boxes connected over a pulley and at rest is released. Box A has a mass of 15kg and box B has a mass of 12kg. The bottom of box A is originally 85cm above the floor. Using conservation of energy and assuming negligible friction, the system has a total energy of 124.95J before being released. After being released, the energy is split between box A and B, with box A having 99.96J and box B having 24.99J. However, the change in energy is not 24.99J as box B is still moving when box A hits the floor. Taking into account the relationship between the speeds of A and
Johnny_99
Two boxes are connected over a pulley and hel AT REST. Box A has a mass of 15kg and box B has a mass of 12kg. If the bottom of box A is originally 85cm above the floor, with what speed will it contact the floor when the system is released? Use conservation of energy and assume that friction is negligible. (Hint: Think abou the total energy of the system before and after the block A is released)
ET= mgh + 1/2mv squared
Ek=1/2mv squared
Ep=mgh
Before released: Eta= (15)(9.8)(.85)
Eta= 124.95J
After released: Etb= mgh
Etb= 12(9.8)(.85)
up to this point, the test says I have it write (as seen from the teachers marking)
then this is where i somehow went wrong: 124.95-99.96= Change in Energy
*at this point, the marker said, "B HAS Ek TOO!"
then i did: 24.99= Change in Energy
24.99= 1/2mv squared
24.99= 1/2(15)v squared
3.332m/s=v
3.3m/s=v
This is unfortunately not the correct answer. If anyone can assist me in where i went wrong that would be great!
I think block B is still moving when A hits the floor. That's probably what your teacher was talking about (there's no floor to stop B).
So
[tex] U_A = K_A+K_B+U_B[/tex]
Dorothy
what is that?
what does U stand for Dorothy?
Not only is B moving, but what is the relationship between the speeds of A and B? (They are connected by a rope!)
A useful way to view conservation of energy is in terms of changes:
[tex]\Delta{E} = \Delta{KE} + \Delta{PE} = 0[/tex]
Remember: You want the change in energy of the system--both boxes.
(Dorothy is using U to stand for potential energy.)
1. What is the "2 boxes with energy attempt" experiment?
The "2 boxes with energy attempt" experiment is a thought experiment used to illustrate the principles of thermodynamics and energy conservation. It involves two boxes, one with high energy and one with low energy, connected by a valve. The question is whether the energy will spontaneously transfer from the high energy box to the low energy box, or if external work is required.
2. What is the purpose of the "2 boxes with energy attempt" experiment?
The purpose of this experiment is to demonstrate the concept of energy conservation and the second law of thermodynamics, which states that energy will always spontaneously flow from a higher energy state to a lower energy state. It also highlights the role of external work in altering the natural flow of energy.
3. How does the "2 boxes with energy attempt" experiment relate to thermodynamics?
This experiment is a simplified representation of the principles of thermodynamics, specifically the laws of energy conservation and entropy. It helps to illustrate the concept of energy flow and how it is affected by external factors.
4. What are the implications of the results of the "2 boxes with energy attempt" experiment?
The results of this experiment have important implications in various fields, including physics, chemistry, and engineering. It helps us understand the fundamental laws of nature and how energy behaves in different systems, which is crucial for developing new technologies and solving real-world problems.
5. What are some real-world applications of the "2 boxes with energy attempt" experiment?
This experiment has implications in various industries, such as energy production, transportation, and manufacturing. Understanding the principles of energy conservation and entropy can help us develop more efficient and sustainable systems, as well as identify and solve energy-related challenges.
