2-car problem
  1. Sep 18, 2007 #1
    Cars A and B are racing each other along the same straight road in the following manner: Car A has a head start and is a distance Da beyond the starting line at t=0. The starting line is at x=0. Car A travels at a constant speed Va. Car B starts at the starting line but has a better engine than Car A, and thus Car B travels at a constant speed Vb, which is greater than Va.
    How far from Car B's starting line will the cars be when Car B passes Car A?
    2. Relevant equations
    I have figured that the time to catch up = Da/(Vb-Va)
    3. The attempt at a solution
    Using the above, I now have this:
    D=t(to catch up)*(Vb-Va)+Da
    Does this look right?
    thanks!
  3. Sep 18, 2007 #2
    learningphysics
    The time looks right. But not the distance.
  4. Sep 18, 2007 #3
    bel
    Consider car B, [tex] s = D_a + v_a t [/tex]. Then consider car A, [tex] s = v_b t [/tex]. However, the two [tex]s[/tex]s are equal, and hence the equations could be equated. And you got that. Now going back to the distance, it is just [tex] s [/tex] at that specific time, and you already have [tex]s(t) [/tex] as a function of time [tex] t [/tex].
  5. Sep 18, 2007 #4
    ...I don't understand the last part...
  6. Sep 18, 2007 #5
    bel
    The distance [tex]s[/tex] is the distance measured from the sarting point of car B. And that distance changes because the point where you measure it from are the cars and the cars are in motion. The car's motion is given as a function of a variable time [tex]t[/tex], which you found already.
  7. Sep 18, 2007 #6
    So, then....distance= t(to catch up)* (Vb-Va)?
    it's been a while since I took physics at highschool, now I'm struggling at uni...
  8. Sep 18, 2007 #7
    learningphysics
    At any time t, what is the distance that car B has travelled?
  9. Sep 18, 2007 #8
    v/t?
  10. Sep 18, 2007 #9
    bel
    Given the variable of time, [tex]t[/tex], you could use the either of the formulae describing the distance of the cars from the starting point of car B to find the distance, since at that time [tex]t[/tex], both the cars are at the same position. The main concern of this question is to reduce the number of variables as much as possible, so I've reduced it to only one distance variable [tex]s[/tex], to be measured from the initial position of car B and the variable [tex]t[/tex], which is the same for both cars and described both cars' motion with respect to these variables.
  11. Sep 18, 2007 #10
    learningphysics
    Distance = velocity*time
    I think we need to go back to the first part... look at bel's posts also... what is the position of car A at any time... what is the position of car B at any time...
  12. Sep 18, 2007 #11
    I don't know why I'm not getting it....i'll try to start from scratch..
    meanwhile, any sites with formulae you can recommend? I don't even have any of my highschool notes.
    Thanks so much for your help! :)
  13. Sep 18, 2007 #12
    Ok...Position of car A=v*t+Da
    Position of car B-v*t.......
  14. Sep 18, 2007 #13
    How about this?
    distance= Vb*(Da/(Vb-Va)) ?
    Or=Vb*t (time it took to catch up)?
  15. Sep 18, 2007 #14
    bel
    I already gave the formulae above, and by those (i.e., by equating the [tex]s[/tex]s, as I mentioned), I came to your conclusion that "
    I have figured that the time to catch up = Da/(Vb-Va)".
  16. Sep 18, 2007 #15
    learningphysics
    Yes, that's the answer. Be sure you understand why it's the answer though.
    position of car A = Da + va*t
    position of car B = vb*t
    you set the two positions equal and solve for time. when you get the time, you can get the position, by either substituting into the car A equation or the car B equation. Both will work. Using the car B equation you immediately get vb*Da/(vb-va) I'll also do the car A one.
    [tex]Da + va*(Da/(vb-va)) = \frac{Da*vb-Da*va +va*Da}{vb-va} = \frac{Da*vb}{vb-va}[/tex]
    the reason it works is because you solved for the time the positions are equal. so the two positions will come out the same with either formula.
    It's better to use the car B formula since it's easier to evaluate the result.
  17. Sep 20, 2007 #16
    thanks!!!
Similar Discussions: 2-car problem
  1. 2 cars (Replies: 2)
  2. 2 passing cars problem (Replies: 5)
Loading...
