J_o_S
- 18
got it. thanks guys
J_o_S said:For a) I was thinking I could just show that both reaction mechanisms add up to the same reaction.
for b)i) I think the reaction rate would triple, for b)ii) I don't think the reaction rate would change.
not sure about part c
Can anyone point me in the right direction?
thanks
siddharth said:J_o_s: First of all, its 1-propene. Refer the IUPAC nomenclature rules.
Then, look at the structure of propene. The carbon-carbon double bond is rich in electrons. And HBr is an acid. Therefore, where will the H+ ion attack? What's the intermediate formed? Have you learned about carbocations and their rearrangments?Then what will the Br- do?
Also, have you learned about Markovnikov rule.?
Dr Brain: it's an Electrophilic Addition reaction.
Dr.Brain said:siddharth , this is a two stage process ,first the double bond is broken and then Br- attacks.In addition processes, the attack and leaving processes both take place simultaneously.
siddharth said:A reaction in which the substrate and the reagent add up to form a product is called addition reaction.
In this case, HBr is the reagent and propene is the substrate.
Where is the leaving process in the addition reaction?
Dr.Brain said:Leaving process is in substitution and not in addition , have you heard of
[itex]S_N - 1[/itex] and [itex]S_N - 2[/itex] ... ? , the same happens here.
BJ
(ii) Nucleophilic substitution
Here one nucleophile is displaced by another.
Example:
R-X + OH- ----------> R-OH + X-
This reaction can proceed under two major mechanisms, namely the SN1 and SN2 mechanisms. SN1 is a first order reaction and follows first order kinetics whereas SN2 is a second order reaction and follows second order kinetics.
Apart from this there is also the SNi mechanism or Substitution Nucleophilic Internal mechanism.
In the above reaction the attacking species is OH- and the leaving group is X-
An element is a pure substance made up of only one type of atom, while a compound is a substance made up of two or more different elements chemically bonded together.
The periodic table is a tabular arrangement of all known elements, organized by their atomic number, electron configuration, and chemical properties.
The number of protons is equal to the atomic number, the number of neutrons can be calculated by subtracting the atomic number from the atomic mass, and the number of electrons is equal to the number of protons in a neutral atom.
An exothermic reaction releases heat and energy, while an endothermic reaction absorbs heat and energy.
The pH scale is a measure of the acidity or basicity of a solution, ranging from 0 to 14. A pH of 7 is neutral, below 7 is acidic, and above 7 is basic. Each whole number change on the scale represents a 10-fold change in acidity or basicity.
