Can You Install Two CPUs on a Motherboard?
  • Thread starter Saint
In summary: Originally posted by russ_watters Not sure if you're saying you don't believe me, but in any case, this sentence is key:The results on Linux kernel 2.4.19 show Hyper-Threading technology could improve multithreaded applications by 30%. Current work on Linux kernel 2.5.32 may provide performance speed-up as much as 51%. "multithreaded applications" specifically means applications that use multiple cores, not just processors.
Saint
437
In the market, do we have motherboards that can install 2 P4 or AMD CPUs?
Computer science news on Phys.org
Yes...
of course...
use google, it isn't hard.
Not many of the AMD MP boards around though.
How much it boost the performance of the PC when compared to a single processor PC ?[?]
It depends what you're using the computer for. For most purposes, not at all. Programs can only use one CPU unless they're specifically written to take advantage of more. Some games can do this, but even then a second processor usually only gives you a ~25% speed boost.
SMP (multiple CPUs) is mainly useful if you are running a server of some sort, which is running many separate programs/tasks at once. Then the multiple processors can give the server a big performance boost.
If the hardware is VERY good and the software (and operating system) is VERY well written you may be able to get a 90% improvement in some rare cases.
AFAIK, there are still no games that employ SMP. Quake3 did initially but it was an incomplete feature that was discarded in an update.
I've ben reading some good things about Intel's Hyperthreading technology. In short it can generate anywhere from ten to 40 percent increases in performance when a compatible OS is used. I believe IBM ran some benchmarks a couple of months ago comparing 'regular' and hyperthread architectures using XP Pro and Linux (not sure if it was a stock kernel or patched). Google for more answers.
As previously mentioned the performance results for dualCPU designs are highly dependant on the OS (WinXP Pro, Win2K, Linux, xBSD, SolarisX86) and the ability of the application to utilize it.
Q: Does Microsoft still require a license for each CPU in a machine?
Thats 40% WHEN MULTITASKING. For single thread applications there is zero difference in performance.
No, MS doesn't require a license for each cpu.
OKAY.
Here's the original article from IBM
OKAY.
1. What is the benefit of having 2 CPUs on a motherboard?
Having 2 CPUs on a motherboard allows for better multitasking and increased processing power. This is especially useful for tasks that require a lot of computing power, such as video editing or gaming.
2. Can any motherboard support 2 CPUs?
No, not all motherboards are designed to support 2 CPUs. It is important to check the specifications of the motherboard before purchasing to ensure it is compatible with 2 CPUs.
3. How does having 2 CPUs affect the overall performance of a computer?
Having 2 CPUs does not necessarily mean double the performance. While it can improve multitasking and processing power, the overall performance also depends on other factors such as the speed and efficiency of the CPUs, as well as the amount and type of RAM.
4. Can 2 different CPUs be used on the same motherboard?
Yes, it is possible to use 2 different CPUs on the same motherboard. However, they need to be compatible with the motherboard and have similar specifications to ensure optimal performance.
5. Is it necessary to have 2 CPUs for everyday use?
No, having 2 CPUs is not necessary for everyday use. It is only recommended for those who need to perform demanding tasks or run multiple programs simultaneously. For regular use, a single CPU is sufficient.
  • Computing and Technology
9K
  • Electrical Engineering
