MuckThatGuy
- 3
This is a fairly easy problem, conceptually... but I can't seem to put the numbers together correctly.
A circle with a radius "r" has a linear charge along the circumference with a charge density of [tex]\lambda=\lambda_{0}\sin(\theta)[/tex], where [tex]\lambda_{0}[/tex] is the max charge along the circumference.
Find:
a.) The direction of the electric field at the center of the ring.
b.) The magnitude.
(They're obviously not looking for a numerical answer)
2. The attempt at a solution
a.) The direction is definitely down, however, I can't seem to 'show' this outside of just my own intuition.
My best attempt at getting everything together is as follows:
[tex]d\vec{E_{r}}=d\vec{E_{x}}+d\vec{E_{y}}[/tex]
[tex]d\vec{E_{x}}=k\int\frac{dQ}{r^{2}}=k\int\frac{\lambda \;dL}{r^{2}}=k\int\frac{\lambda_{0}sin(\theta)\;dL}{r^{2}}[/tex]
[tex]d\vec{E_{y}}=k\int\frac{dQ}{r^{2}}=k\int\frac{\lambda \;dL}{r^{2}}=k\int\frac{\lambda_{0}sin(\theta)\;dL}{r^{2}}[/tex]
When attempting to get dL into terms of [tex]d\theta[/tex] is when problems arise. I know it has to be simple, but every method I've tried always ends up with a charge of 0 along both the x and y axis's (which is obviouslly wrong).
ETA: I'm not sure if it just suffices to change dL to the x and y components [tex]r\;cos(\theta)[/tex] and [tex]r\;sin(\theta)[/tex] respectively. It doesn't feel right to me, but it's the best I can come up with right now. (The book doesn't cover a problem like this).
