Can you describe the metric on the space of positive definite quadratic forms?
In summary, the set of positive definite quadratic forms on R^2 has a metric that turns it into the product of the hyperbolic plane and the open half line of positive real numbers. This metric is induced by the usual left-invariant metric on GL(2,\mathbb{R}) and is consistent with the well-known fact that GL(n,\mathbb{R})^+ is isomorphic to SL(n,\mathbb{R})\times \mathbb{R}^+. The metric can be visualized as mapping ellipses to points on the Poincare disk and is in the same conformal class as the metric on the upper half plane. The importance of this metric in understanding the space of positive definite
lavinia
694
I am told that the set of positive definite quadratic forms on R^2 has a metric that turns it into
H x R where H is the hyperbolic plane. Can you describe this metric?
* As a space the forms are viewed as GL(2,R)/O(2).
Let's note that there's a Gauss-type decomposition of [tex]GL(n,\mathbb{R})[/tex] matrices as
[tex] \mathcal{M} = U D \mathcal{O}, [/tex]
where [tex]U[/tex] is upper-triangular (with 1s on the diagonal), [tex]D[/tex] is diagonal (with [tex]\det{D}>0[/tex]) and [tex] \mathcal{O}[/tex] is orthogonal (in [tex]O(n)[/tex]). I claim that
[tex] M = \begin{pmatrix} 1 & \sqrt{2} x \\ 0 & 1 \end{pmatrix} \begin{pmatrix} r y & 0\\ 0 & r/y \end{pmatrix},[/tex]
is the general element of the coset [tex]GL(2,\mathbb{R})/O(2)[/tex] provided that [tex]r,y>0[/tex].
We can place the usual left-invariant metric on [tex]GL(2,\mathbb{R})[/tex], which will induce the metric
[tex]ds^2 = \frac{1}{2} \text{Tr} \left[ (M^{-1} dM) (M^{-1} dM) ^T\right],[/tex]
[tex] = \left( \frac{dr}{r}\right)^2 + \frac{1}{y^2} \left( dx^2 + dy^2 \right)[/tex]
on the coset. The space is therefore [tex] GL(2,\mathbb{R})/O(2) = H \times \mathbb{R}^+[/tex]. Note that this is consistent with [tex] H = SL(2,\mathbb{R})/SO(2)[/tex] and [tex]\mathbb{R}^+ = \mathbb{R}/\{ 1,-1\}[/tex].
what is the usual left invariant metric on [tex]GL(2,\mathbb{R})[/tex]?
It's
[tex]
ds^2 = \frac{1}{2} \text{Tr} \left[ (\mathcal{M}^{-1} d\mathcal{M}) (\mathcal{M}^{-1} d\mathcal{M}) ^T\right].
[/tex]
The normalization is put in for convenience. [tex]\mathcal{M}^{-1} d\mathcal{M}[/tex] is the Maurer-Cartan form.
fzero said:
It's
[tex]
[/tex]
Thanks. I will do some reading about this.
Do you have a simple geometric picture of this metric? Start with an ellipse centered at the origin of R^2. Map it onto the Poincare disk somehow. Then maybe the factor of R comes from uniformly scaling the ellipses.
Do you have a simple geometric picture of this metric? Start with an ellipse centered at the origin of R^2, map it onto the Poincare disk somehow. Then maybe the factor of R comes from uniformly scaling the ellipses.
The factor of [tex]\mathbb{R}^+[/tex] corresponds to the determinant of a matrix in the component [tex]GL(n,\mathbb{R})^+[/tex] connected to the identity. The metric we found is consistent with the well known fact that [tex]GL(n,\mathbb{R})^+=SL(n,\mathbb{R})\times \mathbb{R}^+[/tex].
Ok. This is helpful.
Does this picture work?
Each positive definite quadratic form determines an ellipse, its ellipse of unit vectors.
An ellipse has three parameters, the lengths of its two axes and its angle of tilt to the xy-coordinate axes.
The subset that are rotations of ellipses with tilt angle zero and fixed x-axis length, (They are rotations of ellipses with equation, x^2 + y^2/b^2 = K) form a two parameter family.
(By convention, angles of rotation can be chosen to be between 0 and pi (the interval, [0,pi), and the first axis can be chosen to be the one that lines up with the x-axis when the rotation is undone. )
For each ellipse in this 2 parameter family, map it to the point in the Poincare disk whose angle is twice the tilt angle and whose Euclidean distance to the origin is |k1 - k2|/k1 + k2 where k1 and k2 are the lengths of its axes.
This two parameter family looks like the Poincare disk under this mapping. As the x-axis length is varied to account for all positive definite quadratic forms, the entire set looks like the Cartesian product of the Poincare disk with the open half line of positive real numbers.
Is this the correct picture?
What is the importance of this metric for understanding the space of positive definite quadratic forms?
I would identify your K with [tex]\mathbb{R}^+[/tex] in the coset, then the ratio of axis lengths b and tilt angle form the UHP. I think you're still mapping the ratio and tilt angle to the Poincare disk, so you might find that the metric on your space is in the same conformal class as the one on the UHP.
As far as the importance of the metric, I have no specific applications in mind for doing geometry on the space of positive definite quadratic forms. That is not to say that there aren't any. I just happened to be aware of some Lie group geometry that could shed some light on your original question.
1. What is a 2 dimensional quadratic form?
A 2 dimensional quadratic form is a mathematical expression that consists of two variables, x and y, and their corresponding coefficients and exponents. It can be written in the form ax^2 + bxy + cy^2, where a, b, and c are numbers.
2. What is the purpose of studying 2 dimensional quadratic forms?
Studying 2 dimensional quadratic forms is important in many areas of science, including physics, engineering, and economics. It allows us to model and analyze the behavior of variables in real-world situations, making it a powerful tool for understanding and predicting outcomes.
3. How do you graph a 2 dimensional quadratic form?
To graph a 2 dimensional quadratic form, you can plot points on a coordinate plane and connect them to create a parabola. Alternatively, you can use the vertex form, y = a(x-h)^2 + k, to identify the vertex and axis of symmetry and then plot other points accordingly.
4. Can a 2 dimensional quadratic form have a negative coefficient?
Yes, a 2 dimensional quadratic form can have a negative coefficient, such as in the expression -2x^2 + 5xy + 3y^2. This will result in a parabola that opens downward instead of upward.
5. How are 2 dimensional quadratic forms used in real life?
2 dimensional quadratic forms are used in a variety of real-life applications, such as predicting the trajectory of a projectile, optimizing production in manufacturing processes, and analyzing stock market trends. They can also be used to solve optimization problems, finding the maximum or minimum value of a given function.
  • Differential Geometry
  • Linear and Abstract Algebra
