Understanding Power Dissipation in Series Circuits
  • Thread starter steven barnett
  • Tags
    Series
In summary, the conversation is about two 95 watt lightbulbs being connected in series to a 120V supply. The question is how much power is dissipated by each bulb. The formula P=V^2/R is used to calculate this, with 120V being used because it is the total voltage across the two bulbs. Each bulb has a resistance of 151.57 ohms and therefore dissipates 23.75 watts. The conversation also discusses the different ways to calculate power and the importance of considering the individual resistance and voltage of each bulb.
steven barnett
Hey guys I made an account here because I cannot understand this for the life of me.
Two 95 W (120V ) lightbulbs are wired in series, then the combination is connected to a 120 V supply.
How much power is dissipated by each bulb?
Answer 24W
The part I don't understand is why 95=(120^2)/R Shouldn't there be a voltage drop of 60V at each light bulb so you use (60^2) Or you could look at the equivalent resistance and use 190=(120^2)/2R ? I cannot understand why you use the first equation for the life of me. That's saying that the power of one lightbulb is the voltage of the whole system^2 / the resistance of one bulb.
Thank you sorry for ranting this is upsetting me .
Hello Steven, :welcome:
Take it easy ! Keep it cool ! etc etc.
The 120 V / 95 W on the bulb means that 120 Volt times the current I is 95 W.
With uncle Ohm's formula ##I = V/R## that makes 120 Volt times ## V/R## = 95 W, in which ##V## = 120 Volt.
So ##\displaystyle {{V^2\over R} = 95 }## Watt when ##V = 120 ## Volt.
With only half the volts you get one quarter the Watts, so 24 W.
Light bulbs are difficult because they change resistance with temperature. Let us ignore that and assume they are fixed resistors.
A 95 watt bulb connected to 120 volt will have a current of ( 95 watt / 120 volt ) = 0.79167 amp.
The resistance of the bulb will be ( 120 volt / 0.79167 amp ) = 151.57 ohm.
The resistance of two globes in series will be 303.156 ohm.
If 120V is applied to the pair of globes in series, the current will be 0.3958 amp.
Each will dissipate 0.3958 amp * 60 volt = 23.75 watt.
That is correct. For a single globe; W = V^2 / R. or; R = V^2 / W
R ohms = 120 volt * 120 volt / 95 watt = 151.579 ohms
I guess what I don't understand is why you use 120V here and not 60V. Since you are doing this for 1 bulb and each bulb only uses 60V why would you use 120V?
One bulb alone, not two in series.
Two bulbs in series have half the voltage each. Total resistance is twice, so current is then half.
Power = (voltage / 2) * (current / 2) = watt / 4 = 23.75 watt
I just don't understand why in P=V^2/R you use 120V... It makes absolutely no sense to me that for one of these bulbs in the series you use 120V and not the voltage drop of 60V... I really really really appreciate you trying to help me with this
A single 95 W globe on 120 V is specified. From that we must work out the resistance of one globe.
Using; R = V2 / W;
One globe on 120 V.
R = 1202 / 95 = 151.57 ohms.
Then two globes on 120 V.
W = V2 / R .
Two globes on 120 V = one globe on 60 V .
W = V2 / R = 602 / 151.57 = 23.75 watt .
Rated bulb voltage and rated bulb wattage are used to calculate hot filament resistance. R=E2/P = 1202/95 = 151.58Ω
Two bulbs in series is a total resistance of 303.16Ω. A current of 0.396 amps flows when 120V is connected across them.
  • Bulb resistances are equal, and two bulbs are in series, thus one-half of the source voltage (60V) is dropped across each. For each bulb, P=V2/R, 602/151.58Ω = 3600/151.58 = 23.75 watts
  • Current through each bulb is 0.396 amps. P=VI. 60V * 0.396A = 23.75 watts. Looking at it a third way, P=I2R, 0.3962*151.58 = 0.1568*151.58Ω = 23.75 watts.
The trick of it is to think of each light bulb as a resistor, calculate it's resistance at rated voltage and wattage, calculate what I current will flow through this resistance when V voltage is placed across it, then figure out (V*I) watts.
The bulbs are designed to deliver white light without the filament burning out when powered by 120V. So when operated at ½ their rated voltage they won't glow much, perhaps in the dark you'll see a dull red filament, so their emission will be limited to the red and infra red spectrum.
One advantage of operation off a reduced voltage is that you can expect them to last a very long time before the filament breaks!
@steven barnett
I have difficulty figuring out just what is the question.
I think several folks answered that one.
In one case you're solving P=V^2/R for R , to figure out what is the resistance R of the bulb when you're given its ratings of P= 95 watts and V= 120 volts.
In the other case you're solving P=V^2/R for P, to figure out how much power P such a lamp with resistance R will produce when subjected to 60 volts. You got R from previous calc, and you already said you know when two are in series each gets half of the 120.
So that's why you use different numbers in the two places. You're solving for different properties under different conditions.
It's a two step solution not one.
Computers have accustomed us to instant answers. Slow down and take one step at a time.
see if this old thread helps you with thinking about KVL and KCL.
https://www.physicsforums.com/threa...t-live-and-neutral-wires.892309/#post-5613568
old jim
Likes davenn
The bulb is rated for a certain wattage at a certain voltage. You can use that information to find its resistance before getting into the specifics of the problem at hand.
Likes jim hardy
1. How do I know if two lightbulbs are connected in series?
In a series circuit, the two lightbulbs will be connected one after the other, with no other components in between. This means that the current flows through one lightbulb and then the other, and that both lightbulbs have the same amount of current passing through them.
2. What happens if one lightbulb in a series circuit burns out?
If one lightbulb in a series circuit burns out, the entire circuit will be broken and neither lightbulb will work. This is because the current cannot flow through the circuit without a complete path. To fix this, the burned out lightbulb needs to be replaced.
3. How does the voltage change in a series circuit with two lightbulbs?
In a series circuit, the voltage is divided between the two lightbulbs. This means that each lightbulb will have a lower voltage than the total voltage of the circuit. The voltage drop across each lightbulb will be the same, as long as the lightbulbs have the same resistance.
4. Can I add more lightbulbs to a series circuit?
Yes, you can add more lightbulbs to a series circuit, but it is important to make sure that the total resistance of the circuit does not exceed the power supply's limit. This is because the more lightbulbs you add, the higher the total resistance will be, which can cause the circuit to overheat.
5. What are the advantages and disadvantages of connecting lightbulbs in series?
The advantage of connecting lightbulbs in series is that they all receive the same amount of current, which can help to prevent one lightbulb from burning out faster than the others. However, the disadvantage is that if one lightbulb burns out, the entire circuit will be broken and none of the lightbulbs will work. Additionally, adding more lightbulbs to a series circuit can decrease the overall brightness of the lightbulbs.
  • Electrical Engineering
