2 Mass Spring System
  • Thread starter breez
breez
65
A mass M is attached to the left end of a spring with a spring constant K and a mass 4M is attached to the right end. A third mass of mass M slides with velocity v and hits mass M in a completely inelastic collision.
What is the velocity of the smaller mass and of the larger mass when the spring is maximally compressed?
What is the maximum compression of the spring?
Solve in terms of the variables; the surface is frictionless.
What I did was assume both springs have 0 velocity at maximal compression, and just solved for the compression by equating the elastic potential energy with the kinetic energy of the masses the instant after impact. I know my assumption is very unsound.
What's the proper way to solve this?
Answers and Replies
Hootenanny
Staff Emeritus
For an inelastic collision, conservation of energy does not apply, one must use conservation of momentum. It will be useful to note that in a completely inelastic collision, both masses will 'stick together' forming a single body.
Next, you should realize that whatever force is exerted on the smaller mass (2M) by the spring is also exerted on the larger mass.
breez
65
I understand that, but I stated I used Conservation of Energy AFTER the collision. Energy is conserved after the inelastic collision.
tiny-tim
25,838
256
Hi breez! :smile:
Hint: what is the velocity of the centre of mass at maximal compression? :smile:
breez
65
It would just be v/6. I really have no idea where to go on this one...
Doc Al
Mentor
45,462
1,950
What's the speed of the left mass immediately after the collision?
tiny-tim
25,838
256
Yes, v/6.
Now what is the relative velocity of the two ends of the spring at maximal compression? :smile:
Suggested for: 2 Mass Spring System
  • Last Post
