Glad you were able to figure it out! Keep up the good work!
In summary, you need to set the derivative of your function equal to zero in order to find critical points and find the maximum value.
seiferseph
102
Heres what i did for this one.
find an equation relating work + math = 16 (total hours she has in a day).
so math = 16 - work (i plug that into the equation for h)
and for money, i have y = 6*work + 6
i plug this in as well and take the derivative.
i get f ' = -4/3 *(6worrk + 6)^-2/3 (16-work)^-1/3
critical points work = -1, 16. the answer is it hits a max at 14/3 hours. what am i doing wrong?
i really just need some hints, i have no idea how to get started.
thanks!
For the first one, you need to use the product rule to find the derivative:
if f(x) = u(x)*v(x), then f' = u(dv/dx) + v(du/dx)
then solve for critical points. Critical points occur when the derivative = 0. In your work above, you solved for where the denominator = 0 (making the derivative undefined), so be careful with that when you attempt the problem again.
For the second one, you need to write a function for the total length of the trip to get started. If you travel in the manner described from the origin to a point (x,y), then you first move x to the right, y up, x to the left, then y back down to (0,0). So your total trip is d = 2x+2y. Use the curve given to write d as a function of a single variable, then optimize.
i'm working on the first, after setting the derivative equal to zero, i get
6 h^2/3 / y^2/3 = 2 y^1/3 / h^1/3
before substituing in h = 16 - work and y = 6*work +6
how do i solve this equation?
Your equation is correct so far, but I think you're making things tougher on yourself than they have to be. I would rewrite U as a function of w (my variable for the number of hours worked) and only w. Then you can take the derivative and find the optimum w.
Anyway, the way to solve your equation is to cross multiply, so you get that 2y=6h (which can be solved for w).
there are 3 variables, d x and y, I'm not sure how to relate them into one. also, how do the equations relate?
and thanks for the help, i got the other question!
No problem.
You've got d(x,y)=2x+2y, which is what you are trying to maximize.
You've also got y = 4-x2/9
Substitute that into the first one so you have d=d(x) (d as a function of x).
Then find the derivative of d with respect to x.
When you set that equal to zero, you will be able to find your critical points and then find where d is a maximum.
jamesrc said:
No problem.
just got it,
thanks again for all this help! :smile:
1. What is an optimization problem?
An optimization problem is a mathematical problem that seeks to find the best possible solution from a set of possible solutions. The goal is to optimize a certain objective function, which can be either maximizing or minimizing a value, subject to certain constraints.
2. What are the different types of optimization problems?
There are two main types of optimization problems: linear optimization and nonlinear optimization. Linear optimization involves optimizing a linear objective function subject to linear constraints, while nonlinear optimization involves optimizing a nonlinear objective function subject to nonlinear constraints.
3. How are optimization problems solved?
Optimization problems are typically solved using mathematical techniques such as linear programming, gradient descent, and genetic algorithms. These techniques involve using algorithms to iteratively improve upon a solution until an optimal solution is found.
4. What are some real-world applications of optimization problems?
Optimization problems have various real-world applications, such as in finance, logistics, manufacturing, and engineering. Examples include optimizing investment portfolios, scheduling production processes, and designing efficient transportation routes.
5. What are some common challenges in solving optimization problems?
Some common challenges in solving optimization problems include dealing with a large number of variables and constraints, finding a balance between the conflicting objectives of maximizing and minimizing, and ensuring that the solution is feasible and realistic in the context of the problem.
