2 problems
  • Thread starter recon
I need to know the names of theorems related to the following two problems:
1. What is the maximum sum less than 1 but more than 0 that can be formed from [tex]\frac{1}{p} + \frac{1}{q} + \frac{1}{r}[/tex], where p, q and r are positive integers?
2. What is the maximum perimeter and area of an inscribed quadrilateral and triangle in a circle with a fixed radius r?
Answers and Replies
I realise that there may be no established theorems for the above 2 problems, so can anyone please suggest how I can go about solving them?
OK, I'm going to shamelessly bump this. *BUMP*
Can someone tell me if it is even possible to solve the second problem? The first one has been solved already.
VietDao29
1,424
Hi,
I am trying to find the maximum perimeter an inscribed quadrilateral, but I haven't succeeded yet.
About the maximum area an inscribed quadrilateral, I suggest you using:
[tex]S_{ABC} = \frac{1}{2} \times AB \times AC \times \sin{BAC}[/tex]
Call A, B, C, D the points on the circle.
Try to figure out the [tex]S_{AOB}, S_{BOC}, S_{COD}, S_{DOA}[/tex] using the above function.
OA = OB = OC = OD = R
And [tex]\sin{90} = 1 \mbox{is max}[/tex]
So an inscribed quadrilateral has the max erea is the inscribed square.
That's it.
Hope it help, :smile:
PS: Can you give me the answer for number 1?
Is it
[tex]\frac{41}{42}[/tex]?
Thanks,
Viet Dao,
Is it
Thanks,
Viet Dao,
Thanks for the help. :smile: And yes, that is the answer to question 2, not 1.
Related Threads on 2 problems
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
