Estimating Sun's Diameter & Earth's Radius: 2 Questions in Physics
  • Thread starter Indigo Prophercy
  • Tags
    Physics
In summary, the conversation discusses two questions for homework and the need for help in solving them. The first question involves estimating the sun's diameter using a metre-stick, a piece of paper, and the knowledge of its distance from the earth. The second question involves determining the Earth's radius by measuring the time between two sunsets, one while lying on the beach and the other while standing up. The person asking for help is reminded to show their work before receiving assistance.
Indigo Prophercy
I got these 2 questions for homework and i can't figure them out.
Number 1 is With only a metre-stick, a piece of paper and the knowledge that the sun is 1.50 x 10^11m from the earth, how can one estimate the suns diameter.
Number 2 is You can watch the sun set and disappear over a calm ocean while you lie on the beach, then once again if u stand up. Determine an approximate value of the Earth's radius. Measuring the time between the 2 sun sets.
If anyone can help i would be so thankful!
You're supposed to show some of your work before anyone can help.
For question 1, you can use the concept of angular size to estimate the sun's diameter. First, measure the length of the shadow cast by the metre-stick. Then, hold the piece of paper at arm's length and mark the length of the shadow on the paper. This will represent the angular size of the sun. Next, using the knowledge that the sun is 1.50 x 10^11m away, you can use trigonometry to calculate the actual size of the sun's diameter.
For question 2, you can use the concept of angular velocity to estimate the Earth's radius. First, measure the time between the two sunsets. Then, using the knowledge that the Earth rotates at a constant rate of 15 degrees per hour, you can calculate the angular distance the sun traveled between the two sunsets. Finally, using the formula for angular velocity (angular distance divided by time), you can calculate the Earth's radius. Keep in mind that this is only an approximate value, as there are many factors that can affect the actual time it takes for the sun to set.
1. What is the difference between velocity and acceleration?
Velocity is the rate of change of an object's position over time, while acceleration is the rate of change of an object's velocity over time. In other words, velocity measures the speed and direction of an object's motion, while acceleration measures how quickly the velocity is changing.
2. Can an object have a constant velocity but changing acceleration?
Yes, an object can have a constant velocity while its acceleration is changing. This is known as uniform circular motion, where the object moves in a circular path at a constant speed, but its direction is constantly changing due to the changing acceleration caused by the centripetal force.
3. What is the difference between scalar and vector quantities?
Scalar quantities are quantities that have only magnitude, such as mass, time, and temperature. Vector quantities, on the other hand, have both magnitude and direction, such as velocity, acceleration, and force.
4. How does Newton's Second Law of Motion explain the relationship between force, mass, and acceleration?
Newton's Second Law of Motion states that the acceleration of an object is directly proportional to the net force applied to it and inversely proportional to its mass. This means that the greater the force applied to an object, the greater its acceleration will be, and the greater the mass of an object, the smaller its acceleration will be for a given force.
5. What is the difference between static and kinetic friction?
Static friction is the force that prevents two surfaces from sliding past each other when they are not in motion, while kinetic friction is the force that opposes the relative motion of two surfaces that are already in motion. Generally, static friction is greater than kinetic friction, meaning it takes more force to overcome static friction and start an object moving than it does to keep it moving.
24K
