(2+x^2)dy/dx - x(y+3)= 0 , y(0)=-1
  • Thread starter deryk
In summary, the conversation discusses how to solve the initial value problem (2+x^2)dy/dx = x(y+3). It involves using a substitution u = 2+x^2 and integrating both sides to find the solution. The conversation also emphasizes the importance of practicing similar problems to become proficient in solving them.
deryk
The question asked to solve this initial value problem
(2+x^2)dy/(dx*(y+3) = x
dy/[(y+3)*dx]= x/(2+x^2)
dy/(y+3) = x*dx/(2+x^2)
S dy/(y+3) = S x/(2+x^2)*dx
ln(y+3) = ?
Im not sure what to do with the RHS do I do integration by parts?
Did it occur to you that, since you have xdx in the numerator, you might try a substitution: u= 2+ x2?
well your right so far
so your only problem is the rhs?
if so
let u=x^2+2
du/dx=2x
du=2xdx
dx=du/(2x)
the sub back into rhs as u=x^2+2 and dx=du/(2x)to be left with
x/(u)*du/(2x)
x's cancel
1/u*du
then intergrate with respect to u, once done that sub u=x^2+2
then I'm sure you can find the constant by using y(0)=-1
only way to know how to do this is to practise many examples!
1. What is the equation (2+x^2)dy/dx - x(y+3)= 0 used for?
This equation is a first-order linear differential equation that is commonly used in mathematical and scientific fields to model various physical phenomena, such as chemical reactions, population growth, and heat transfer.
2. How do you solve the equation (2+x^2)dy/dx - x(y+3)= 0?
To solve this equation, you can use the method of separation of variables. This involves isolating the variables dy and dx on opposite sides of the equation and then integrating both sides to obtain the general solution. You can also use other techniques such as substitution or the integrating factor method.
3. What does the initial condition y(0)=-1 mean in this equation?
The initial condition y(0)=-1 represents the value of the dependent variable y at the initial value of the independent variable x=0. This information is necessary to find the particular solution of the differential equation.
4. Can this equation be solved analytically or does it require numerical methods?
This equation can be solved analytically using various methods as mentioned in the answer to question 2. However, in some cases, the equation may be too complex to solve analytically, and numerical methods such as Euler's method or Runge-Kutta methods may be required to approximate the solution.
5. What are the applications of solving this type of differential equation?
This type of differential equation has numerous real-world applications in fields such as physics, chemistry, biology, engineering, and economics. It can be used to model various processes and make predictions about their behavior, which can then be used to inform decision making and problem-solving.
