214 related rates gravel cone
In summary, when the pile is $10 ft$ high, the height of the pile is increasing at a rate of $\displaystyle \frac{120}{\pi}\,ft/min.$
karush
MHB
3,269
Gravel is being dumped from a conveyor belt at a rate of
$30\displaystyle\frac{ ft}{min}$
and its coarseness is such that it forms a pile in the shape of a cone whose base diameter and height are always equal.
How fast is the height of the pile increasing when the pile is
$10 ft$ high?
$$V=\frac{1}{3}\pi r^2h$$
Gravel is being dumped from a conveyor belt at a rate of \(\displaystyle 30\,\frac{\text{ft}^3}{\text{min}}\)
This tells us, if we let all measures of length be in feet, and all measures of time be in minutes, that we may write:
\(\displaystyle \d{V}{t}=30\)
and its coarseness is such that it forms a pile in the shape of a cone:
This tells is we may write:
\(\displaystyle V=\frac{\pi}{3}r^2h\)
whose base diameter and height are always equal:
\(\displaystyle 2r=h\implies r=\frac{h}{2}\)
How fast is the height of the pile increasing when the pile is 10 ft high?
This tells us we want to find \(\displaystyle \d{h}{t}\) when \(h=10\).
I would begin by expressing the volume \(V\) of the cone as a function of \(h\):
\(\displaystyle V=\frac{\pi}{3}\left(\frac{h}{2}\right)^2h=\frac{\pi}{12}h^3\)
Now, implicitly differentiate w.r.t \(t\):
\(\displaystyle \d{V}{t}=\frac{\pi}{4}h^2\d{h}{t}\)
Can you finish?
$\displaystyle \d{V}{t}=\frac{\pi}{4}h^2\d{h}{t} $
since
$\d{V}{t}=30$and $h=10$
then$\displaystyle 30=\frac{\pi}{4}10^2\d{h}{t} $
so far
1. What is a "214 related rates gravel cone" problem?
A "214 related rates gravel cone" problem is a type of calculus problem that involves finding the rate of change of a cone-shaped pile of gravel. This type of problem is commonly used in physics and engineering to analyze real-world situations where multiple variables are changing simultaneously.
2. How do you set up a "214 related rates gravel cone" problem?
To set up a "214 related rates gravel cone" problem, you will need to identify the variables involved and their relationships. This typically includes the height, radius, and volume of the cone, as well as the rate of change of one or more of these variables. You will then use the chain rule and implicit differentiation to find the rate of change of the desired variable.
3. What is the formula for finding the volume of a cone?
The formula for finding the volume of a cone is V = (1/3)πr2h, where r is the radius and h is the height of the cone. This formula can be used to solve "214 related rates gravel cone" problems by taking the derivative with respect to time and using the chain rule to find the rate of change of the volume.
4. What are some common applications of "214 related rates gravel cone" problems?
"214 related rates gravel cone" problems have many real-world applications, including determining the rate at which a pile of gravel is being added or removed, calculating the rate at which a liquid is draining from a cone-shaped container, or finding the rate at which a sand pile is eroding on a beach.
5. What are some tips for solving "214 related rates gravel cone" problems?
Some tips for solving "214 related rates gravel cone" problems include carefully identifying the variables and their relationships, drawing a diagram to visualize the problem, and using the chain rule and implicit differentiation correctly. It can also be helpful to check your answer by plugging it back into the original problem to ensure it makes sense in the given context.
  • Calculus
  • Calculus
  • Calculus
  • Calculus
  • Calculus
